bot starting error
itsphill
hi, i jest installed sinubot and when I start the bot it gives doesn't work
the bot log:
2019-07-24T02:43:10+02:00 closing channels
2019-07-24T02:43:10+02:00 eof from voice
2019-07-24T02:43:09+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-24T02:43:09+02:00 Closed.
2019-07-24T02:43:09+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019-07-24T02:43:09+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-24T02:43:09+02:00 About to run.
2019-07-24T02:43:09+02:00 Prespawn.
2019-07-24T02:43:07+02:00 eof from data
2019-07-24T02:43:07+02:00 closing channels
2019-07-24T02:43:07+02:00 eof from voice
2019-07-24T02:43:06+02:00 Closed.
2019-07-24T02:43:06+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-24T02:43:06+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019-07-24T02:43:06+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-24T02:43:06+02:00 About to run.
2019-07-24T02:43:06+02:00 Prespawn.
2019-07-24T02:42:30+02:00 Storing configuration.
2019-07-24T02:42:17+02:00 closing channels
2019-07-24T02:42:17+02:00 eof from voice
2019-07-24T02:42:16+02:00 Closed.
2019-07-24T02:42:16+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-24T02:42:16+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019-07-24T02:42:16+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-24T02:42:16+02:00 About to run.
2019-07-24T02:42:16+02:00 Prespawn.
2019-07-24T02:42:01+02:00 Fail from voice reader: read unix @->@: use of closed network connection
2019-07-24T02:42:01+02:00 Could not prepare listeners: file file+net server: setnonblock: bad file descriptor
2019-07-24T02:42:01+02:00 Fail from data reader: read unix @->@: use of closed network connection
2019-07-24T02:42:01+02:00 > Data Fail
2019-07-24T02:42:01+02:00 closing channels
2019-07-24T02:42:00+02:00 Prespawn.
2019-07-24T02:42:00+02:00 script command loaded
2019-07-24T02:42:00+02:00 module registered as command
2019-07-24T02:42:00+02:00 registered callback for event chat
2019-07-24T02:42:00+02:00 serialized function: true
2019-07-24T02:42:00+02:00 Auto-Starting ed3469cb-3a1c-4758-8762-5d531cbc63a6/5c6043d6-7bf9-4e2e-9780-a8da21748354 in 500 ms...
2019-07-24T02:42:00+02:00 Initialization complete
2019-07-24T02:42:00+02:00 executing script command
2019-07-24T02:42:00+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-24T02:42:00+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
how to resolve?
I guess you made a mistake installing and are missing some dependencies. But since you lack crucial information to give you advise, I suggest you to read this again, and post the needed infos.
itsphill
I installed it from the sinusbot installer, i tried more times but the i recive the same error, i tried too in another vps and and I recive the same error
You can install it on 1000 VPSs ... as long I don't know the specs, I cannot help you! Thats why you should read that link, and post the needed information.
If you don't have the time or will to do so (or the even just read), why should anyone bother taking his time and helping you?
itsphill
  • SinusBot v
  • You can install it on 1000 VPSs ... as long I don't know the specs, I cannot help you! Thats why you should read that link, and post the needed information.
  • ersion
  • SinusBot 1.0.0-beta.3-735814e
  • TS Client and Server version: 3.19
  • OS (operating system), Linux buntu 18.04
  • hardware specs ( VPS 8 GB RAM)
  • the instance log and bot log (set LogLevel = 10 in the config.ini before):
  • 2019-07-24T11:19:22+02:00 Storing configuration.
    2019-07-24T11:19:01+02:00 closing channels
    2019-07-24T11:19:01+02:00 eof from voice
    2019-07-24T11:19:00+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-07-24T11:19:00+02:00 Closed.
    2019-07-24T11:19:00+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
    2019-07-24T11:19:00+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
    2019-07-24T11:19:00+02:00 About to run.
    2019-07-24T11:19:00+02:00 Prespawn.
    2019-07-24T11:18:57+02:00 closing channels
    2019-07-24T11:18:56+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-07-24T11:18:56+02:00 Closed.
    2019-07-24T11:18:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
    2019-07-24T11:18:56+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
    2019-07-24T11:18:56+02:00 About to run.
