BOT DOESNT WANT TO CONNECT ON TS3 SERVERS! HELP PLS!
2022-11-21T18:05:29+01:00 Could not create Notifications-Tabletable Notifications already exists
2022-11-21T18:05:29+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2022-11-21T18:05:29+01:00 Could not create Chat-Tabletable Chat already exists
2022-11-21T18:03:20+01:00 TSClient quit.
2022-11-21T18:03:19+01:00 New connection status 0; Error 1797
2022-11-21T18:03:19+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2022-11-21T18:03:19+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2022-11-21T18:03:19+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2022-11-21T18:03:14+01:00 TS |INFO | | |Statistics report: Not yet, next report on Sun Nov 27 16:17:54 2022
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI | |Last update check was: Mon Jan 1 00:00:01 2035
2022-11-21T18:03:14+01:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2022-11-21T18:03:14+01:00 New connection status 1; Error 0
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI |1 |Initiating connection: 89.40.104.53:9987
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI |1 |Connect to server: 89.40.104.53
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI | |ts3server: 89.40.104.53?port=9987&nickname=hero%20is%20hero&password=&channel=&channelpassword=
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/07e7041f-a18a-4a3c-b0de-c17705f1c774/0d6c0575-5c44-4dd9-9fcc-24d30794605d/settings.db
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI | |Qt version: 5.12.1
2022-11-21T18:03:14+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2022-11-21T18:03:14+01:00 TS |INFO | | |*** Time [INIT]: 132
2022-11-21T18:03:14+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 132
2022-11-21T18:03:14+01:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2022-11-21T18:03:14+01:00 TS |INFO | | |successfully downloaded revocation list for accounting
2022-11-21T18:03:14+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2022-11-21T18:03:14+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2022-11-21T18:03:14+01:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2022-11-21T18:03:14+01:00 TS |INFO |Addons | |Checking for addon updates...
2022-11-21T18:03:13+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2022-11-21T18:03:13+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2022-11-21T18:03:13+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2022-11-21T18:03:13+01:00 TS |INFO | | |Using hardware aes
2022-11-21T18:03:13+01:00 TS |INFO | | |SystemInformation: Linux 5.11.22-5-pve #1 SMP PVE 5.11.22-10 (Tue, 28 Sep 2021 08:15:41 +0200) x86_64 Binary: 64bit
2022-11-21T18:03:13+01:00 TS |INFO | | |TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
2022-11-21T18:03:13+01:00 Starting instance ts3server://89.40.104.53?port=9987&nickname=hero%20is%20hero&password=&channel=&channelpassword=
2022-11-21T18:03:13+01:00 Could not create Notifications-Tabletable Notifications already exists
Lala Sabathil
No need to scream in the title.
Furthermore any possible error is written in the log you showed. Try figuring it out yourself first. And search the forum.
