Uploading Files Failed on web Interface
Xhavest
Hello
First off i love the bot you guys made this was exactly what i was looking for and it was not that bad setting up in a Virtual Box.
But i am having issues uploading some files. I don't know if this is because you guys are running a library database for song artist and title and saving it in a hash but all my newer CD's cannot upload to the sever. i ripped them all in window media player and they used a library to add file properties. Older CD's not a problem but anything newer then like 2013 is not uploading properly.
If Could someone please help me out it would be much appreciated to add more verity to my bot.
Xhavest
ok so i found my issues. i guess i should have looked before but the program does not accept wma files so i am in the process of converting them to mp3. if anyone else runs into this i am currently using program called BeeThink converter. it allows you to keep the tags when you convert the files as well as support batch operations. but no means is it the best but it work and its free.
As a side note when you guys do support external drive support could you add in connection of NAS drives or folders with wma support. i know their might be licensing issues as it is a proprietary format but you might get MS to let for developmental proposes.