    2019-07-24T11:18:56+02:00 Prespawn.
    2019-07-24T11:18:22+02:00 Storing configuration.
    2019-07-24T11:18:21+02:00 closing channels
    2019-07-24T11:18:20+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-07-24T11:18:20+02:00 Closed.
    2019-07-24T11:18:20+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
    2019-07-24T11:18:20+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
    2019-07-24T11:18:20+02:00 About to run.
    2019-07-24T11:18:20+02:00 Prespawn.
    2019-07-24T11:18:13+02:00 eof from data
    2019-07-24T11:18:13+02:00 closing channels
    2019-07-24T11:18:13+02:00 eof from voice
    2019-07-24T11:18:12+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-07-24T11:18:12+02:00 Closed.
    2019-07-24T11:18:12+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
    2019-07-24T11:18:12+02:00 Starting instance ts3server://ts.dreamwars.eu?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
    2019-07-24T11:18:12+02:00 About to run.
    2019-07-24T11:18:12+02:00 Prespawn.
    2019-07-24T11:18:08+02:00 BOT-CONFIG [admin] HOST CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
    2019-07-24T10:49:52+02:00 Storing configuration.
    2019-07-24T10:49:23+02:00 closing channels
    2019-07-24T10:49:23+02:00 eof from voice
    2019-07-24T10:49:23+02:00 Fail from data reader: read unix @->@: use of closed network connection
    2019-07-24T10:49:23+02:00 Prespawn.
    2019-07-24T10:49:22+02:00 script command loaded
    2019-07-24T10:49:22+02:00 module registered as command
    2019-07-24T10:49:22+02:00 registered callback for event chat
    2019-07-24T10:49:22+02:00 serialized function: true
    2019-07-24T10:49:22+02:00 Auto-Starting 9ea24894-d56b-4135-b879-3c4534e0441d/30890698-4dd0-426b-9a30-a3fbebd79ca2 in 500 ms...
    2019-07-24T10:49:22+02:00 Initialization complete
    2019-07-24T10:49:22+02:00 executing script command
    2019-07-24T10:49:22+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
    2019-07-24T10:49:22+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
  • your config.ini;
  • TS3Path = "/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64"
    LogLevel = 10EnableProfiler = false
    ExternalFileBase = ""
    LicenseKey = "QhxPwhAVDg2JR8zYpatLqlyxH0V8QEF4kcg58UAfT08="
    DevMode = false
    [TTS]
    Enabled = false
  • used browser and plugins (only if it is relevant for the problem none)
For SinusBot1.0.0-beta.3 the most suited TS-Client Version is 3.3.0
Suggesting you to update your client manually to this.
Check the requirements prior ... e.g. kernel version 3.17 on your vps (since you still lack information) and the additional dependencies.
itsphill
how i can update it manually?
itsphill
https://sinusbot.github.io/docs/installation/linux/
well, just see the FAQs, starting at Now you need to download the TeamSpeak 3 Client and install it.
sorry, when i do
wget http://dl.4players.de/ts/releases/3.3.0/TeamSpeak3-Client-linux_amd64-3.3.0.run
chmod 0755 TeamSpeak3-Client-linux_amd64-3.3.0.run
./TeamSpeak3-Client-linux_amd64-3.3.0.run
it gives me error
sinusbot@dreamwars:/opt/sinusbot$ chmod 0755 TeamSpeak3-Client-linux_amd64-3.3.0.run
chmod: cannot access 'TeamSpeak3-Client-linux_amd64-3.3.0.run': No such file or directory
sinusbot@dreamwars:/opt/sinusbot$ ./TeamSpeak3-Client-linux_amd64-3.3.0.run
bash: ./TeamSpeak3-Client-linux_amd64-3.3.0.run: No such file or directory
sinusbot@dreamwars:/opt/sinusbot$ wget http://dl.4players.de/ts/releases/3.3.0/TeamSpeak3-Client-linux_amd64-3.3.0.run
--2019-07-24 11:13:34-- http://dl.4players.de/ts/releases/3.3.0/TeamSpeak3-Client-linux_amd64-3.3.0.run
Resolving dl.4players.de (dl.4players.de)... 85.25.26.25, 85.25.26.26, 85.25.26.27
Connecting to dl.4players.de (dl.4players.de)|85.25.26.25|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2019-07-24 11:13:34 ERROR 404: Not Found.
