Ts3 client quit when i press play.
Sweden
So the bot work fine, webgui works, bot joins the teamspeak and look good (aka mic and sound not disabled)
Then when i press play in the webgui then it all go bad.
The bot then disconects from the ts.
Tryed all of this...
https://sinusbot-installer.de/ (can run but then gives me error (Command which failed was: " apt-get update") )
Tsclients 3.3.2 , 3.3.0 , 3.3.3 , 3.1.6 and maybe more that i cant remenber now.
Sinusbot 1.0.0-beta.5 , 1.0.0-beta.5-b262b6a , current.tar.bz2
Heres wat the diagSinusbot.sh gave me.
it says the bot start script not fuond but i have done (https://github.com/SinusBot/linux-startscript)
- Operating System: Ubuntu 18.04.3 LTS
- Kernel: Linux 4.15.0-62-generic x86_64
- Load Average: 1.26 0.70 0.58
- Uptime: 0 days, 0 hours, 31 minutes, 23 seconds
- OS APT Last Update: 11.09.2019 10:46:12 CEST +02:00:00
- Shell Locale: en_US.UTF-8
    Architecture:        x86_64
    CPU(s):              4
    Thread(s) per core:  2
    Core(s) per socket:  2
    Socket(s):           1
    Model name:          Intel(R) Atom(TM) CPU  330   @ 1.60GHz
    CPU MHz:             1606.369
- RAM: 907.05 MB/2.93 GB in use (30%)
- DISK: 53.77 GB/58.43 GB in use (92%)
- Status: running (PIDs: 3025 3024, User: sinusbot)
   - YoutubeDLPath = not set
    linux-vdso.so.1 (0x00007ffd857f8000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f060a12a000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f0609dd2000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f06099d1000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f060906c000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f0608df8000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f0608bf4000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f0608856000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f0608637000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f06082ae000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f0608096000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0607ca5000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f0607a88000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f0607880000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f060a344000)
- Time (local): 11.09.2019 11:13:58 CEST +02:00:00
- Time (remote): 11.09.2019 11:13:58 CEST +02:00:00
- Timezone: Europe/Stockholm
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: unknown
From last crash report from /opt/sinusbot/data/ts3/4a73d474-e452-4d60-a636-f38de9cf0ad6/d272e838-05c2-4ef8-967d-854ec34f7d15/logs
2019-09-11 09:21:11.324621|INFO    |              |   |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019-09-11 09:21:11.325023|INFO    |              |   |SystemInformation: Linux 4.15.0-62-generic #69-Ubuntu SMP Wed Sep 4 20:55:53 UTC 2019 x86_64 Binary: 64bit
2019-09-11 09:21:11.770822|DEBUG   |PulseAudio    |   |connected to pulse audio server -
2019-09-11 09:21:11.777451|INFO    |              |   |*** Time [SPAWN_EVENTCONVERTER]: 119
2019-09-11 09:21:11.778572|INFO    |ClientUI      |   |Unable to create an Open GL context.
2019-09-11 09:21:11.782416|ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019-09-11 09:21:11.950022|INFO    |              |   |*** Time [ICONMANGER]: 322
2019-09-11 09:21:11.952609|INFO    |Addons        |   |Checking for addon updates...
