Solved TSClient Quit
Bedbug
Hello, I have bought this bug up before, but it hasn't been fixed since I have, I uninstalled your software before but recently tried to re-install it until I encountered yet the same bug.
My current config.ini is this:
LogLevel = 10EnableProfiler = false
MTU = 1500
SampleInterval = 100
LicenseKey = "UIJL+u62Bk2L8+En0uEeII7aBF+LM714g+DOijdUVTc="
EnableAloneMode = false
The browser I am using to play the music is Google Chrome, I have not tried any other browsers since the bug appeared.
Here is a copy and paste of my PC specs:
Edition: Windows 10 Home
Version: 1511
OS Build: 10586.63
Processor: AMD A4-6300 APU with Radeon(tm) HD Graphics 3.70 GHz
Installed RAM: 4.00 GB
System type: 64-Bit operating system, x64-based processor
If there's anymore information you need me to add, please let me know - hopefully you can help me with my issue.
P.S. When I didn't change any of the config.ini settings the bot worked just fine, only when I tried to play the music is when it crashed, when I changed the LogLevel = 10, this is when the bot crashed instantly when I started it up
Crank
try it this way... (EnableProfiler in a new Line)
Bedbug
Hey, I really appreciate your help :)
I did that, and the bot did start up fine and didn't crash - I managed to get it on the TeamSpeak server and it was all fine, I didn't manage to test the music though - when I now try and use the bot it opens up but doesn't open up TeamSpeak, here is what I copied and pasted from the console, it just stays on this and doesn't do anything:
Version: 0.9.8
2016/01/30 10:41:54 1c139a55 INFO Initializing bot://1c139a55-8f38-454a-9307-83ccfb67683f
2016/01/30 10:41:54 1c139a55 976ae8b5 INFO Loaded
2016/01/30 10:41:54 FFmpeg/avcodec v3673444; license: LGPL version 2.1 or later; 493 codecs
2016/01/30 10:41:54 FFmpeg/avformat v3673958; license: LGPL version 2.1 or later; 138 formats
2016/01/30 10:41:54 RadioStation data loaded
2016/01/30 10:41:54 Imported radio stations
Open up the web interface of the bot and push the power-button on the upper right, that should start the client again.
Bedbug
I did that and it worked just fine, but when I tried to play a radio station it loaded and as soon as the music started playing the BOT automatically just disconnects from the server, this is the disconnect message, if this helps:
<13:00:49> "TeamSpeakUser" disconnected (Requested via API.)
And this is the Instance Log from the web panel:
2016-01-30T12:59:43+00:00 Loaded
2016-01-30T12:59:53+00:00 Could not delete from Notificationsno such table: Notifications
2016-01-30T12:59:53+00:00 Could not insert into Notifications-Tableno such table: Notifications
2016-01-30T12:59:53+00:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-01-30T13:00:14+00:00 Storing configuration.
2016-01-30T13:00:49+00:00 PLAYURL [admin] http://streaming210.radionomy.com:80/IslandBeachPartywithCaptainVern OK
2016-01-30T13:00:49+00:00 New channel
2016-01-30T13:00:49+00:00 New connection status 1; Error 0
2016-01-30T13:00:49+00:00 New connection status 0; Error 1797
2016-01-30T13:00:49+00:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong or the security level of your identity is too low.
2016-01-30T13:00:49+00:00 Client-Count is now 1
2016-01-30T13:00:49+00:00 Preparing for Alone-Mode
2016-01-30T13:00:49+00:00 New connection status 2; Error 0
2016-01-30T13:00:49+00:00 New connection status 3; Error 0
2016-01-30T13:00:49+00:00 Bot got moved to channel 1
2016-01-30T13:00:49+00:00 TSClient quit.
2016-01-30T13:00:49+00:00 New connection status 4; Error 0
2016-01-30T13:00:49+00:00 Client-Count is now 6
2016-01-30T13:00:49+00:00 Bot got moved to channel 2888
2016-01-30T13:00:51+00:00 PLAYURL [admin] http://streaming210.radionomy.com:80/IslandBeachPartywithCaptainVern OK
2016-01-30T13:00:51+00:00 New channel
2016-01-30T13:00:52+00:00 Deleting channel
2016-01-30T13:00:56+00:00 Could not delete from Notificationsno such table: Notifications
2016-01-30T13:00:56+00:00 Could not insert into Notifications-Tableno such table: Notifications
2016-01-30T13:00:56+00:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&cid=2888&channelpassword=
2016-01-30T13:01:00+00:00 New connection status 1; Error 0
2016-01-30T13:01:04+00:00 New connection status 0; Error 0
2016-01-30T13:01:04+00:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong or the security level of your identity is too low.
2016-01-30T13:01:04+00:00 TSClient quit.
2016-01-30T13:01:09+00:00 STOP [admin] OK
2016-01-30T13:01:10+00:00 Deleting channel
2016-01-30T13:01:10+00:00 Channels now zero
2016-01-30T13:01:10+00:00 Done playing
And the Bot log is currently empty
