Solved Youtube-DL Soundcloud not working
I have the same problem... using the youtube-dl out of sinusbot context, it works perfectly... but if i use ytdl inside sinusbot i get "no good format found" on ts3 chat or "no valid format found" on the platform
rtm516
Just as extra info when you use it outside the bot context (standalone) it downloads as mp3 but I'm sure this format will work fine.
Dooley_labs
Donor++
Bumping this. Needs to be fixed at some point please. I've been unable to add music from my desired source for months.
Dooley_labs
Donor++
Actually should have already been fixed. Are you using the latest version of YT-DL and latest release of Sinusbot?
Dooley_labs
Donor++
Windows or Linux? Not possible to get the error with SoundCloud on Linux anymore unless it's a premium song. Just tested it again today without problems on Debian 9, latest Sinusbot release and Youtube-dl release from the official site.
Dooley_labs
Donor++
What about after refreshing the page? Added songs never appear until you refresh.
lemon
!yt doesn't dowload the tracks, well, at least it doesn't store them permanently on the bot.
I've restarted the bot several times now after the update, but I restarted it once again now, and it works.. wtf?
Dooley_labs
Donor++
The command to store the song permanently is !ytdl. !yt only plays what it's told.
