Solved Bot startet nicht mehr (A manual update is required)
OTD
Bash:
Version: 1.0.0-beta.8-9e95ca7
Using Logfile /home/***/SinusBot/SinusBot-Logdatei.log
a manual update is required
Bot startet nicht mehr :confused:
Nach einem Serverneustart heut morgen, verweigert er den start ☹
Da es aber keine neuere Version gibt, ist die Meldung nicht sehr aufschlussreich.
Bash:
[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] ================================================
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] = [1mHELLO![0m  Having an issue? I'm here to assist! =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =                                              =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  Thanks for  using  this diagnostic script!  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  The more  information  you   provide,  the  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  better we  can help to solve your problem.  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  The execution  may  take  some  moments to  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  collection the most  important information  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  of your system and  your bot installation.  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  After everything  is  done, you will get a  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  summarized output ready to copy & paste it  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  within a CODE-tag  in  the SinusBot forum.  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  [Link: https://forum.sinusbot.com]          =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  This script uses DNS resolutions and HTTPS  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  requests  to  Sinusbot-related  domains to  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =  check  if your network settings are valid.  =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] ================================================
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] = Please also report any feedback or issues    =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] = related to the script in the official forum. =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] = Thank you and happy debugging!               =
[0m[40m[2019-12-30 15:05:36] [[0;32mWELCOME[0;37m] =   -- Patrik Kernstock aka. Patschi.          =
[0m
[40m[2019-12-30 15:05:36] [[0;32mWAIT[0;37m] Press [ENTER] to continue...[0m
[40m[2019-12-30 15:05:43] [[0;36mINFO[0;37m] Starting diagSinusbot v0.8.0 [2019-06-16 00:01 UTC]...
[0m[40m[2019-12-30 15:05:43] [[0;36mINFO[0;37m] Checking for new diagnostic script version...
[0m[40m[2019-12-30 15:05:43] [[0;32mOKAY[0;37m] You are using the latest version.
[0m[40m[2019-12-30 15:05:43] [[0;36mINFO[0;37m] Detected operating system: Debian GNU/Linux 10 (buster)
[0m[40m[2019-12-30 15:05:43] [[0;36mINFO[0;37m] Searching bot binary...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Searching in directory '/root'...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Searching in directory '/opt/sinusbot/'...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Searching in directory '/opt/ts3bot/'...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Searching in directory '/opt/ts3soundboard/'...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Searching in directory '/home/sinusbot/'...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Searching in directory '/home/sinusbot/sinusbot/'...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Searching in directory '/home/***/SinusBot'...
[0m[40m[2019-12-30 15:05:43] [[0;35mDEBUG[0;37m] Binary 'sinusbot' found.
[0m[40m[2019-12-30 15:05:43] [[0;36mINFO[0;37m] Binary found.
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Collecting information...
[0m[40m[2019-12-30 15:05:44] [[0;36mINFO[0;37m] (Scan may take some moments...)
[0m[40m[2019-12-30 15:05:44] [[0;36mINFO[0;37m] Collecting system information...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Getting operating system version...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Checking DNS resolution...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Checking web IPv4 access...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Checking update server availability...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Checking for locales...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Getting processor information...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Checking for available operating system updates...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Getting RAM information...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Getting SWAP information...
[0m[40m[2019-12-30 15:05:44] [[0;35mDEBUG[0;37m] Getting DISK information...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Getting disk info by using command:
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m]  $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reiserfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk
[0m[40m[2019-12-30 15:05:45] [[0;36mINFO[0;37m] Collecting bot information...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Loading bot config file...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Determining bot status...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Getting LDD output from bot binary...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Reading ListenPort from bot configuration...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Getting installed bot scripts...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Reading LogLevel from bot configuration...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Reading TS3Path from bot configuration...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Trying to get ts3client version...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Checking installation of bot plugin in ts3client...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Checking if libqxcb-glx-integration.so file exists...
