Cant Connect.Connecting to local server
BLOCKSTORM_
Operating System: Linux
SinusBot Version: Latest Beta
TS3 Version: 3.x.x
I just installed the Bot on an Linux Debian VServer.Edited the instance settings etc.But every time i try to enable the bot,the bot tries to connect to 127.0.0.1,but i have specified another ip in the instance settings.So it dont Work.Down is the instance log
Instance-Log
2017-09-04T20:33:33+02:00 PLAY [admin] 1bee6c61-e850-48ae-8cf2-a162a5c5ea69 OK
2017-09-04T20:24:28+02:00 Support :2357 Queue trach finnish
2017-09-04T20:24:28+02:00 SAMPLEX 3840 60
2017-09-04T20:22:12+02:00 BOT-CONFIG [admin] NICK HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T20:21:53+02:00 BOT-CONFIG [admin] NICK CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T20:21:04+02:00 BOT-CONFIG [admin] NICK HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T20:20:08+02:00 PLAY [admin] 1bee6c61-e850-48ae-8cf2-a162a5c5ea69 OK
2017-09-04T20:17:55+02:00 Support :2357 Queue trach finnish
2017-09-04T20:17:55+02:00 SAMPLEX 3840 60
2017-09-04T20:14:00+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T20:13:35+02:00 Support :2357 Queue trach finnish
2017-09-04T20:13:35+02:00 PLAY [admin] 1bee6c61-e850-48ae-8cf2-a162a5c5ea69 OK
2017-09-04T20:13:01+02:00 BOT-CONFIG [admin] NICK CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T20:12:37+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T20:12:09+02:00 STOP [admin] OK
2017-09-04T20:11:43+02:00 PLAY [admin] 1bee6c61-e850-48ae-8cf2-a162a5c5ea69 OK
2017-09-04T18:40:18+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T18:38:47+02:00 Loading script Support
2017-09-04T18:38:26+02:00 Loading script Support
2017-09-04T18:28:01+02:00 BOT-CONFIG [admin] NICK NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-09-04T18:27:02+02:00 Loading script Support
2017-09-04T18:24:53+02:00 Loading script Support
2017-09-04T17:56:04+02:00 TSClient quit.
2017-09-04T17:56:03+02:00 New connection status 0; Error 1797
2017-09-04T17:56:03+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-09-04T17:56:03+02:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2017-09-04T17:56:03+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-09-04T17:55:58+02:00 TS |INFO | | |Statistics report: Setting next report date to: Mon Sep 25 17:55:58 2017
2017-09-04T17:55:58+02:00 TS |INFO | | |Statistics report: First run, report later in 1-30 days
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-09-04T17:55:58+02:00 New connection status 1; Error 0
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/e049c7cc-2acd-4c68-b4ca-f5dd5a2bb1df/cdeaecda-3925-4622-9b60-6300207e3983/settings.db
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-09-04T17:55:58+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-09-04T17:55:58+02:00 TS |INFO | | |*** Time [INIT]: 498
2017-09-04T17:55:58+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 497
2017-09-04T17:55:57+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-09-04T17:55:57+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-09-04T17:55:57+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-09-04T17:55:57+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-09-04T17:55:57+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-09-04T17:55:57+02:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-09-04T17:55:57+02:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-09-04T17:55:57+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-09-04T17:55:57+02:00 TS |INFO | | |Using hardware aes
2017-09-04T17:55:57+02:00 TS |INFO | | |SystemInformation: Linux 3.16.0 #1 SMP Wed Jun 21 14:23:18 MSK 2017 x86_64 Binary: 64bit
2017-09-04T17:55:57+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-09-04T17:55:56+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-09-04T17:55:56+02:00 Could not insert into Profiles-Tableno such table: Profiles
2017-09-04T17:55:56+02:00 Could not delete from Profilesno such table: Profiles
2017-09-04T17:55:56+02:00 Auto-Starting e049c7cc-2acd-4c68-b4ca-f5dd5a2bb1df/cdeaecda-3925-4622-9b60-6300207e3983 in 500 ms...
2017-09-04T17:55:56+02:00 Initialization complete
1:12