2019-09-11 09:21:12.017347|INFO    |              |   |successfully downloaded revocation list for accounting
2019-09-11 09:21:12.034049|INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019-09-11 09:21:12.069712|INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-09-11 09:21:12.096716|INFO    |Query         |   |listening on 127.0.0.1:25639
2019-09-11 09:21:12.097441|INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019-09-11 09:21:12.392035|INFO    |              |   |*** Time [SERVERVIEWMANAGER]: 126
2019-09-11 09:21:12.538362|INFO    |              |   |*** Time [MAINWINDOW]: 1054
2019-09-11 09:21:12.539761|INFO    |              |   |*** Time [INIT]: 1056
2019-09-11 09:21:12.556754|INFO    |ClientUI      |   |Failed to init text to speech engine
2019-09-11 09:21:12.557178|INFO    |ClientUI      |   |Qt version: 5.12.1
2019-09-11 09:21:12.557956|INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/4a73d474-e452-4d60-a636-f38de9cf0ad6/d272e838-05c2-4ef8-967d-854ec34f7d15/settings.db
2019-09-11 09:21:12.840565|INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=Same%20Pirate%20Radio%20DJ&password=&cid=61&channelpassword=
2019-09-11 09:21:12.844094|INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2019-09-11 09:21:12.846093|INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2019-09-11 09:21:12.996138|INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019-09-11 09:21:13.103816|INFO    |ClientUI      |1  |Connect status: Connecting
2019-09-11 09:21:13.106174|INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019-09-11 09:21:13.109117|INFO    |ClientUI      |   |Last update check was: lör jan. 1 00:00:01 2022
2019-09-11 09:21:13.111331|INFO    |              |   |Statistics report: First run, report later in 1-30 days
2019-09-11 09:21:13.112033|INFO    |              |   |Statistics report: Setting next report date to: tis okt. 1 11:21:13 2019
2019-09-11 09:21:13.129843|DEVELOP |PktHandler    |   |Puzzle solve time: 26
2019-09-11 09:21:13.224408|INFO    |ClientUI      |1  |Connect status: Connected
2019-09-11 09:21:13.301473|INFO    |ClientUI      |1  |Connect status: Establishing connection
2019-09-11 09:21:13.425866|INFO    |ClientUI      |1  |Connect status: Connection established
2019-09-11 09:21:13.731171|INFO    |Newsticker    |   |Newsticker next check: lör jan. 1 00:00:01 2022
2019-09-11 09:21:13.891058|INFO    |              |   |Failed to read image /opt/sinusbot/data/ts3/4a73d474-e452-4d60-a636-f38de9cf0ad6/d272e838-05c2-4ef8-967d-854ec34f7d15/cache/remote/FRq8gdEHbC9EnF3XCoLZFnWQWwL0fEsMG+17c2PXh2FCydxLiMeG8o1lTduX6O_q3hL+dOGcDidoxzrEwIShPQ==
2019-09-11 09:21:13.891619|INFO    |              |   |No image, refusing to display
Logs From sinusbot Instance logs befor crash
2019-09-11T11:21:27+02:00 closing channels
2019-09-11T11:21:16+02:00 TSClient quit.
2019-09-11T11:21:15+02:00 TS>Starting Error Reporter: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/error_report
2019-09-11T11:21:15+02:00 TS>Breakpad crash /opt/sinusbot/data/ts3/4a73d474-e452-4d60-a636-f38de9cf0ad6/d272e838-05c2-4ef8-967d-854ec34f7d15/crashdumps/7f1bfef3-59f3-47ed-50e701ae-a663aaaa.dmp
2019-09-11T11:21:15+02:00 Awaiting Callback (1): PR:{aaeffdc4-dd1f-4d11-a50a-526dfc7365f5}:71/DESC
2019-09-11T11:21:15+02:00 new track info: Kelly Bailey - Adrenaline Horror (4b656c6c79204261696c6579202d20416472656e616c696e6520486f72726f72)
2019-09-11T11:21:15+02:00 PLAY [admin] 76cf0505-884a-4914-96d7-ea5db261ba34 OK
2019-09-11T11:21:15+02:00 New channel 76cf0505-884a-4914-96d7-ea5db261ba34 () ID ca6010c7-3b10-43e2-8419-90222bf88932 (cc 0)
2019-09-11T11:21:14+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{aaeffdc4-dd1f-4d11-a50a-526dfc7365f5}:67/GCLL'
2019-09-11T11:21:13+02:00 TS |INFO    |              |   |No image, refusing to display
2019-09-11T11:21:13+02:00 New connection status 4; Error 0
2019-09-11T11:21:13+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019-09-11T11:21:13+02:00 SaméFisk joined the channel
2019-09-11T11:21:13+02:00 New connection status 3; Error 0
2019-09-11T11:21:13+02:00 TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019-09-11T11:21:13+02:00 New connection status 2; Error 0
2019-09-11T11:21:13+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connected
2019-09-11T11:21:13+02:00 TS |DEVELOP |PktHandler    |   |Puzzle solve time: 26
