EN TTS Locale Script
kanalumaddela
So I'm trying to get this script to work where users can use tts in multiple locales with the default locale having to be changed. The script does not load whatsoever and I've checking back and forth with the say() function and how to use it. Currently I am trying to get it to work with japanese.
registerPlugin({
    name: 'TTS Locales',
    version: '1.0',
    description: 'TTS Locales',
    author: 'kanalumaddela',
    vars: {
        locale: {
            title: 'Locale to use',
            type: 'string'
        sinusbot.on('chat', function(ev) {
             if (ev.msg.startsWith('!japanese ')) {
                  var message = ev.msg.substring(10);
                  sinusbot.say('This message is in english, ' + ev.msg.substring(10)); //debugging shit
                  sleep(5000); //debugging shit
                  sinusbot.say(message[, config.locale]);
                  sinusbot.say('This is a backup phrase to say to make sure the TTS is working'); //debugging shit
                  return;
Error in the logs
2016/08/24 23:59:16 [GENERAL/SCRIPTS] WARN   Could not load script (anonymous): Line 18:40 Unexpected token , (and 2 more errors)
Line of code causing the error
Usage according to the script api
say(text[, locale])
For some reason I can't get it to use the tts with a different locale. If I did a basic script that had
sinusbot.say('hello');
it would work
kanalumaddela
nvm figured it out. Looked at the showcase script and put
sinusbot.say(message, config.locale);
which worked. :p
