youtube-dl problem
Wicherek
Hello, I've spent 2 hours going through all the forums and all the solutions didn't help so I'll post my logs and everything here because im out of ideas. Everything works great, thanks for creating the bot but I can't get youtube-dl to work. Everything else works, I can manually upload stuff and I can use chat commands through TS3 but it gets stuck on downloading when I use any youtube-dl related commands and I can't clear "Download Files" in control panel, it says "error, youtube-dl not available".
Here's diagnostic scipt result:
 - Operating System: Ubuntu 14.04.4 LTS
 - Kernel: Linux 3.19.0-49-generic x86_64
 - Load Average: 0.21 0.43 0.45
 - Uptime: 56 days, 18 hours, 34 minutes, 39 seconds
 - OS APT Last Update: 07.06.2016 09:06:24 CEST +02:00:00
  Architecture:  x86_64
  CPU(s):  1
  Thread(s) per core:  1
  Core(s) per socket:  1
  Socket(s):  1
  CPU MHz:  2999.996
  Hypervisor vendor:  KVM
  Virtualization type:  full
 - RAM: 411.69 MB/993.25 MB in use (41%)
 - SWAP: 76.61 MB/508.99 MB in use (15%)
 - DISK: 3.13 GB/42.97 GB in use (7%)
  > libglib: 2.40.2-0ubuntu1
 - Status: running (PIDs: 13090 13089, User: sinusbot)
 - Binary: /home/sinusbot/sinusbot (Hash: 8b94daaaf3ffd829669e70a3c6a5843d)
 - Version: 0.9.12-58b509d
  - Bot Plugin: 2c207af25e3000543d85b5f4275ef053
  - TS3 Client: 2c207af25e3000543d85b5f4275ef053
  - TS3Path = /home/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.1)
  - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.06.03)
 - Report date: 07.06.2016 16:19:57 CEST +02:00:00 (timezone: Europe/Amsterdam)
 - TeamSpeak 3 Version: 3.0.19.1
 - youtube-dl Version: 2016.06.03
 - DiagScript version: 0.4.5
config.ini:
ListenHost = "127.0.0.1"
DataDir = "/home/sinusbot/data/"
LicenseKey = "8SNx1FJTIE2zJ1jCbRGTjwVpLnCLKrpB6Xdr4+fomxk="
  CacheStreamed = true
  UserAgent = "SinusBot (0.9.12-58b509d)"
try
sudo apt-get install python-pip
sudo pip install --upgrade youtube_dl
Wicherek
The directory '/home/sinusbot/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/sinusbot/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
/usr/local/lib/python2.7/dist-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#snimissingwarning.
  SNIMissingWarning
/usr/local/lib/python2.7/dist-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
Requirement already up-to-date: youtube-dl in /usr/local/lib/python2.7/dist-packages
after pip install
Lionpigster
I got the same problem (I can't clear "Download Files" in control panel, it says "error, youtube-dl not available".) but now it works. I got a to long message in one of the scripts (changed that) and I restarted the system completly.
After that it somehow worked.
Wicherek
Well, im an idiot then, I thought I restarted my machine after installing everything, it works now, cheers.
