Solved Upgrade to beta TeamSpeak3
Check the installation guide in the wiki out ;)
Manius
Because it seems that in version 3.1.8 it has been corrected that it will not be bothering the bots, because now I'm squeezing all of them all up when someone writes something or something similar ... I do not know exactly what it's called ...
But I mean TeamSpeak and not SinusBot ....
Then you should maybe ask this question in the TeamSpeak Forum.
The mirrors probably don't have a download link right now because this version it not released yet.
Edit:
In this thread they say that there is no download link.
Senpai Mizu
Hello! And was someone testing a sinusbot beta? Ie 3.1.8?
yea it works.
yup they are not crashing anymore, they fixed it.
eQuin0x
Is there actually the possibility of the Bot playing music or does that not work with 3.1.8? Since I get the Problem that the SinusBot Device is unknown.
If anybody can play music with his bot, could you explain how exactly u made it happen?
The last two users in this thread confirmed that everything worked fine for them, so yes, it works.
You probably forgot to copy the plugin (wiki).
Manius
Hello! Bot works on version Version: 3.1.8 (2018-01-22 10:50:07) [Stable]
And you can do that, how to give access to some user will have access to only one bot? Because now, when I add a user, it sees all users ...
