DragonHacker
Operating System: Linux
SinusBot Version: 0.9.x NOPE 0.10.7
TS3 Version: 3.0.18
For first. My lang english is not main.
I use manually installed sinus, because is more simple. But im not "noob" linux. And use autostart script > with initd servicehttps://forum.sinusbot.com/resources/linux-bootscript-for-the-sinusbot.6/ if you consider is old script, but is working pretty good with start and stop function. i not like to use update screen etc. update i make manually.
Can't connect on because error (yea i use loglevel 10)
https://pastebin.com/sMh1LgZM
2017/10/15 07:33:05 30096d2a e3601a96 DEBUG TS>QXcbConnection: Could not connect to display unix/:40.0
older version is worked pretty good.. (sinusbot version)
config.ini
https://pastebin.com/R0mGehPF
browse? nope is not problem (chrome)
TS3 Version: 3.0.18
config.ini
- Operating System: Debian GNU/Linux 8.9 (jessie) (OpenVZ)
- Kernel: Linux 2.6.32-openvz-042stab120.16-amd64 x86_64
- Load Average: 0.63 0.40 0.21
- Uptime: 0 days, 0 hours, 16 minutes, 22 seconds
- OS APT Last Update: 14.10.2017 14:18:47 EDT -04:00:00
- Bot Start Script: found at /etc/init.d/sinusbot [perms: 777]
- RAM: B/8.14 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 2.73 GB/62.54 GB in use (4%)
> libglib: 2.42.1-1+b1
- Status: running (PIDs: 1680 1679, User: sinusbot)
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: 1fbc12a341f5e6f07b1bfb00b796b9e1)
- Version: 0.10.7-a91e4b6
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.18.2)
- YoutubeDLPath = not set
- Report date: 15.10.2017 07:49:05 EDT -04:00:00 (timezone: America/New_York)
- youtube-dl Version: unknown
- DiagScript version: 0.5.1
