Sinusbot won't start
Haeth.
a while ago, there was a problem with Sinusbot, especially TS3 client along with Sinusbot.. so the problem was that TS3 3.3 now requires kernel 3.17 or higher, but when I manually updated it (current kernel version is: 4.9.0-0.bpo.9-amd64 ) it still does not work and I again end up with error, that you can see right here.
Thanks for any help.
Haeth.
Prolly some issue with dependencies... you're sure you got everything installed as supposed?
https://sinusbot.github.io/docs/installation/linux/#manual-installation
Nope, I tried it multiple times, without success.
@irgendwr
 - Kernel: Linux 4.9.0-0.bpo.9-amd64 x86_64
 - Load Average: 0.10 0.26 0.18
 - Uptime: 0 days, 22 hours, 10 minutes, 41 seconds
 - OS APT Last Update: 06.09.2019 16:18:27 UTC +00:00:00
 - Shell Locale: (not set)
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Westmere E56xx/L56xx/X56xx (Nehalem-C)
    CPU MHz:               2400.084
    Virtualization:        VT-x
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 232.83 MB/996.38 MB in use (23%)
 - DISK: 2.44 GB/9.70 GB in use (25%)
   - libglib: 2.42.1-1+deb8u3
 - Status: running (PIDs: 3289 3286, User: sinusbot)
 - Binary Info: MD5 Hash: 2ee075d4cb2a3a640862b4eefa0fa6b1, Perms: 755, User: si        nusbot
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64        (Version 3.3.0)
   - YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2019.07.02)
 - Installed scripts: Aukce.js; Auto_Channel_Creator.js; Tunakills_Rankingsystem        .js; badni.js; bookmark.js; channelDescriptionChanger.js; command.js; customGrou        pAssigner.js; followme.js; massiveGroupAssigner.js; navstevky.js; norecording.js        ; onlineClientsInChannelName.js; rememberChannel.js; welcome.js
    linux-vdso.so.1 (0x00007ffeb73de000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f89af0e2000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f89aed8a000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f89ae989000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f89ae024000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f89addb0000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f89adbac000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f89ad8ab000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f89ad68e000        )
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f89ad3830        00)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f89ad16d000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f89acdc2000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f89acba7000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f89ac99f000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f89af2fc000)
 - HTTPS check with IPv4 mode: SUCCESS [Connection established to www.sinusbot.c        om, CODE #200]
 - Time (local): 06.09.2019 16:22:34 UTC +00:00:00
 - Timezone: Etc/UTC
 - TeamSpeak3 Version: 3.3.0
 - youtube-dl Version: 2019.07.02
