Bug Bot möchte keine Streams mehr spielen "Could not stream..."
BlackNebulaR
nachdem ich meinen Server neu gestartet habe (die Bots habe ich vorher gestoppt und den Prozess gekillt) funktioniert das Streaming von Internet Radio nicht mehr. Es endet mit der Fehlermeldung: "Could not stream..."
2015-09-18 18:45:58.763057|INFO    |ClientUI      |  1| Initiating connection: 127.0.0.1:9987 127.0.0.1
2015-09-18 18:45:58.767366|WARNING |TSDNS         |   |  getaddrinfo error: Temporary failure in name resolution
2015-09-18 18:45:58.814314|INFO    |PreProSpeex   |  1| Speex version: 1.2rc1
2015-09-18 18:45:58.831790|DEVELOP |PktHandler    |   | Puzzle solve time: 4
2015-09-18 18:45:58.851159|INFO    |ClientUI      |  1| Connect status: Connecting
2015-09-18 18:45:58.851251|INFO    |ClientUI      |  1| Connect status: Connected
2015-09-18 18:45:59.020837|INFO    |ClientUI      |  1| Connect status: Establishing connection
2015-09-18 18:45:59.059012|INFO    |ClientUI      |  1| Connect status: Connection established
2015-09-18 18:45:59.062382|INFO    |PermManager   |   | Loading permissions from cache
2015-09-18 18:45:59.531284|INFO    |ClientUI      |   | Last update check was: Sun Jan 1 00:00:01 2017
2015/09/18 18:45:59 03cb1074 9fb24709 DEBUG  Could not delete from Notificationsno such table: Notifications
2015/09/18 18:45:59 03cb1074 9fb24709 DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2015/09/18 18:45:59 03cb1074 9fb24709 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=MusicBox%20%5BTechnoBase.FM%5D&password=&cid=229&channelpassword=
2015-09-18 18:45:59.816185|INFO    |              |   | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-09-18 18:45:59.816292|INFO    |              |   | SystemInformation: Linux 2.6.32-042stab103.6 #1 SMP Wed Jan 21 13:07:39 MSK 2015 x86_64 Binary: 64bit
2015-09-18 18:45:59.816321|INFO    |              |   | Using hardware aes
2015-09-18 18:45:59.850006|ERROR   |PulseAudio    |   | failed to connect to pulse audio server
2015-09-18 18:45:59.850339|ERROR   |PulseAudio    |   | pa_context_connect failed
2015-09-18 18:45:59.850427|ERROR   |SoundBckndIntf|   | /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2015-09-18 18:45:59.892038|INFO    |              |   | Loading plugin: libappscanner_plugin
2015-09-18 18:45:59.892777|INFO    |              |   | Loading plugin: libclientquery_plugin
2015-09-18 18:45:59.893029|INFO    |              |   | Loading plugin: liblua_plugin
2015-09-18 18:45:59.893062|INFO    |              |   | Loading plugin: libsoundbot_plugin
2015-09-18 18:45:59.893995|INFO    |              |   | Loading plugin: libtest_plugin
2015-09-18 18:45:59.899381|ERROR   |Query         |   | bind failed on 127.0.0.1:25639
2015-09-18 18:46:00.113052|INFO    |              |   | *** Time [MAINWINDOW]: 113
2015-09-18 18:46:00.113809|INFO    |              |   | *** Time [INIT]: 113
2015-09-18 18:46:00.122683|INFO    |ClientUI      |   | Failed to init text to speech engine
2015-09-18 18:46:00.124361|INFO    |ClientUI      |   | Qt version: 5.2.1
2015-09-18 18:46:00.124436|INFO    |ClientUI      |   | Using configuration location: /opt/ts3soundboard/data/ts3/03cb1074-5b8b-45e9-a237-5075cffb63b4/9fb24709-4128-4479-915a-db3ca868d7d9/settings.db
2015-09-18 18:46:00.414224|INFO    |ClientUI      |   | ts3server: 127.0.0.1?port=9987&nickname=MusicBox%20%5BTechnoBase.FM%5D&password=&cid=229&channelpassword=
2015-09-18 18:46:00.414718|INFO    |ClientUI      |  1| Connect to server: 127.0.0.1
2015-09-18 18:46:00.415612|INFO    |ClientUI      |  1| Blacklist check ok
2015-09-18 18:46:00.415674|INFO    |ClientUI      |  1| Initiating connection: 127.0.0.1:9987 127.0.0.1
2015-09-18 18:46:00.419256|WARNING |TSDNS         |   |  getaddrinfo error: Temporary failure in name resolution
2015-09-18 18:46:00.491237|INFO    |PreProSpeex   |  1| Speex version: 1.2rc1
2015-09-18 18:46:00.507814|DEVELOP |PktHandler    |   | Puzzle solve time: 3
2015-09-18 18:46:00.588599|INFO    |ClientUI      |  1| Connect status: Connecting
2015-09-18 18:46:00.588694|INFO    |ClientUI      |  1| Connect status: Connected
2015-09-18 18:46:00.932982|INFO    |ClientUI      |  1| Connect status: Establishing connection
2015-09-18 18:46:00.970324|INFO    |ClientUI      |  1| Connect status: Connection established
2015-09-18 18:46:00.976700|INFO    |PermManager   |   | Loading permissions from cache
2015-09-18 18:46:01.320828|INFO    |ClientUI      |   | Last update check was: Sun Jan 1 00:00:01 2017
2015/09/18 18:46:14 03cb1074 7749f493 DEBUG  Storing configuration.
