Bot not connecting
Idler
Version: 0.9.9-a897ff9
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2015/09/15 19:21:37 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2015/09/15 19:21:37 82636e20 INFO Initializing bot://82636e20-07b4-4c65-b9f2-b24dd41c1ebb
2015/09/15 19:21:37 X [MAIN] Starting up fake x-server...
2015/09/15 19:21:37 x [MAIN] ERROR: listen unix /tmp/.X11-unix/X40: bind: address already in use
bot@arthursts3:/opt/ts3bot$ screen
38.151.4:9987
2015-09-15 19:22:57.180060|INFO |ClientUI | 1| Blacklist check ok
2015-09-15 19:22:57.180779|INFO |ClientUI | 1| Initiating connection: 185.38.151.4:9987 ts.grandtheftaltis.co.uk
2015-09-15 19:22:57.585024|INFO |PreProSpeex | 1| Speex version: 1.2rc1
2015-09-15 19:22:57.596405|INFO |ClientUI | 1| Connect status: Connecting
2015-09-15 19:22:57.599639|INFO |ClientUI | | Last update check was: Sun Jan 1 00:00:01 2017
2015-09-15 19:22:57.609805|DEVELOP |PktHandler | | Puzzle solve time: 4
2015-09-15 19:22:57.630117|INFO |ClientUI | 1| Connect status: Disconnected
2015-09-15 19:22:57.630260|INFO |ClientUI | 1| Disconnected or forced to leave, want autoreconnect = 0
2015/09/15 19:22:58 82636e20 369c4564 INFO New connection status 1; Error 0
2015/09/15 19:22:58 82636e20 369c4564 INFO The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong or the security level of your identity is too low.
2015/09/15 19:22:58 82636e20 369c4564 INFO New connection status 0; Error 0
2015/09/15 19:22:58 82636e20 369c4564 INFO TSClient quit.
2015/09/15 19:22:58 X [MAIN] Disconnected: 3
2015/09/15 19:22:58 X [MAIN] Disconnected: 2
The identity isn't too low and the bot isn't banned.
I heard this could also happen if a default channel has been configured but is now passworded.
The log seems to be broken around the middle. What happened there?
Did you already fix that? Remove that file as root if you haven't already. :)
