The bot doesnt make sound
Hello today i tried to reinstall the sinusbot version a lot of time with script , by my own and by tring to downgrade / upgrade the teamspeak client versions .
Thanks for the help and for the time
 - Kernel: Linux 4.19.0-5-amd64 x86_64
 - Load Average: 1.45 0.91 0.54
 - Uptime: 1 days, 16 hours, 7 minutes, 12 seconds
 - OS APT Last Update: 08.04.2020 04:14:02 EDT -04:00:00
 - Shell Locale: en_US.UTF-8
    Architecture:        x86_64
    CPU(s):              1
    Thread(s) per core:  1
    Core(s) per socket:  1
    Socket(s):           1
    Model name:          AMD Opteron 23xx (Gen 3 Class Opteron)
    CPU MHz:             2395.498
    Hypervisor vendor:   KVM
    Virtualization type: full
 - RAM: 512.13 MB/987.35 MB in use (51%)
 - DISK: 2.05 GB/24.59 GB in use (8%)
   - libglib: 2.58.3-2+deb10u2
 - Status: running (PIDs: 30332 30331, User: sinusbot)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2020.03.24)
 - Installed scripts: adminStaffStatus1.0.0.js; advertising.js; AFK_Mover.js; alonemode.js; Auto_Channel_Creator.js; bookmark.js; Channel_Description_Changer.js; Channel_Servergroup_Assigner.js; clientStatusInChannelName.js; command.js; CountOnlineUsers.js; dice.js; Digital_Clock.js; followme.js; groupChecker.js; group-dependencies.js; Group__Distributor.js; Jail.js; norecording.js; OKlib.js; onlineMembersCount.js; Private_Channel_Manager.js; Reconnect.js; rememberChannel.js; RLNT AHG v1.0.5.js; RLNT OOTO v1.0.0.js; ServerGroupOnConnect.js; servergroupSwitcher.js; Server_Join_Alert.js; Server_Rules.js; sinusbot-commands.js; Support.js; verify.js; welcome.js; Youtube_Search.js; YT-search.js
    linux-vdso.so.1 (0x00007ffd08eff000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fe4a0891000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fe4a0539000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fe4a0138000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fe49f7d3000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fe49f55f000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fe49f553000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fe49f3ce000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fe49f3ad000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fe49f229000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fe49f20f000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fe49f04e000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fe49ee30000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fe49ee24000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fe4a0aad000)
 - Time (local): 08.04.2020 13:11:29 EDT -04:00:00
 - Time (remote): 08.04.2020 13:11:27 EDT -04:00:00
 - Time (difference): 2 secs (Time diff less than 2 secs. Good.)
 - Timezone: America/New_York
 - TeamSpeak3 Version: 3.3.2
 - youtube-dl Version: 2020.03.24
And how you you play that music, from an uploaded file, youtube, etc?
C'mon, show a little initiative ... what does you instance log say?
The file is uploaded and the log says that is playing, all works without problems and errors the only problem is that it doesnt make sound
fabm3n
Tier II
Tier I
Can you send us your Instance Log?
But please set your LogLevel in your config.ini to 10 and then restart Sinusbot :)
2020-04-10T03:27:35+02:00 PLAY [admin] 08076b31-93b1-4d5f-b429-68200e769fcd OK
2020-04-10T03:27:18+02:00 unloaded instance
2020-04-10T03:27:13+02:00 script AFK_Mover loaded
2020-04-10T03:27:13+02:00 script servergroupSwitcher loaded
2020-04-10T03:27:13+02:00 script Server_Rules loaded
2020-04-10T03:27:13+02:00 script Group__Distributor loaded
2020-04-10T03:27:13+02:00 script sinusbot-commands loaded
2020-04-10T03:27:13+02:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-04-10T03:27:13+02:00 script command loaded
2020-04-10T03:27:13+02:00 script OKlib loaded
2020-04-10T03:27:13+02:00 no valid script found in Channel_Servergroup_Assigner.js
2020-04-10T03:27:13+02:00 error in script: Uncaught exception: SyntaxError: Unexpected identifier at Channel_Servergroup_Assigner.js:11:4 sgid: { ^^^^ Stack trace: SyntaxError: Unexpected identifier
2020-04-10T03:27:05+02:00 unloaded instance
2020-04-10T03:27:00+02:00 script AFK_Mover loaded
2020-04-10T03:27:00+02:00 script servergroupSwitcher loaded
2020-04-10T03:27:00+02:00 script Server_Rules loaded
2020-04-10T03:27:00+02:00 script sinusbot-commands loaded
2020-04-10T03:27:00+02:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-04-10T03:27:00+02:00 script command loaded
2020-04-10T03:27:00+02:00 script OKlib loaded
2020-04-10T03:27:00+02:00 no valid script found in Channel_Servergroup_Assigner.js
