Dawnbringer
Hello!
My bot does not start, here is the diagnostic.
When I try to start the bot:
Instance log
Bot log
Can anyone help me please?
- Operating System: Debian GNU/Linux 9.9 (stretch)
- Kernel: Linux 4.9.0-7-amd64 x86_64
- Load Average: 0.42 0.48 0.46
- Uptime: 148 days, 18 hours, 57 minutes, 12 seconds
- OS APT Last Update: 24.07.2019 12:29:36 UTC +00:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2650 v4 @ 2.20GHz
CPU MHz: 2199.998
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 1.50 GB/1.95 GB in use (76%)
- DISK: 8.97 GB/49.18 GB in use (18%)
- libglib: 2.50.3-2
- Status: running (PIDs: 12954 12953, User: sinusbot)
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.3.0)
- YoutubeDLPath = not set
linux-vdso.so.1 (0x00007fff47b32000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f8cf3a06000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f8cf36ae000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f8cf32ad000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f8cf2948000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f8cf26d4000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f8cf24d0000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f8cf21cc000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f8cf1faf000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f8cf1c2d000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f8cf1a16000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f8cf1677000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f8cf145d000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f8cf1255000)
/lib64/ld-linux-x86-64.so.2 (0x00007f8cf3c20000)
- Time (local): 24.07.2019 13:31:32 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: unknown
Instance log
2019-07-24T15:29:28+02:00 Storing configuration.
2019-07-24T15:29:27+02:00 eof from data
2019-07-24T15:29:27+02:00 closing channels
2019-07-24T15:29:27+02:00 eof from voice
2019-07-24T15:29:26+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-24T15:29:26+02:00 Closed.
2019-07-24T15:29:26+02:00 TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libpci.so.3: cannot open shared object file: No such file or directory
2019-07-24T15:29:26+02:00 Starting instance ts3server://142.93.99.241?port=9987&nickname=%5BBOT%5D%20Commander&password=swg12&channel=&channelpassword=
2019-07-24T15:29:26+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-07-24T15:29:26+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-07-24T15:29:26+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-07-24T15:29:26+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-07-24T15:29:26+02:00 Could not create Chat-Tabletable Chat already exists
2019-07-24T15:29:26+02:00 About to run.
2019-07-24T15:29:26+02:00 Prespawn.
Bot log
2019-07-24T15:20:58+02:00 Loading instance://f0a0716e-df37-4e83-8fea-2e8aabb5fda9
2019-07-24T15:20:58+02:00 Loading instances
