A manual Update Is Required
I've installed multiple OS just because of sinusbot.
First I tried it on Windows 7 (64 bit) But i get the same error
Then i tried it on Centos 6.3 (64 bit) Same ERROR
Now i've installed Ubuntu 14.04 (64 bit) Still same error
I've read all the forums regarding that error. I've update the time as well but issue is not resolved. I posted my logs of Centos 6.3 (64bit) On the post was moved to auto installer script because of which i installed ubuntu but the error still persist.
Here are all the logs
root@Server:/opt/sinusbot# ./sinusbot -RunningAsRootIsEvilAndIKnowThat
2017/04/28 14:36:00 [GENERAL/!!!!!!!] WARN   !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
Version: 0.9.18-8499d2c
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin sound.js
2017/04/28 14:36:00 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2017/04/28 14:36:00 X [MAIN] Starting up fake x-server...
a manual update is required
Diagnose Script
 - Operating System: Ubuntu 16.04.2 LTS
 - Kernel: Linux 4.4.0-62-generic x86_64
 - Load Average: 1.11 1.19 1.09
 - Uptime: 0 days, 18 hours, 51 minutes, 28 seconds
 - OS Updates: 7 (updates available!)
 - OS APT Last Update: 28.04.2017 14:32:00 PKT +05:00:00
 - HTTPS check with IPv4 mode: FAILED  [Failed establishing connection to sinusbot.com]
    CPU(s):                8
    Thread(s) per core:    1
    Core(s) per socket:    2
    Socket(s):             4
    Model name:            Intel(R) Xeon(R) CPU           E5450  @ 3.00GHz
    CPU MHz:               2992.500
    Hypervisor vendor:     VMware
    Virtualization type:   full
 - RAM: 118.02 MB/487.43 MB in use (24%)
 - SWAP: 8.42 MB/508.99 MB in use (1%)
 - DISK: 1.80 GB/11.60 GB in use (15%)
   > libglib: 2.48.2-0ubuntu1
 - Binary: /opt/sinusbot/sinusbot (MD5 Hash: aa67b784b83f5a7e66c60496f58d4a92)
 - Version: 0.9.18-8499d2c
   - Bot Plugin: d53693319c8922b95257ad4c6eacff69
   - TS3 Client: d53693319c8922b95257ad4c6eacff69
   - YoutubeDLPath = not set
 - Report date: 28.04.2017 14:37:00 PKT +05:00:00 (timezone: Asia/Karachi)
 - youtube-dl Version: unknown
 - DiagScript version: 0.5.1
Seeing PKT as your Timezone, I fear that your provider has been blocked on CF for spamming. Could you try using another service provider (maybe another hosting company for your bot)?
I'm not going to remove the ban anytime soon as about 95% of all spam was coming from that provider - sorry.
Is there anyother solution? Because i work in this ISP and in an ISP there is no other service.
I also have the same ip address but i am being able to access the website and use forum as well.
Lynxaa
To prevent making another post with the same context, I'll post here.
 - Operating System: Ubuntu 16.10 (OpenVZ)
 - Kernel: Linux 2.6.32-042stab120.16 x86_64
 - Load Average: 0.00 0.03 0.04
 - Uptime: 0 days, 0 hours, 13 minutes, 53 seconds
 - OS APT Last Update: 30.04.2017 07:21:26 UTC +00:00:00
 - RAM:  B/4.00 GB in use (%)
 - SWAP:  B/ B in use (%)
 - DISK: 969.60 MB/39.72 GB in use (2%)
   > libglib: 2.50.2-2ubuntu1
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.04.28)
 - Report date: 30.04.2017 07:33:51 UTC +00:00:00 (timezone: Etc/UTC)
 - youtube-dl Version: 2017.04.28
