TSClient quit.
Pokollo99
I can start the sinusbot and can login on the web interface, but when i try to start the bot it just doesn't do anything and this is all i got in my log:
2017-08-15T22:57:01+02:00 Loaded
2017-08-15T22:57:17+02:00 Could not delete from Notificationsno such table: Notifications
2017-08-15T22:57:17+02:00 Could not insert into Notifications-Tableno such table: Notifications
2017-08-15T22:57:18+02:00 Starting instance ts3server://localhost?port=9987&nickname=IndyMC%20BOT&password=&channel=&channelpassword=
2017-08-15T22:57:18+02:00 TSClient quit.
2017-08-15T22:57:26+02:00 Could not delete from Notificationsno such table: Notifications
2017-08-15T22:57:26+02:00 Could not insert into Notifications-Tableno such table: Notifications
2017-08-15T22:57:26+02:00 Starting instance ts3server://localhost?port=9987&nickname=IndyMC%20BOT&password=&channel=&channelpassword=
Someone help me please.
I'm using Ubuntu 16.04 64 bit on VPS with 4gb ram and 4 cores.
Here is my config file:
SecretKey = [218, 161, 218, 161, 115, 209, 162, 2, 87, 40, 92, 225, 193, 102, 162, 123, 241, 7, 208, 146, 67, 87, 51, 24, 134, 26, 243, 242, 124, 185, 181, 234]
LogLevel = 3
MTU = 1500
SampleInterval = 100
Pokollo99
BTW at sinusbot startup i get a message about xinit (xinit: XFree86_VT property unexpectedly has 0 items instead of 1).
how do you start the bot? And can you give us the log from the sinusbot process (you said it had something with xinit inside)
Pokollo99
I'm starting the proccess itself with this command:
xinit /opt/ts3soundboard/ts3bot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
and here's a picture of what i see when i start the proccess:
http://kephost.com/images/2017/08/15/Kepernyofelvetel888.png
BJ20
pls use ./sinusbot to start it, you using an very old start command which might be the reason of your erros.
