Sound Bugs
FDGod07
Hello Everone,
My Sinusbot has a laggy and a Robotic Sound.
OS: Windows Server 2008 R2 Standard 64-Bit
CPU: i7 2600 @ 3,4 GHz
RAM: 6GB
HDD: 500GB
Used Browser Google Chrome
Only 1xTS3 Server and 1x Sinusbot
DataDir = "C:\\SinusBot\\data\\"
YoutubeDLPath = "C:\\Musik"
SampleInterval = 40
EnableWebStream = true
LicenseKey = "TGK+Bkk+NL9xfLnxOGFLiop0A3L6icuegtrNev2HRxg="
2016-09-08T19:06:29+02:00 Added EVListener
2016-09-08T19:06:28+02:00 LOGIN [admin] OK
2016-09-08T19:06:18+02:00 Loading instance://2d05d037-e044-451e-a413-a17b041d0e8d
2016-09-08T19:06:18+02:00 Loading instances
2016-09-08T19:08:18+02:00 Storing configuration.
2016-09-08T19:07:49+02:00 Done playing
2016-09-08T19:07:49+02:00 Channels now zero
2016-09-08T19:07:49+02:00 Deleting channel
2016-09-08T19:07:49+02:00 STOP [admin] OK
2016-09-08T19:07:18+02:00 Storing configuration.
2016-09-08T19:07:12+02:00 Deleting channel
2016-09-08T19:07:11+02:00 New channel
2016-09-08T19:07:11+02:00 PLAYURL [admin] http://fm.opentree.cz:80/dnbradio OK
2016-09-08T19:07:08+02:00 New channel
2016-09-08T19:07:08+02:00 PLAYURL [admin] http://fm.opentree.cz:80/dnbradio OK
2016-09-08T19:06:58+02:00 SEEK [admin] 52.812500 OK
2016-09-08T19:06:48+02:00 Storing configuration.
2016-09-08T19:06:45+02:00 PLAY-NEXT [admin] OK
2016-09-08T19:06:44+02:00 PLAY-PREV [admin] OK
2016-09-08T19:06:23+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2016-09-08T19:06:22+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2016-09-08T19:06:21+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2016-09-08T19:06:20+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2016-09-08T19:06:19+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2016-09-08T19:06:19+02:00 New connection status 4; Error 0
2016-09-08T19:06:19+02:00 New connection status 3; Error 0
2016-09-08T19:06:19+02:00 New connection status 2; Error 0
2016-09-08T19:06:19+02:00 New connection status 1; Error 0
2016-09-08T19:06:19+02:00 TS>DUMP defined! Dumpdir is: C:\SinusBot\data\/ts3/db8541d5-0fa6-4b3c-b63c-25e668c01f20/2d05d037-e044-451e-a413-a17b041d0e8d/\crashdumps
2016-09-08T19:06:19+02:00 TS>Crashdump ENABLED, directory is: C:\SinusBot\data\/ts3/db8541d5-0fa6-4b3c-b63c-25e668c01f20/2d05d037-e044-451e-a413-a17b041d0e8d/\crashdumps
2016-09-08T19:06:19+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-09-08T19:06:19+02:00 Could not insert into Notifications-Tableno such table: Notifications
2016-09-08T19:06:19+02:00 Could not delete from Notificationsno such table: Notifications
2016-09-08T19:06:19+02:00 < PrepareListener
2016-09-08T19:06:19+02:00 > PrepareListener
2016-09-08T19:06:18+02:00 Auto-Starting db8541d5-0fa6-4b3c-b63c-25e668c01f20/2d05d037-e044-451e-a413-a17b041d0e8d in 500 ms...
2016-09-08T19:06:18+02:00 Initialization complete
I tried to Switch SampleInterval from 0-200 nothing helped. Channel Quality was Opus Musik and 11,87KiB/S. My Ping was 16ms and 0% packet lose. Dont know what should be changed that it is gona fix. Maybe you can help me ;)
FDGod07
FDGod07
I use the Latest Beta.
Other things that i can try?
I readed some things about Kernel Timing or so
Bad CPU Timing * :)
And please do not play around with the SampleInterval in versions above 0.9.8 > both for Windows & Linux this may causes more problems.
But back 2 topic: CPU Timing has to do with your virtualization, if you host the VM's by your self you have to setup your host/software properly.
Software like Virtualbox should not be used for "real" virtualization, it is good for testing but not for production.
But at all, the Sinusbot is so far optimized both on Linux and Windows so i think we can't do much here at the moment.
