Solved TSClient Quit
KnocKs
Operating System: Ubuntu
SinusBot Version: latest
TS3 Version: latest
TSClient Quit
diagSinusbot Output:
 - Operating System: Ubuntu 16.10
 - Kernel: Linux 4.8.0-34-generic x86_64
 - Load Average: 0.14 0.37 0.38
 - Uptime: 0 days, 0 hours, 15 minutes, 59 seconds
 - OS APT Last Update: 19.01.2017 14:54:51 CET +01:00:00
  Architecture:  x86_64
  CPU(s):  2
  Thread(s) per core:  1
  Core(s) per socket:  2
  Socket(s):  1
  Model name:  Intel(R) Core(TM)2 CPU  6700  @ 2.66GHz
  CPU MHz:  2128.000
  Virtualization:  VT-x
 - RAM: 1.41 GB/3.85 GB in use (36%)
 - SWAP: 0 B/3.99 GB in use (0%)
 - DISK: 6.35 GB/641.62 GB in use (0%)
  > libglib: 2.50.0-12.50.0-1
 - Status: running (PIDs: 3153 3152 1063 996, User: root)
 - Binary: /opt/sinusbot/sinusbot (MD5 Hash: 0005c8c289b99913844c9f761dbb50e9)
 - Version: 0.9.16-10f0fad
  - Bot Plugin: 28b54596e19937601df973b709aa0667
  - TS3 Client: 28b54596e19937601df973b709aa0667
  - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.1.0.1)
  - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.01.18)
 - Report date: 19.01.2017 16:46:39 CET +01:00:00 (timezone: Europe/Rome)
 - TeamSpeak 3 Version: 3.1.0.1
 - youtube-dl Version: 2017.01.18
 - DiagScript version: 0.4.6
config.ini:
LogLevel = 3
LicenseKey = "wYFlVQdC/QLXQZBW7T+MEHOqGONC4fXwBICj+hrjZ08="
  UserAgent = "SinusBot (0.9.16-10f0fad)"
The bot is hosted in my PC so i dont use IPtables
I have installed everything today by the installer script
Sorry for my grammar but im italian
Sorry for the missing special characters but my keyboard dont have them :c
Can you provide us Logs with LogLevel 10 or more?
KnocKs
knocks@knocks-Fisso:/opt/sinusbot$ ./sinusbot
 ___ ___ _  _ _  _ ___ ___  ___ _____  BETA
/ __|_ _| \| | | | / __| _ )/ _ \_  _|
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin advertising.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin aloneMode.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin badchan.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin bookmark.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin covatar.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin dev.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin followme.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin idle.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin metadata.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin norecording.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin rememberChannel.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin showcase.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin sound.js
2017/01/19 21:38:16 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin welcometext.js
2017/01/19 21:38:16 X [MAIN] Starting up fake x-server...
2017/01/19 21:38:16 c91a7a7e  INFO  Loading instances
2017/01/19 21:38:16 c91a7a7e  INFO  Loading instance://8ccc4660-ca04-48fc-a112-0f1d315bba8f
2017/01/19 21:38:16 c91a7a7e 8ccc4660 DEBUG  Spawning instance shortly due to missing configuration file.
2017/01/19 21:38:16 c91a7a7e 8ccc4660 INFO  Initialization complete
2017/01/19 21:38:16 [GENERAL/FFMPEG ] INFO  FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/01/19 21:38:16 [GENERAL/FFMPEG ] INFO  FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2017/01/19 21:38:16 [GENERAL/YTDL  ] INFO  youtube-dl checking...
2017/01/19 21:38:16 c91a7a7e 8ccc4660 INFO  Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017/01/19 21:38:16 X [MAIN] New connection
2017/01/19 21:38:17 c91a7a7e 8ccc4660 DEBUG  TS>Could not initialize GLX
2017/01/19 21:38:17 c91a7a7e 8ccc4660 DEBUG  Closed.
2017/01/19 21:38:17 c91a7a7e 8ccc4660 INFO  TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017/01/19 21:38:17 [GENERAL/YTDL  ] INFO  youtube-dl version compatible, support enabled
2017/01/19 21:38:17 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2017/01/19 21:38:17 [GENERAL/RADIO  ] INFO  RadioStation data loaded
2017/01/19 21:38:18 [GENERAL/RADIO  ] INFO  Imported radio stations
2017/01/19 21:38:29 X [MAIN] New connection
2017/01/19 21:38:45 c91a7a7e 8ccc4660 DEBUG  Storing configuration.
TS3index.com
Licensed Partner
I think you use the new 3.1-Client (API 21) but the current Sinusbot will only work with client version <= 3.0.19.4 (API 20).
Use the following link to download the old client:
TeamSpeak3-Client-linux_amd64-3.0.19.4.run
KnocKs
Now it says this:
Library not found.
Library not found.
You need to copy the plugin from /plugins/libsoundbot_plugin.so into the plugins folder of your teamspeak client
=> In my example
cp plugin/libsoundbot_plugin.so TeamSpeak3-Client-linux_amd64/plugins/
KnocKs
=> In my example
Ok, it WORKS!!
Thanks a lot for helping me!
Qhiliqq
Licensed Partner
The server isn't online...
Read line 51 in your pastebin...
Qhiliqq
Licensed Partner
Bei TS3 Cloud supporten wir nicht weiter.