Hilfe Plus
Hello itsphil,
one user had the sam problem with this. I haved help him with this command:
Debian / Ubuntu
sudo apt-get install libxss1
CentOS
sudo yum install libXScrnSaver
the problem is, your server missing a packet.
Yours faithfully,
Tom
Donald2500
Hello, thanks for this tip the Server says that this is already installed at the newest version but after your command and a server and service restart it looks like it will work.
So thank you very much.
here is the bot log
2019-07-28T15:13:37+02:00 New connection status 4; Error 0
2019-07-28T15:13:37+02:00 TS |INFO    |PermManager   |   |Loading permissions from cache
2019-07-28T15:13:37+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019-07-28T15:13:37+02:00 New connection status 3; Error 0
2019-07-28T15:13:37+02:00 TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019-07-28T15:13:37+02:00 New connection status 2; Error 0
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connected
2019-07-28T15:13:36+02:00 TS |DEVELOP |PktHandler    |   |Puzzle solve time: 2
2019-07-28T15:13:36+02:00 TS |INFO    |              |   |Statistics report: Not yet, next report on Tue Aug 13 22:48:31 2019
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |   |Last update check was: Sat Jan 1 00:00:01 2022
2019-07-28T15:13:36+02:00 TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019-07-28T15:13:36+02:00 New connection status 1; Error 0
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019-07-28T15:13:36+02:00 TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |1  |Initiating connection: 91.218.66.58:9987
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |1  |Resolve successful: 91.218.66.58:9987
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |1  |Lookup finished: ip=91.218.66.58 port=9987 query=ts.neruxvace.net error=0
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |No TSDNS found
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully 5.62.126.167:41144
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully 91.218.66.58:41144
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful, "_tsdns._tcp.neruxvace.net" DNS server returned answer with no data
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |A/AAAA DNS resolve for possible TSDNS successful, "neruxvace.net" =(h: 5.62.126.167 p:0)
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |A/AAAA DNS resolve for possible TSDNS successful, "ts.neruxvace.net" =(h: 91.218.66.58 p:0)
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |A/AAAA DNS resolve successful, "ts.neruxvace.net" =(h: 91.218.66.58 p:0)
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful, "_ts3._udp.ts.neruxvace.net" DNS server returned answer with no data
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |Server name resolved to host: ts.neruxvace.net 9987
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |Lookup: ts.neruxvace.net, parse result: DNS ts.neruxvace.net 9987
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |Server name successfully resolved
2019-07-28T15:13:36+02:00 TS |INFO    |TSDNS         |   |Trying to resolve server name: NeruxVace
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |1  |Trying to resolve NeruxVace
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |1  |Connect to server: NeruxVace
2019-07-28T15:13:36+02:00 TS |INFO    |ClientUI      |   |ts3server: NeruxVace?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-28T15:13:35+02:00 TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/ab226f46-37cf-40de-815b-b43ae74008f8/e78ef467-f195-4d10-b06c-73e739d7a283/settings.db
2019-07-28T15:13:35+02:00 TS |INFO    |ClientUI      |   |Qt version: 5.12.1
2019-07-28T15:13:35+02:00 TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019-07-28T15:13:35+02:00 TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2019-07-28T15:13:35+02:00 TS |INFO    |              |   |*** Time [INIT]: 118
2019-07-28T15:13:35+02:00 TS |INFO    |              |   |*** Time [MAINWINDOW]: 118
2019-07-28T15:13:35+02:00 TS |INFO    |              |   |successfully downloaded revocation list for accounting
2019-07-28T15:13:35+02:00 TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019-07-28T15:13:35+02:00 TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2019-07-28T15:13:35+02:00 TS |INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-07-28T15:13:35+02:00 TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019-07-28T15:13:35+02:00 TS |INFO    |Addons        |   |Checking for addon updates...
