Operating System: Windows / Linux
SinusBot Version: 0.9.20-a9b8dc6
TS3 Version: 3.0.18.2
Hello guys when i try to connect my bot at my server
https://hastebin.com/atovijuxac.sql
this don't worked
" The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help."
i try many solution downgrade TS3client but this don't worked you can saw my version
this don't worked
2017/06/25 00:28:28 01b07a02 6865b3d0 DEBUG Prespawn.
2017/06/25 00:28:28 01b07a02 6865b3d0 DEBUG About to run.
2017/06/25 00:28:28 01b07a02 6865b3d0 WARN Could not create Chat-Tabletable Chat already exists
2017/06/25 00:28:28 01b07a02 6865b3d0 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017/06/25 00:28:28 01b07a02 6865b3d0 WARN Could not create Notifications-Tabletable Notifications already exists
2017/06/25 00:28:28 01b07a02 6865b3d0 DEBUG Could not delete from FileTransferno such table: FileTransfer
2017/06/25 00:28:28 01b07a02 6865b3d0 DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO Starting instance ts3server://guiltz.Fr?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017/06/25 00:28:28 X [MAIN] New connection
2017/06/25 00:28:28 01b07a02 6865b3d0 DEBUG TS>Crashdump ENABLED, directory is: /home/bot/bot/data/ts3/01b07a02-05ac-4bcd-9103-aa196b24120d/6865b3d0-1c51-4e17-bc2c-b45e31f5f7c4/crashdumps
2017/06/25 00:28:28 01b07a02 6865b3d0 DEBUG TS>DUMP defined! Dumpdir is: /home/bot/bot/data/ts3/01b07a02-05ac-4bcd-9103-aa196b24120d/6865b3d0-1c51-4e17-bc2c-b45e31f5f7c4/crashdumps
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2 (2017-04-30) x86_64 Binary: 64bit
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO | | |Using hardware aes
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO | | |Loading plugin: liblua_plugin
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO | | |Loading plugin: libtest_plugin
2017/06/25 00:28:28 01b07a02 6865b3d0 INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2017/06/25 00:28:29 X [MAIN] New connection
2017/06/25 00:28:29 01b07a02 6865b3d0 DEBUG TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |ClientUI | |Qt version: 5.5.0
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |ClientUI | |Using configuration location: /home/bot/bot/data/ts3/01b07a02-05ac-4bcd-9103-aa196b24120d/6865b3d0-1c51-4e17-bc2c-b45e31f5f7c4/settings.db
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |ClientUI | |ts3server: guiltz.Fr?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Connect to server: guiltz.Fr
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Trying to resolve guiltz.Fr
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.guiltz.fr"
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |TSDNS | |DNS resolve successful, "guiltz.fr"=151.80.37.79
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO |ClientUI | |Last update check was: mar. janv. 1 00:00:01 2019
2017/06/25 00:28:29 01b07a02 6865b3d0 INFO TS |INFO | | |Statistics report: Not yet, next report on mar. juil. 18 23:48:45 2017
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Lookup finished: 151.80.37.79 9987 guiltz.fr 0 0
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Resolve successful: 151.80.37.79:9987
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Blacklist check ok
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Initiating connection: 151.80.37.79:9987 guiltz.Fr
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO New connection status 1; Error 0
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |WARNING |ClientUI | |Blacklist check error: 7
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |WARNING |ClientUI | |Failed to write to blacklist server: Unable to send a message
2017/06/25 00:28:33 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2017/06/25 00:28:36 01b07a02 6865b3d0 DEBUG Storing configuration.
2017/06/25 00:28:39 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2017/06/25 00:28:39 01b07a02 6865b3d0 INFO TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2017/06/25 00:28:39 01b07a02 6865b3d0 INFO The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017/06/25 00:28:39 01b07a02 6865b3d0 INFO New connection status 0; Error 1797
2017/06/25 00:28:40 01b07a02 6865b3d0 DEBUG TS>libpng warning: iCCP: known incorrect sRGB profile
2017/06/25 00:28:40 01b07a02 6865b3d0 DEBUG TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2017/06/25 00:28:40 01b07a02 6865b3d0 DEBUG Closed.
2017/06/25 00:28:40 01b07a02 6865b3d0 INFO TSClient quit.
