2019/08/31 00:05:04 c90c8ccf INFO Loading instances
2019/08/31 00:05:04 c90c8ccf INFO Loading instance://9e570d83-dda8-4a69-8007-ab21849e2e61
2019/08/31 00:05:04 c90c8ccf 9e570d83 INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/08/31 00:05:04 c90c8ccf 9e570d83 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/08/31 00:05:04 c90c8ccf 9e570d83 DEBUG executing script command
2019/08/31 00:05:04 c90c8ccf 9e570d83 INFO Initialization complete
2019/08/31 00:05:04 c90c8ccf 9e570d83 INFO Auto-Starting c90c8ccf-2a7a-40b4-a5db-0cc56e59cd3a/9e570d83-dda8-4a69-8007-ab21849e2e61 in 500 ms...
2019/08/31 00:05:04 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/08/31 00:05:04 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/08/31 00:05:04 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://ts.balkankings.org:8087
2019/08/31 00:05:04 c90c8ccf 9e570d83 DEBUG serialized function: true
2019/08/31 00:05:04 c90c8ccf 9e570d83 DEBUG registered callback for event chat
2019/08/31 00:05:04 c90c8ccf 9e570d83 DEBUG module registered as command
2019/08/31 00:05:04 c90c8ccf 9e570d83 INFO script command loaded
2019/08/31 00:05:04 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/08/31 00:05:04 [GENERAL/RADIO ] INFO Imported radio stations
2019/08/31 00:05:04 c90c8ccf 9e570d83 DEBUG Prespawn.
2019/08/31 00:05:05 c90c8ccf 9e570d83 DEBUG closing channels
2019/08/31 00:05:05 c90c8ccf 9e570d83 WARN Fail from data reader: read unix @->@: use of closed network connection
2019/08/31 00:05:05 read unix @->@: use of closed network connection . 138
. 574
. 514
. 489
. 602
. 2197
2019/08/31 00:05:05 c90c8ccf 9e570d83 DEBUG About to run.
2019/08/31 00:05:05 c90c8ccf 9e570d83 INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/08/31 00:05:05 c90c8ccf 9e570d83 WARN Fail from voice reader: read unix @->@: use of closed network connection
. 508
. 514
. 489
. 532
. 2197
2019/08/31 00:05:05 c90c8ccf 9e570d83 DEBUG TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libXcomposite.so.1: cannot open shared object file: No such file or directory
2019/08/31 00:05:05 c90c8ccf 9e570d83 DEBUG Closed.
2019/08/31 00:05:05 c90c8ccf 9e570d83 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/08/31 00:05:06 c90c8ccf 9e570d83 DEBUG closing channels
2019/08/31 00:05:34 c90c8ccf 9e570d83 DEBUG Storing configuration.
. 574
. 514
. 489
. 602
. 2197
. 508
. 514
. 489
. 532
. 2197
