DE [Solved]Script var conditions
Kamikaze
Ich habe folgende var
JavaScript:
        aa_StreamerOverviewActive: {
            title: 'Single or PerUser Overview? (PerUser = Streamer Overview in Streamer Channel instead all in one Channel)',
            indent: 0,
            type: 'select',
            options: [
                'Single',
                'None',
                'Both'
Und var's mit der 'condition' ob der wert 0 ist. wie kann ich die condition so setzen das die configs bei 0 oder 2 angezeigt werden?
JavaScript:
        b_StreamerOverviewChannel: {
            title: 'Select Channel for Streamer Overview:',
            indent: 1,
            type: 'channel',
            conditions: [
                { field: 'aa_StreamerOverviewActive', value: 0 }
So hat's nicht funktioniert^^
JavaScript:
{ field: 'aa_StreamerOverviewActive', value: 0 },
{ field: 'aa_StreamerOverviewActive', value: 2 }
DrWarpMan
I asked similar question to the Sinusbot Staff team, and they told me it is not possible now. I am not 100% sure about this one, but at least 99% sure that this won't work :D
(So.. do not rely on my response)
