1 Bot disconnected immer
Flash08YT
Edited* Der Bot connected zwar schon, aber disconnected immer für "Requested via API"
Bot log:
2019-01-18 23:20:13.609383|INFO    |              |   |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019-01-18 23:20:13.609490|INFO    |              |   |SystemInformation: Linux 3.16.0-6-amd64 #1 SMP Debian 3.16.57-2 (2018-07-14) x86_64 Binary: 64bit
2019-01-18 23:20:13.643963|ERROR   |PulseAudio    |   |failed to connect to pulse audio server -
2019-01-18 23:20:13.644349|ERROR   |PulseAudio    |   |pa_context_connect failed -
2019-01-18 23:20:13.644434|ERROR   |SoundBckndIntf|   |/opt/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2019-01-18 23:20:13.645254|INFO    |ClientUI      |   |Unable to create an Open GL context.
2019-01-18 23:20:13.645663|ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019-01-18 23:20:13.663952|INFO    |Addons        |   |Checking for addon updates...
2019-01-18 23:20:13.715160|INFO    |              |   |successfully downloaded revocation list for accounting
2019-01-18 23:20:13.722786|INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019-01-18 23:20:13.927013|INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019-01-18 23:20:13.927645|INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-01-18 23:20:13.928548|ERROR   |Query         |   |bind failed on 127.0.0.1:25639
2019-01-18 23:20:14.157091|INFO    |              |   |*** Time [MAINWINDOW]: 410
2019-01-18 23:20:14.157191|INFO    |              |   |*** Time [INIT]: 410
2019-01-18 23:20:14.157429|DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019-01-18 23:20:14.160658|INFO    |ClientUI      |   |Failed to init text to speech engine
2019-01-18 23:20:14.160753|INFO    |ClientUI      |   |Qt version: 5.6.1
2019-01-18 23:20:14.160810|INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/87bf2d85-4b1e-4969-b30d-0ec38e82e94f/2574a2e7-15f2-a499-70a0-2b36b70b6f19/settings.db
2019-01-18 23:20:14.457970|INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=Flash08YT-Bot&password=&cid=67&channelpassword=
2019-01-18 23:20:14.458496|INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2019-01-18 23:20:14.458881|INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2019-01-18 23:20:14.474453|INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019-01-18 23:20:14.479580|INFO    |ClientUI      |1  |Connect status: Connecting
2019-01-18 23:20:14.484903|DEVELOP |PktHandler    |   |Puzzle solve time: 5
2019-01-18 23:20:14.491762|INFO    |ClientUI      |1  |Connect status: Connected
2019-01-18 23:20:14.498902|INFO    |              |   |Failed to read image /opt/sinusbot/data/ts3/87bf2d85-4b1e-4969-b30d-0ec38e82e94f/2574a2e7-15f2-a499-70a0-2b36b70b6f19/cache/remote/SWGTfCs7Bmij_qoa1z8uSNtPArovnNVjr8lV0rFThGFEoEiH9WPr8ge27yCTZchH4StmfoR0VAPWpPaxbqgQvw==
2019-01-18 23:20:14.523493|INFO    |              |   |Failed to read image /opt/sinusbot/data/ts3/87bf2d85-4b1e-4969-b30d-0ec38e82e94f/2574a2e7-15f2-a499-70a0-2b36b70b6f19/cache/remote/9NG7suefcJwumott1bunRRtPJBokqcasa+0MMI8D1slMeVXHB1OYbJDkr7g7dToJrwQ6XlmKWk+oM7DQYi+VzA==
2019-01-18 23:20:14.524407|INFO    |ClientUI      |1  |Connect status: Establishing connection
- Kernel: Linux 3.16.0-6-amd64 x86_64
- Load Average: 1.08 1.46 1.54
- Uptime: 53 days, 10 hours, 17 minutes, 46 seconds
- OS APT Last Update: 19.01.2019 00:08:28 CET +01:00:00
    CPU(s):                6
    Thread(s) per core:    1
    Core(s) per socket:    6
    Socket(s):             1
    Model name:            Common KVM processor
    CPU MHz:               3393.622
    Hypervisor vendor:     KVM
    Virtualization type:   full
- RAM: 10.99 GB/14.72 GB in use (74%)
- SWAP: 52.20 MB/6.11 GB in use (0%)
- DISK: 6.92 GB/141.50 GB in use (4%)
   + libglib: 2.42.1-1+b1
- Status: running (PIDs: 23183 23182, User: sinusbot)
- Binary Info: MD5 Hash: 93b1862d5dff5160be694bdd1f636712, Perms: 777, User: sinusbot
- Version: 1.0.0-alpha.4-661f4ab
   - Bot Plugin: 0cb7720523475e509ea99d101804e5f0
   - TS3 Client: 0cb7720523475e509ea99d101804e5f0
   - LogLevel = 6
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.2.3)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.01.17)
- Installed scripts: advertising.js; AFK_Mover_(AwayMuteDeafIdle).js; alonemode.js; AntiProxy.js; AutomaticServerGroupAssigner.js; bookmark.js; command.js; CryptoCurrency_Info.js; followme.js; Minecraft_Server_Info.js; norecording.js; OKlib.js; Reconnect.js; rememberChannel.js; servergroupSwitcher.js; support-pp.js; welcome.js
- Time (local): 19.01.2019 00:24:48 CET +01:00:00
- Time (remote): 19.01.2019 00:24:48 CET +01:00:00
- TeamSpeak 3 Version: 3.2.3
- youtube-dl Version: 2019.01.17
- DiagScript Version: 0.7.1
