TSClient quit
Belvet
  • SinusBot version
  • 1.0.0-beta.3-735814e
  • TS Client and Server version
  • 3.30 / 3.9.1
  • OS (operating system)
  • Debian 9 64 Bit
  • hardware specs
  • VPS
  • 10 Core / 60 GB Ram
  • Instanz Log
  • 2019-08-04T23:57:19+02:00 Storing configuration.
    2019-08-04T23:56:58+02:00 eof from voice
    2019-08-04T23:56:58+02:00 closing channels
    2019-08-04T23:56:57+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-08-04T23:56:57+02:00 Closed.
    2019-08-04T23:56:57+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
    2019-08-04T23:56:57+02:00 Starting instance ts3server://hitrax.de?port=9987&nickname=I%20%E2%9D%A4%20Radio&password=&channel=&channelpassword=
    2019-08-04T23:56:57+02:00 About to run.
    2019-08-04T23:56:57+02:00 Prespawn.
    2019-08-04T23:56:52+02:00 closing channels
    2019-08-04T23:56:52+02:00 eof from voice
    2019-08-04T23:56:51+02:00 Closed.
    2019-08-04T23:56:51+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-08-04T23:56:51+02:00 Starting instance ts3server://hitrax.de?port=9987&nickname=I%20%E2%9D%A4%20Radio&password=&channel=&channelpassword=
    2019-08-04T23:56:51+02:00 About to run.
    2019-08-04T23:56:50+02:00 Fail from voice reader: read unix @->@: use of closed network connection
    2019-08-04T23:56:50+02:00 closing channels
    2019-08-04T23:56:50+02:00 Prespawn.
    2019-08-04T23:56:50+02:00 script command loaded
    2019-08-04T23:56:50+02:00 module registered as command
    2019-08-04T23:56:50+02:00 registered callback for event chat
    2019-08-04T23:56:50+02:00 serialized function: true
    2019-08-04T23:56:50+02:00 Auto-Starting 5339d724-8514-4dd9-b7dd-a28c4ae34aec/97aa47c8-6695-4016-a60c-377b1c0ff8be in 500 ms...
    2019-08-04T23:56:50+02:00 Initialization complete
    2019-08-04T23:56:50+02:00 executing script command
    2019-08-04T23:56:49+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-08-04T23:56:49+02:00 Closed.
    2019-08-04T23:56:49+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
    2019-08-04T23:56:49+02:00 Starting instance ts3server://hitrax.de?port=9987&nickname=I%20%E2%9D%A4%20Radio&password=&channel=&channelpassword=
    2019-08-04T23:56:49+02:00 About to run.
    2019-08-04T23:56:49+02:00 Prespawn.
    2019-08-04T23:56:49+02:00 Spawning instance shortly due to missing configuration file.
  • Config.ini
ExternalFileBase = ""
LicenseKey = "ptYZrpMUoyH+FE1m5F86T+7nBt5HQ+Bvt0Rb86OEQws="
DevMode = false
[TTS]
Enabled = false
After updating with the sinusbot installer script i get this error before that everything was fine and after reinstalling it with it same problem..