2020-04-10T03:27:00+02:00 error in script: Uncaught exception: SyntaxError: Unexpected identifier at Channel_Servergroup_Assigner.js:11:4 sgid: { ^^^^ Stack trace: SyntaxError: Unexpected identifier
2020-04-10T03:26:44+02:00 Could not add client to group: client is already a member of the group
2020-04-10T03:26:44+02:00 [servergroupSwitcher:100:20] Adding ID: 19
2020-04-10T03:26:44+02:00 [servergroupSwitcher:94:28] New groupsToAdd length: 1
2020-04-10T03:26:44+02:00 [servergroupSwitcher:92:28] Old groupsToAdd length: 0
2020-04-10T03:26:44+02:00 [servergroupSwitcher:90:24] Trigger group ID loop: 16
2020-04-10T03:26:44+02:00 [servergroupSwitcher:90:24] Trigger group ID loop: 61
2020-04-10T03:26:44+02:00 Could not remove client from group: client is not a member of the group
2020-04-10T03:26:44+02:00 [servergroupSwitcher:83:20] Removing ID: 47
2020-04-10T03:26:44+02:00 [servergroupSwitcher:83:20] Removing ID: 46
2020-04-10T03:26:44+02:00 [servergroupSwitcher:83:20] Removing ID: 45
2020-04-10T03:26:44+02:00 [servergroupSwitcher:83:20] Removing ID: 61
2020-04-10T03:26:44+02:00 [servergroupSwitcher:83:20] Removing ID: 17
2020-04-10T03:26:44+02:00 [servergroupSwitcher:77:28] New groupsToRemove length: 5
2020-04-10T03:26:44+02:00 [servergroupSwitcher:75:28] Old groupsToRemove length: 4
2020-04-10T03:26:44+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 16
2020-04-10T03:26:44+02:00 [servergroupSwitcher:77:28] New groupsToRemove length: 4
2020-04-10T03:26:44+02:00 [servergroupSwitcher:75:28] Old groupsToRemove length: 3
2020-04-10T03:26:44+02:00 [servergroupSwitcher:77:28] New groupsToRemove length: 3
2020-04-10T03:26:44+02:00 [servergroupSwitcher:75:28] Old groupsToRemove length: 2
2020-04-10T03:26:44+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 47
2020-04-10T03:26:44+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 46
2020-04-10T03:26:44+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 44
2020-04-10T03:26:44+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 45
2020-04-10T03:26:44+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 61
2020-04-10T03:26:44+02:00 [servergroupSwitcher:77:28] New groupsToRemove length: 2
2020-04-10T03:26:44+02:00 [servergroupSwitcher:75:28] Old groupsToRemove length: 1
2020-04-10T03:26:44+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 17
2020-04-10T03:26:44+02:00 [servergroupSwitcher:77:28] New groupsToRemove length: 1
2020-04-10T03:26:44+02:00 [servergroupSwitcher:75:28] Old groupsToRemove length: 0
2020-04-10T03:26:44+02:00 [servergroupSwitcher:69:16] Added groupID was: 16
2020-04-10T03:26:39+02:00 [servergroupSwitcher:90:24] Trigger group ID loop: 16
2020-04-10T03:26:39+02:00 [servergroupSwitcher:90:24] Trigger group ID loop: 61
2020-04-10T03:26:39+02:00 [servergroupSwitcher:83:20] Removing ID: 17
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 46
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 45
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 44
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 61
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 16
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 47
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 17
2020-04-10T03:26:39+02:00 [servergroupSwitcher:77:28] New groupsToRemove length: 1
2020-04-10T03:26:39+02:00 [servergroupSwitcher:75:28] Old groupsToRemove length: 0
2020-04-10T03:26:39+02:00 [servergroupSwitcher:73:24] Trigger group ID loop: 19
2020-04-10T03:26:39+02:00 [servergroupSwitcher:69:16] Added groupID was: 19
2020-04-10T03:26:36+02:00 [servergroupSwitcher:90:24] Trigger group ID loop: 16
2020-04-10T03:26:36+02:00 [servergroupSwitcher:90:24] Trigger group ID loop: 61
2020-04-10T03:26:36+02:00 Could not remove client from group: client is not a member of the group
2020-04-10T03:26:36+02:00 [servergroupSwitcher:83:20] Removing ID: 42
2020-04-10T03:26:36+02:00 [servergroupSwitcher:83:20] Removing ID: 41
First of all you better remove this script, since it's not working, not even being a valid JS-file. Then you reply please back.
Tried to change the loglevel but nothing changed
So you're saying, after setting the LogLevel to 10, restarting, and then waiting for another crash, the log looks exact 100% the same?
Did you remove the malicious script though?
You can hardly be helped, if you don't do what you've been told. :rolleyes:
The bot never crashed, im doing everthing that you are all saying . I changed the config stuff and removed the js scripts but as i said nothing changed
Well but if you did so, why don't you post your log again? For everything you have to be asked, instead of giving some infos on your own...
