(suggestion) Add/upload music directory without drag and drop method
hrezaei
Hi.
I've been testing the 0.8 version of the bot. I want to add music without the use of drag and drop method. Maybe a browse button, or a field in which you could enter the full directory name.
Is it possible to add that please?
Thank you.
P.S I'm visually impaired, I use screen reader software, e. I use the keyboard to navigate, hence asking for this feature.
Cheers
Hadi
Currently, it's not possible. But I'll add that to one of the next versions, then. :)
hrezaei
that's cool, thanks!
meanwhile, Can i add files manually? Is there a folder in which i could drop my music files?
Just some news on this issue:
The latest beta has this huge upload field which is now clickable as well and will open the file selector. Does that help?
And no, you cannot simply add files, sorry.