2019-09-11T11:21:13+02:00 TS |INFO    |              |   |Statistics report: Setting next report date to: tis okt. 1 11:21:13 2019
2019-09-11T11:21:13+02:00 TS |INFO    |              |   |Statistics report: First run, report later in 1-30 days
2019-09-11T11:21:13+02:00 TS |INFO    |ClientUI      |   |Last update check was: lör jan. 1 00:00:01 2022
2019-09-11T11:21:13+02:00 TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019-09-11T11:21:13+02:00 New connection status 1; Error 0
2019-09-11T11:21:13+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019-09-11T11:21:12+02:00 TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019-09-11T11:21:12+02:00 TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2019-09-11T11:21:12+02:00 TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2019-09-11T11:21:12+02:00 TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=Same%20Pirate%20Radio%20DJ&password=&cid=61&channelpassword=
2019-09-11T11:21:12+02:00 TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/4a73d474-e452-4d60-a636-f38de9cf0ad6/d272e838-05c2-4ef8-967d-854ec34f7d15/settings.db
2019-09-11T11:21:12+02:00 TS |INFO    |ClientUI      |   |Qt version: 5.12.1
2019-09-11T11:21:12+02:00 TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019-09-11T11:21:12+02:00 TS |INFO    |              |   |*** Time [INIT]: 1056
2019-09-11T11:21:12+02:00 TS |INFO    |              |   |*** Time [MAINWINDOW]: 1054
2019-09-11T11:21:12+02:00 TS |INFO    |              |   |*** Time [SERVERVIEWMANAGER]: 126
2019-09-11T11:21:12+02:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2019-09-11T11:21:12+02:00 TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019-09-11T11:21:12+02:00 TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2019-09-11T11:21:12+02:00 TS |INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-09-11T11:21:12+02:00 TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019-09-11T11:21:12+02:00 TS |INFO    |              |   |successfully downloaded revocation list for accounting
2019-09-11T11:21:11+02:00 TS |INFO    |Addons        |   |Checking for addon updates...
2019-09-11T11:21:11+02:00 TS |INFO    |              |   |*** Time [ICONMANGER]: 322
2019-09-11T11:21:11+02:00 TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019-09-11T11:21:11+02:00 TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2019-09-11T11:21:11+02:00 TS |INFO    |              |   |*** Time [SPAWN_EVENTCONVERTER]: 119
2019-09-11T11:21:11+02:00 TS |DEBUG   |PulseAudio    |   |connected to pulse audio server -
2019-09-11T11:21:11+02:00 TS |INFO    |              |   |SystemInformation: Linux 4.15.0-62-generic #69-Ubuntu SMP Wed Sep 4 20:55:53 UTC 2019 x86_64 Binary: 64bit
2019-09-11T11:21:11+02:00 TS |INFO    |              |   |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
My config.ini
UploadLimit = 283086080
LicenseKey = "u7ZUnfS4FOQfeKvP2FzgMBwPhk5DgMUn746+PkHl/Bw="
  ChunkSize = 5242880
  AllowGIF = true
webgui bot log
2019-09-11T11:32:17+02:00 Loading instance://d272e838-05c2-4ef8-967d-854ec34f7d15
2019-09-11T11:32:17+02:00 Loading instances
Just fyi:
If you're always running the lastest TeamSpeak server version (currently 3.9.1), downgrading to anything below client version 3.3.0 won't be an option soon. TeamSpeak's new server version 3.10.0 won't support older client versions and is to be released within two weeks.
Sweden
ahh well fuk i stent 3 days trying to figger it out and u telling me its cuz my cpu :p well poop :D
apart from my linus server for ts and sinusbot i have a windows server i run game servers on can i run sinusbot on that till a fix come for teamspeak on linux then just tell it where my server is right :D
GamerMarc
Just fyi:
That's one of the problems, but if he does not has a updated TeamSpeak Server, it will help him
I'm assuming it might be correlated with your CPU, but thats just a guess.
Many people don't have influence on their server version, and even if they do, I personally don't see a reason and wouldn't recommend to use an outdated server version which has security holes and is vulnerable.
GamerMarc
Yes, Im with you, but if he does not has anything more to do...
Sweden
can i some how move my setting/data froom the linux sinusbot to my windows one ?
saw that its possibel to to windows to linux will give it a try