Also what are you doing on "playing and nothing happens"?
You use webinterface? A bot cmd?
2020-04-11T16:17:35+02:00 SpEcTeR joined the channel
2020-04-11T15:52:08+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T14:57:05+02:00 Andreehi joined the channel
2020-04-11T14:51:45+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T14:37:12+02:00 Richich00 joined the channel
2020-04-11T13:51:23+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T13:20:23+02:00 Andreehi joined the channel
2020-04-11T13:13:52+02:00 PolloStorto joined the channel
2020-04-11T12:51:05+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T12:36:54+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T12:29:25+02:00 ExTy joined the channel
2020-04-11T12:23:33+02:00 ExTy joined the channel
2020-04-11T12:03:23+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T11:03:03+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T10:15:31+02:00 Drip8 joined the channel
2020-04-11T10:15:27+02:00 ExTy joined the channel
2020-04-11T10:14:57+02:00 Mysteroalex joined the channel
2020-04-11T10:13:44+02:00 ExTy joined the channel
2020-04-11T10:02:44+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T09:59:51+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T09:20:40+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T09:16:58+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T08:16:41+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T07:16:25+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T06:49:12+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T06:40:17+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T06:32:30+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T06:06:56+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T06:05:12+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T05:35:44+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T04:59:16+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T03:59:00+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T03:51:04+02:00 GODz Pagi joined the channel
2020-04-11T03:08:29+02:00 SpEcTeR1 joined the channel
2020-04-11T02:58:41+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T02:58:07+02:00 Montes joined the channel
2020-04-11T01:58:42+02:00 Done playing
2020-04-11T01:58:42+02:00 Channels now zero
2020-04-11T01:58:42+02:00 Deleting channel 08076b31-93b1-4d5f-b429-68200e769fcd () ID 3720929b-7d80-4052-81ff-bcedd02d74d4 (cc 1)
2020-04-11T01:58:42+02:00 Removing closed channel 08076b31-93b1-4d5f-b429-68200e769fcd () ID 3720929b-7d80-4052-81ff-bcedd02d74d4
2020-04-11T01:58:22+02:00 TS |WARNING |SCHandler |1 |Received unknown packet
2020-04-11T01:56:42+02:00 TS> To get a list of available commands see [B]!help[/B]
2020-04-11T01:56:42+02:00 TS> You do not have permissions to use this command!
2020-04-11T01:56:42+02:00 [ command:41:14] SpEcTeR (h9nvCmv8MowCGGvE9ILf1/aXX9s=) is missing permissions for !play
2020-04-11T01:56:42+02:00 [ command:41:14] SpEcTeR (h9nvCmv8MowCGGvE9ILf1/aXX9s=) used !play
2020-04-11T01:56:40+02:00 TS> To get a list of available commands see [B]!help[/B]
2020-04-11T01:56:40+02:00 TS> You do not have permissions to use this command!
2020-04-11T01:56:40+02:00 [ command:41:14] SpEcTeR (h9nvCmv8MowCGGvE9ILf1/aXX9s=) is missing permissions for !stop
2020-04-11T01:56:40+02:00 [ command:41:14] SpEcTeR (h9nvCmv8MowCGGvE9ILf1/aXX9s=) used !stop
2020-04-11T01:56:37+02:00 [ command:41:14] SpEcTeR (h9nvCmv8MowCGGvE9ILf1/aXX9s=) used !playing
2020-04-11T01:56:27+02:00 TS> To get a list of available commands see [B]!help[/B]
2020-04-11T01:56:27+02:00 TS> You do not have permissions to use this command!
2020-04-11T01:56:27+02:00 [ command:41:14] SpEcTeR (h9nvCmv8MowCGGvE9ILf1/aXX9s=) is missing permissions for !say
2020-04-11T01:56:27+02:00 [ command:41:14] SpEcTeR (h9nvCmv8MowCGGvE9ILf1/aXX9s=) used !say
2020-04-11T01:55:58+02:00 Storing configuration.
2020-04-11T01:55:31+02:00 VOLUME-SET [admin] 46 OK
2020-04-11T01:55:30+02:00 VOLUME-SET [admin] 40 OK
2020-04-11T01:54:58+02:00 Storing configuration.
2020-04-11T01:54:45+02:00 new track info: music test  (5468655765656b6e645645564f202d20546865205765656b6e64202d205468652048696c6c7320284f6666696369616c20566964656f29)
2020-04-11T01:54:45+02:00 New channel 08076b31-93b1-4d5f-b429-68200e769fcd () ID 3720929b-7d80-4052-81ff-bcedd02d74d4 (cc 0)
2020-04-11T01:54:45+02:00 PLAY [admin] 08076b31-93b1-4d5f-b429-68200e769fcd OK
I play it from webinterface
I play the music but the bot doesnt make sound , i just wrote this before
What server and client version are you using?
