Hallo ich habe ein Problem. Es geht drum dass der Bot auf dem TeamSpeak connectet aber nach einigen Sekunden austimed.
Der "TS-Bot" timed nur aus wenn man die Debian Version "testing/buster" hat!
Auf Debian 9.6/stretch geht der "TS-Bot"!
Der "sinusbot-installer.de" wurde benutzt, manuell passiert aber das allergleiche (ts-bot time out).
Version: SinusBot (0.14.3-0e747fd) | TeamSpeak Client: 3.2.3 | TeamSpeak Server: 3.5.0
Operating-System: Debian testing/buster
Hardware Specs: ROOT-Server, Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz | 4 GB RAM
Browser: Google Chrome
config.ini:
LogFile = "/opt/sinusbot/logs.txt"
LicenseKey = "ZKsOC1ZAuTtNyndylX6+qUPNiN+05dWfmhajZdz/K3I="
V1 = ""
V2 = ""
logs.txt
2018/11/20 21:16:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/11/20 21:16:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/11/20 21:16:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/11/20 21:16:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/11/20 21:16:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/11/20 21:16:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/11/20 21:16:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2018/11/20 21:16:27 e5167086 INFO Loading instances
2018/11/20 21:16:27 e5167086 INFO Loading instance://8ddf8f4a-98c1-4bbd-84bd-d5e91c57b1a0
2018/11/20 21:16:27 e5167086 8ddf8f4a INFO Initialization complete
2018/11/20 21:16:27 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2018/11/20 21:16:27 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2018/11/20 21:16:27 [GENERAL/YTDL ] INFO youtube-dl checking...
2018/11/20 21:16:28 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2018/11/20 21:16:28 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2018/11/20 21:16:28 [GENERAL/RADIO ] INFO RadioStation data loaded
2018/11/20 21:16:28 [GENERAL/RADIO ] INFO Imported radio stations
2018/11/20 21:17:13 e5167086 INFO LOGIN [admin] OK
2018/11/20 21:17:18 e5167086 8ddf8f4a DEBUG Prespawn.
2018/11/20 21:17:18 e5167086 8ddf8f4a DEBUG About to run.
2018/11/20 21:17:18 e5167086 8ddf8f4a WARN Could not create Chat-Tabletable Chat already exists
2018/11/20 21:17:18 e5167086 8ddf8f4a WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/11/20 21:17:18 e5167086 8ddf8f4a WARN Could not create Notifications-Tabletable Notifications already exists
2018/11/20 21:17:18 e5167086 8ddf8f4a DEBUG Could not delete from FileTransferno such table: FileTransfer
2018/11/20 21:17:18 e5167086 8ddf8f4a DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/11/20 21:17:18 e5167086 8ddf8f4a DEBUG Could not delete from Newsno such table: News
2018/11/20 21:17:18 e5167086 8ddf8f4a DEBUG Could not insert into News-Tableno such table: News
2018/11/20 21:17:18 e5167086 8ddf8f4a INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018/11/20 21:17:19 X [MAIN] New connection
2018/11/20 21:17:19 e5167086 8ddf8f4a DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/e5167086-d3ca-45e3-8a35-db755c91c2de/8ddf8f4a-98c1-4bbd-84bd-d5e91c57b1a0/crashdumps
2018/11/20 21:17:19 e5167086 8ddf8f4a DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/e5167086-d3ca-45e3-8a35-db755c91c2de/8ddf8f4a-98c1-4bbd-84bd-d5e91c57b1a0/crashdumps
2018/11/20 21:17:19 e5167086 8ddf8f4a INFO TS |INFO | | |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2018/11/20 21:17:19 e5167086 8ddf8f4a INFO TS |INFO | | |SystemInformation: Linux 4.18.0-2-amd64 #1 SMP Debian 4.18.10-2 (2018-11-02) x86_64 Binary: 64bit
2018/11/20 21:17:19 e5167086 8ddf8f4a INFO TS |INFO | | |Using hardware aes
2018/11/20 21:17:19 e5167086 8ddf8f4a INFO TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |Addons | |Checking for addon updates...
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018/11/20 21:17:20 X [MAIN] New connection
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO | | |successfully downloaded revocation list for accounting
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO | | |*** Time [MAINWINDOW]: 201
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO | | |*** Time [INIT]: 202
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI | |Qt version: 5.6.1
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/e5167086-d3ca-45e3-8a35-db755c91c2de/8ddf8f4a-98c1-4bbd-84bd-d5e91c57b1a0/settings.db
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO New connection status 1; Error 0
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 7
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TS |INFO |ClientUI |1 |Connect status: Connected
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018/11/20 21:17:20 e5167086 8ddf8f4a INFO TSClient quit.
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>libpng warning: iCCP: known incorrect sRGB profile
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>Auto configuration failed
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>140115835161856:error:25066067
SO support routines
LFCN_LOAD:could not load the shared library:dso_dlfcn.c:185:filename(libssl_conf.so): libssl_conf.so: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>140115835161856:error:25070067
SO support routines
SO_load:could not load the shared library:dso_lib.c:244:
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>140115835161856:error:0E07506E:configuration file routines:MODULE_LOAD_DSO:error loading dso:conf_mod.c:285:module=ssl_conf, path=ssl_conf
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>140115835161856:error:0E076071:configuration file routines:MODULE_RUN:unknown module name:conf_mod.c:222:module=ssl_conf
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG TS>QMutex: destroying locked mutex
2018/11/20 21:17:20 e5167086 8ddf8f4a DEBUG Closed.
2018/11/20 21:17:27 e5167086 8ddf8f4a DEBUG Storing configuration.
config.ini:
V1 = ""
V2 = ""
logs.txt