[0m[40m[2019-12-30 15:05:45] [[0;35mDEBUG[0;37m] Checking for 'youtube-dl'...
[0m[40m[2019-12-30 15:05:47] [[0;33mWARNING[0;37m] Time difference of local and remote time is greater than 30 seconds! Please update your local time using NTP or so to prevent any server or SinusBot-specific issues! A correct server time is always strongly recommended!
[0m[40m[2019-12-30 15:05:47] [[0;35mDEBUG[0;37m] Generating output...
[0m
[40m[1mPlease attach this output to your forum post:[0m
[0m
[40m[CODE]
[0m[40m==========================================================
- Kernel: Linux 4.19.0-6-amd64 x86_64
- Load Average: 0.23 0.21 0.19
- Uptime: 0 days, 12 hours, 11 minutes, 2 seconds
- OS APT Last Update: 30.12.2019 01:18:50 CET +01:00:00
- Shell Locale: de_DE.UTF-8
    Architecture:        x86_64
    CPU(s):              3
    Thread(s) per core:  1
    Core(s) per socket:  3
    Socket(s):           1
    Model name:          Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz
    CPU MHz:             3546.026
    Hypervisor vendor:   KVM
    Virtualization type: full
- RAM: 1.71 GB/3.85 GB in use (44%)
- SWAP: 1.72 GB/3.99 GB in use (43%)
- DISK: 77.98 GB/1002.98 GB in use (7%)
   - libglib: 2.58.3-2+deb10u2
- Webinterface: port locally not reachable (Port: 1800)
- Binary: /home/***/SinusBot/sinusbot
- Binary Info: MD5 Hash: 43a7695283e7688edd94790e09bbce39, Perms: 755, User: ruhrsports
- Version: 1.0.0-beta.8-9e95ca7
   - TS3Path = /home/***/SinusBot/TS3-Client/ts3client_linux_amd64 (Version 3.3.2)
   - YoutubeDLPath = not set
- Installed scripts: advertising.js; alonemode.js; Auto_Channel_Creator.js; bookmark.js; command.js; followme.js; norecording.js; rememberChannel.js; sinusbot-commands.js; welcome.js
    linux-vdso.so.1 (0x00007ffdb1f46000)
    libswresample.so.2 => /home/***/libswresample.so.2 (0x00007f97c3a9d000)
    libavfilter.so.6 => /home/***/libavfilter.so.6 (0x00007f97c3745000)
    libavformat.so.57 => /home/***/libavformat.so.57 (0x00007f97c3344000)
    libavcodec.so.57 => /home/***/libavcodec.so.57 (0x00007f97c29df000)
    libavutil.so.55 => /home/***/libavutil.so.55 (0x00007f97c276b000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f97c2756000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f97c25d1000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f97c25b0000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f97c242c000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f97c2412000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f97c2251000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f97c2033000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f97c2027000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f97c3cb9000)
- DNS resolution check: SUCCESS [www.sinusbot.com resolved to 2a01:4f8:171:84::2]
    update01.sinusbot.com -> 2a01:4f8:171:84::2: SUCCESS [CODE #404]
    update02.sinusbot.com -> 2a01:4f8:171:84::2: SUCCESS [CODE #404]
    update03.sinusbot.com -> 2a01:4f8:171:84::2: SUCCESS [CODE #404]
- Time (local): 30.12.2019 15:05:45 CET +01:00:00
- Time (remote): 30.12.2019 15:15:01 CET +01:00:00
- Time (difference): 556 secs (Time diff greater than 30 secs!)
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: unknown
[0m[40m
[0m
[40m[1mNotice[0m: For a better overview, post this data
[0m
[40m[2019-12-30 15:05:47] [[0;35mDEBUG[0;37m] Done.
[0m
Thanks for the tip. I totally missed that, sorry for that.
He is now running again :)
Thank you very much and sorry that I opened an extra contribution.
Greetings OTD
