Bots not starting for some days
Dr_Demo
Everything worked fine, until a few days back. Idk why the bots won't start now, I think our teamspeak updated itself but I am not to sure here.
DIAGNOSTICS:
 - Operating System: Debian GNU/Linux 9.11 (stretch)
 - Kernel: Linux 4.9.0-8-amd64 x86_64
 - Load Average: 0.81 1.10 1.03
 - Uptime: 0 days, 0 hours, 32 minutes, 0 seconds
 - OS APT Last Update: 14.11.2019 16:34:36 CET +01:00:00
 - Shell Locale: en_US.UTF-8
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Intel Xeon Processor (Skylake, IBRS)
    CPU MHz:               2100.000
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 809.68 MB/1.91 GB in use (41%)
 - DISK: 4.72 GB/18.71 GB in use (25%)
   - libglib: 2.50.3-2+deb9u1
 - Status: running (PIDs: 5819 5818, User: sinusbot)
 - Binary Info: MD5 Hash: 6f301dac3e4dfd45ce149933c5dadd08, Perms: 755, User: sinusbot
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.2.5)
   - YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2019.06.27)
 - Installed scripts: advertising.js; alonemode.js; AntiProxy.js; bookmark.js; come.js; command.js; CoverLoader_[Radio_Station_Support].js; Default-Channel.js; followme.js; norecording.js; OKlib.js; Reconnect.js; rememberChannel.js; welcome.js
    linux-vdso.so.1 (0x00007ffca7d4e000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f5f7f370000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f5f7f018000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f5f7ec17000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f5f7e2b2000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f5f7e03e000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f5f7de3a000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f5f7db36000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f5f7d919000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f5f7d597000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f5f7d380000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5f7cfe1000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f5f7cdc7000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f5f7cbbf000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f5f7f58a000)
 - Time (local): 14.11.2019 17:07:07 CET +01:00:00
 - Time (remote): 14.11.2019 17:07:07 CET +01:00:00
 - TeamSpeak3 Version: 3.2.5
 - youtube-dl Version: 2019.06.27
I suggest you to also update the client and server versions. I see absolutely no reason to stay on the old 3.10 version
