Sinusbot wont start. Help
Ramy
I have intsalled Sinusbot properly on my 64bit windows and I started the bot as administrator
and opened my browser and logged in to the panel
and I added my teamspeak server settings correctly and I added music and bot wont start on teamspeak
Version: 0.9.8
2016/07/26 12:23:07 cc08e2f8 INFO   Initializing bot://cc08e2f8-3ecf-48dd-b894-4
d7715c38869
2016/07/26 12:23:07 cc08e2f8 ece480fe INFO   Loaded
2016/07/26 12:23:07 FFmpeg/avcodec v3673444; license: LGPL version 2.1 or later;
493 codecs
2016/07/26 12:23:07 FFmpeg/avformat v3673958; license: LGPL version 2.1 or later
; 138 formats
2016/07/26 12:23:07 cc08e2f8 ece480fe INFO   Starting instance ts3server://ts.bl
ackwonder.tf?port=9987&nickname=Trap%20Bot&password=&channel=Counter%20Strike%3A
%20Global%20Offensive&channelpassword=
2016/07/26 12:23:07 cc08e2f8 ece480fe ERROR  Error spawning instancefork/exec C:
\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: The requested operation requir
es elevation.
2016/07/26 12:23:07 cc08e2f8 ece480fe INFO   TSClient quit.
2016/07/26 12:23:07 RadioStation data loaded
2016/07/26 12:23:07 Imported radio stations
2016/07/26 12:23:13 cc08e2f8 ece480fe WARN   Could not request shutdown
2016/07/26 12:23:21 cc08e2f8 ece480fe INFO   Starting instance ts3server://ts.bl
2016/07/26 12:23:21 cc08e2f8 ece480fe ERROR  Error spawning instancefork/exec C:
es elevation.
2016/07/26 12:23:21 cc08e2f8 ece480fe INFO   TSClient quit.
Don't run as admin and disable compatibility mode should it be enabled (right click the sinusbot.exe).
Ramy
edit : I managed to get it to work by putting an old vesion of teamspeak in the sinusbot folder