2019-07-28T15:13:35+02:00 TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019-07-28T15:13:35+02:00 TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2019-07-28T15:13:35+02:00 TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2019-07-28T15:13:35+02:00 TS |INFO    |              |   |SystemInformation: Linux 4.4.0-157-generic #185-Ubuntu SMP Tue Jul 23 09:17:01 UTC 2019 x86_64 Binary: 64bit
2019-07-28T15:13:35+02:00 TS |INFO    |              |   |TeamSpeak 3 Client 3.3.0 (2019-06-18 09:29:01)
2019-07-28T15:13:35+02:00 Starting instance ts3server://NeruxVace?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-28T15:13:34+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-07-28T15:13:34+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-07-28T15:13:34+02:00 Could not create Chat-Tabletable Chat already exists
2019-07-28T15:13:32+02:00 TSClient quit.
2019-07-28T15:13:32+02:00 KILL [admin] OK
2019-07-28T15:13:31+02:00 New connection status 0; Error 0
2019-07-28T15:13:31+02:00 TS |INFO    |ClientUI      |1  |Disconnected or forced to leave, want autoreconnect = 0
2019-07-28T15:13:31+02:00 TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2019-07-28T15:13:27+02:00 New connection status 4; Error 0
2019-07-28T15:13:27+02:00 TS |INFO    |PermManager   |   |Loading permissions from cache
2019-07-28T15:13:27+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019-07-28T15:13:27+02:00 New connection status 3; Error 0
2019-07-28T15:13:27+02:00 TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019-07-28T15:13:27+02:00 New connection status 2; Error 0
2019-07-28T15:13:27+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connected
2019-07-28T15:13:27+02:00 TS |DEVELOP |PktHandler    |   |Puzzle solve time: 2
2019-07-28T15:13:27+02:00 New connection status 1; Error 0
2019-07-28T15:13:27+02:00 TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019-07-28T15:13:27+02:00 TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |1  |Initiating connection: 91.218.66.58:9987
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |1  |Resolve successful: 91.218.66.58:9987
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |1  |Lookup finished: ip=91.218.66.58 port=9987 query=ts.neruxvace.net error=0
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful, "_ts3._udp.ts.neruxvace.net" DNS server returned answer with no data
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |No TSDNS found
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully 5.62.126.167:41144
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |A/AAAA DNS resolve for possible TSDNS successful, "neruxvace.net" =(h: 5.62.126.167 p:0)
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful, "_tsdns._tcp.neruxvace.net" DNS server returned answer with no data
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully 91.218.66.58:41144
2019-07-28T15:13:26+02:00 TS |INFO    |              |   |Statistics report: Not yet, next report on Tue Aug 13 22:48:31 2019
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |   |Last update check was: Sat Jan 1 00:00:01 2022
2019-07-28T15:13:26+02:00 TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |A/AAAA DNS resolve for possible TSDNS successful, "ts.neruxvace.net" =(h: 91.218.66.58 p:0)
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |A/AAAA DNS resolve successful, "ts.neruxvace.net" =(h: 91.218.66.58 p:0)
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |Server name resolved to host: ts.neruxvace.net 9987
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |Lookup: ts.neruxvace.net, parse result: DNS ts.neruxvace.net 9987
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |Server name successfully resolved
2019-07-28T15:13:26+02:00 TS |INFO    |TSDNS         |   |Trying to resolve server name: NeruxVace
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |1  |Trying to resolve NeruxVace
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |1  |Connect to server: NeruxVace
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |   |ts3server: NeruxVace?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/ab226f46-37cf-40de-815b-b43ae74008f8/e78ef467-f195-4d10-b06c-73e739d7a283/settings.db
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |   |Qt version: 5.12.1
2019-07-28T15:13:26+02:00 TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019-07-28T15:13:26+02:00 TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2019-07-28T15:13:26+02:00 TS |INFO    |              |   |*** Time [INIT]: 138
2019-07-28T15:13:26+02:00 TS |INFO    |              |   |*** Time [MAINWINDOW]: 137
2019-07-28T15:13:25+02:00 TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2019-07-28T15:13:25+02:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