2015/09/18 18:46:14 03cb1074 9fb24709 DEBUG  Storing configuration.
2015/09/18 18:48:03 03cb1074 7749f493 INFO   PLAYURL [admin] http://mp3.stream.tb-group.fm:80/ht.mp3 NOK
2015/09/18 18:52:01 03cb1074 7749f493 INFO   PLAYURL [admin] http://mp3.stream.tb-group.fm:80/ht.mp3 NOK
2015/09/18 18:52:12 03cb1074 7749f493 INFO   PLAYURL [admin] http://mp3.stream.tb-group.fm:80/ht.mp3 NOK
Außerdem stürzt der Stream am Tag oft ab, sodass ich ihn neu starten muss. :(
Ich verwende die Version 0.9.8 für Debian.
Grüße @BlackNeb
BlackNebulaR
Ok noch ein paar mehr Daten:
Version: 0.9.8
Betriebssystem: Debian 8.0
Hardware: CPU (unbekannt), RAM 512 MB
Verwendeter Browser: MS Edge
Freier Speicher: RAM 418.43 MB frei, HDD 39.36 GB frei
config.ini:
SecretKey = [131, 66, 152, 197, 213, 76, 200, 139, 143, 92, 245, 172, 82, 49, 118, 74, 236, 30, 208, 81, 50, 79, 223, 138, 161, 4, 35, 1, 75, 62, 38, 49]
MTU = 1500
SampleInterval = 100
Hier der Instanz-Log:
2015-09-19T00:43:14+02:00 Loaded
2015-09-19T00:43:16+02:00 Last track was 4bba2ae4-9770-46de-91d0-7bde0b330372, will auto-play soon
2015-09-19T00:43:16+02:00 Could not delete from Notificationsno such table: Notifications
2015-09-19T00:43:16+02:00 Could not insert into Notifications-Tableno such table: Notifications
2015-09-19T00:43:17+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=MusicBox%20%5BHouseTime.FM%5D&password=&cid=127&channelpassword=
2015-09-19T00:43:21+02:00 Auto-Playing last track
2015-09-19T00:43:44+02:00 Storing configuration.
2015-09-19T00:44:54+02:00 KILL [admin] OK
2015-09-19T00:44:54+02:00 TSClient quit.
2015-09-19T00:45:14+02:00 Storing configuration.
2015-09-19T00:45:57+02:00 Could not delete from Notificationsno such table: Notifications
2015-09-19T00:45:57+02:00 Could not insert into Notifications-Tableno such table: Notifications
2015-09-19T00:45:57+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=MusicBox%20%5BHouseTime.FM%5D&password=&cid=127&channelpassword=
2015-09-19T00:46:14+02:00 Storing configuration.
2015-09-19T00:48:03+02:00 PLAYURL [admin] http://mp3.stream.tb-group.fm:80/ht.mp3 NOK
2015-09-19T00:52:01+02:00 PLAYURL [admin] http://mp3.stream.tb-group.fm:80/ht.mp3 NOK
2015-09-19T00:52:12+02:00 PLAYURL [admin] http://mp3.stream.tb-group.fm:80/ht.mp3 NOK
2015-09-19T01:06:06+02:00 Bot got moved to channel 228
2015-09-19T01:06:17+02:00 KILL [admin] OK
2015-09-19T01:06:17+02:00 TSClient quit.
BlackNebulaR
/etc/resolv.conf:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
Service bind9 Status:
root@BlackNebulaR:/dev/pts# service bind9 status
● bind9.service - LSB: Start and stop bind9
   Loaded: loaded (/etc/init.d/bind9)
  Drop-In: /run/systemd/generator/bind9.service.d
           └─50-insserv.conf-$named.conf
   Active: inactive (dead)
BlackNebulaR
        up route add default dev venet0
        down route del default dev venet0
        down ifconfig venet0 down
iface venet0 inet6 manual
        up route -A inet6 add default dev venet0
        down route -A inet6 del default dev venet0
auto venet0:0
iface venet0:0 inet static
        address 84.200.204.36
        netmask 255.255.255.255
Dann ändere das ganze mal ab:
in:
dns-nameservers 8.8.8.8 8.8.4.4
und dann
service networking restart
ACHTUNG: Ich sehe bei dir kein Gateway konfiguriert, ich weiß nicht bei welchem Provider du bist. Prüfe bitte ob du nen Rescue System / KVM / Virtuall KVM zur verfügung hast falls du dir an der Netzwerkconfig was zerschießt.
Wenn du die Name Server eingetragen hast: 8.8.8.8 8.8.4.4 sind die Google Public DNS Server kannst du das ganze prüfen:
 nslookup google.de
Wenn der Befehl nslookup nicht gefunden wird musst du dir die dnsutils noch installieren:
apt-get install dnsutils
