Ts3 Joint Nicht
Carrot44
Ich hatte gestern mein Rootserver neu installiert davor hat der Bot nie probleme gemacht ich habe ihn dann neu installiert Rootserver und Bot seitdem bekomme ich immer denn Fehler habe alle tipps des Forum schon probiert nichts hat funktioniert.
Fehler:
2019-10-06T13:33:30+02:00 Storing configuration.
2019-10-06T13:33:05+02:00 eof from voice
2019-10-06T13:33:05+02:00 closing channels
2019-10-06T13:33:04+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-10-06T13:33:04+02:00 Closed.
2019-10-06T13:33:04+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-10-06T13:33:04+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-10-06T13:33:04+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-10-06T13:33:04+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-10-06T13:33:04+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-10-06T13:33:04+02:00 TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/TeamSpeak3-Client-linux_amd64/libQt5WebEngineCore.so.5)
2019-10-06T13:33:04+02:00 Starting instance ts3server://localhost?port=9987&nickname=test&password=&channel=&channelpassword=
2019-10-06T13:33:04+02:00 Could not insert into News-Tableno such table: News
2019-10-06T13:33:04+02:00 Could not delete from Newsno such table: News
2019-10-06T13:33:04+02:00 Could not insert into Profiles-Tableno such table: Profiles
2019-10-06T13:33:04+02:00 Could not delete from Profilesno such table: Profiles
2019-10-06T13:33:04+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-10-06T13:33:04+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-10-06T13:33:04+02:00 Could not insert into Application-Tableno such table: Application
2019-10-06T13:33:04+02:00 Could not delete from Applicationno such table: Application
2019-10-06T13:33:04+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-10-06T13:33:04+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
Diagnose script:
- Kernel: Linux 3.16.0-6-amd64 x86_64
- Load Average: 0.61 0.55 0.58
- Uptime: 0 days, 14 hours, 8 minutes, 18 seconds
- OS APT Last Update: 06.10.2019 13:00:54 CEST +02:00:00
- Shell Locale: de_DE.UTF-8
CPU(s): 4
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Model name: Common KVM processor
CPU MHz: 2199.998
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 8.53 GB/23.59 GB in use (36%)
- SWAP: 0 B/511.99 MB in use (0%)
- DISK: 3.50 GB/9.16 GB in use (38%)
- libglib: 2.42.1-1+b1
- Status: running (PIDs: 1480 1479, User: sinusbot)
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.3.0)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.09.28)
linux-vdso.so.1 (0x00007ffd57bf4000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f4cdc606000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f4cdc2ae000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f4cdbead000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f4cdb548000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f4cdb2d4000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f4cdb0d0000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f4cdadcf000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f4cdabb2000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f4cda8a7000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f4cda691000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f4cda2e6000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f4cda0cb000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f4cd9ec3000)
/lib64/ld-linux-x86-64.so.2 (0x00007f4cdc820000)
- Time (local): 06.10.2019 13:35:55 CEST +02:00:00
- Time (remote): 06.10.2019 13:35:55 CEST +02:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.09.28
[/CODE]
[2019-10-06 13:35:57] [DEBUG] Done.
Das ist soweit nicht richtig. Deine Kernel Version ist zu alt für TS 3.3.x, siehe hier.
Die Suche hätte dir auch die Lösung in dutzenden Topics ausgespuckt, leider hast du auch diese nicht benutzt:
https://forum.sinusbot.com/threads/sinusbot-connected-sich-nicht-auf-dem-ts3.7375/
https://forum.sinusbot.com/threads/keine-verbindung.7265/
https://forum.sinusbot.com/threads/connect-problem.7179/
Carrot44
also auf debian 9 updaten?
Wenn du damit auch eine Kernel Version 3.17+ installierst, dann ja... grundsätzlich ist das aber nicht pauschal zu beantworten. Da du einen KVM-virtualisierten VPS hast, solltest es aber erfolgversprechend sein. Nimm aber am besten gleich Debian 10!
Carrot44
ok danke für die antwort habe nur gesagt bekommen debian 10 wäre kompliziert deswegen habe ich nie geupdatet weil ich jz debian 8 einiger massen verstehe
Carrot44
habe jetzt auf debian 10 geupdatet immer noch der gleiche Fehler :/
Lightning
Tier I
Was sagt denn uname -a in der Putty konsole? Sollte der Kernel weiterhin kleiner als 3.17 sein, liegt der Fehler daran.
