itsphill
Hi, I restored a backup of my teamspeak server and I have installed the sinusbot but when I am going to start the bot my server teamspeak crashes and the bot doesn't go on..
how I can resolve it?
2019-04-24T17:59:04+02:00 TSClient quit.
2019-04-24T17:59:03+02:00 New connection status 0; Error 1797
2019-04-24T17:59:03+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2019-04-24T17:59:03+02:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2019-04-24T17:59:03+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2019-04-24T17:58:52+02:00 TS |INFO | | |Statistics report: Setting next report date to: Wed May 1 15:58:52 2019
2019-04-24T17:58:52+02:00 TS |INFO | | |Statistics report: First run, report later in 1-30 days
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019-04-24T17:58:52+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-04-24T17:58:52+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2019-04-24T17:58:52+02:00 New connection status 1; Error 0
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2019-04-24T17:58:52+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI |1 |Initiating connection: 185.CEN.SU.RED
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI |1 |Connect to server: 185.CEN.SU.RED
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI | |ts3server: 185.CEN.SU.RED?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/6acfcc38-794d-4751-9806-0005117cedc5/e2c67684-b4ac-4360-9c23-af77f190c0f2/settings.db
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-04-24T17:58:52+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2019-04-24T17:58:52+02:00 TS |INFO | | |*** Time [INIT]: 444
2019-04-24T17:58:52+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 444
2019-04-24T17:58:52+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2019-04-24T17:58:52+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-04-24T17:58:52+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-04-24T17:58:52+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-04-24T17:58:52+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-04-24T17:58:52+02:00 TS |INFO |Addons | |Checking for addon updates...
2019-04-24T17:58:52+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-04-24T17:58:52+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-04-24T17:58:52+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-04-24T17:58:52+02:00 TS |INFO | | |Using hardware aes
2019-04-24T17:58:52+02:00 TS |INFO | | |SystemInformation: Linux 4.15.0 #1 SMP Thu Feb 21 17:35:43 MSK 2019 x86_64 Binary: 64bit
2019-04-24T17:58:52+02:00 TS |INFO | | |TeamSpeak 3 Client 3.2.5 (2019-04-17 16:07:33)
2019-04-24T17:58:51+02:00 Starting instance ts3server://185.CEN.SU.RED?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-04-24T17:58:46+02:00 BOT-CONFIG [admin] NAME HOST CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
