I currently have a problem with the Sinusbot.
Every time I try to change the Radio Channel, it just wont play.
Im currently using Sinusbot version 0.9.11
My Server Specs are:
- Dedicated Server with Debian 8
- Intel XEON D-1540 (8 Cores (16vCores)) @ 2.6GHz
- 32GB DDR4 Ram
Browsers used: Google Chrome & Firefox
Output of @Patschi 's script:
My Config.ini:
Thats the Error message (LogLevel 10):
And thats spamming into the console.
Thanks in advance!
- Cr4ftii
- 32GB DDR4 Ram
- Operating System: Debian GNU/Linux 8.3 (jessie)
- Load Average: 1.17 1.14 1.26
- Uptime: 7 days, 20 hours, 28 minutes, 41 seconds
- OS APT Last Update: 28.03.2016 06:10:41 CEST +02:00:00
CPU(s): 16
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU D-1540 @ 2.00GHz
CPU MHz: 1229.843
Virtualization: VT-x
- RAM: 2.02 GB/31.38 GB in use (6%)
- SWAP: 0 B/15.25 GB in use (0%)
- DISK: 13.22 GB/83.85 GB in use (15%)
- Report date: 01.04.2016 21:14:10 CEST +02:00:00 (timezone: Europe/Berlin)
- Status: running (PIDs: 8820 8819, User: sinusbot)
- Binary: /opt/ts3soundboard/sinusbot (Hash: 09876610d75f55d2a133013f5a06937d)
- Version: 0.9.11-ee30ef7
- Bot Plugin: 550012df1db6e7086abcf5af6afd0dda
- TS3 Client: 550012df1db6e7086abcf5af6afd0dda
- TS3Path = /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_ amd64 (Version 3.0.18.2)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2015.12.23)
- Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; cov atar.js; dev.js; followme.js; idle.js; metadata.js; norecording.js; rememberChan nel.js; showcase.js; sound.js; welcometext.js
- DiagScript version: v0.4.1
My Config.ini:
InstanceActionLimit = 12
EnableWebStream = true
LicenseKey = "lBRIlKuw9rxKr6gqI8xVmARKnNfch+tFiObp5Ev9EAA="
UserAgent = "SinusBot (0.9.11-ee30ef7)"
2016/04/01 21:02:42 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:42 faf1cb68 e21a0919 DEBUG Done playing
2016/04/01 21:02:42 faf1cb68 e21a0919 INFO Playing next from playlist: track://374eebb9-f693-4d61-9b16-2d461f74d9c2
2016/04/01 21:02:43 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:43 faf1cb68 e21a0919 DEBUG Done playing
2016/04/01 21:02:43 faf1cb68 e21a0919 INFO Playing idle trackplaylist://65072544-9ae1-4762-a6c0-af7aaa0eaace
2016/04/01 21:02:43 faf1cb68 e21a0919 DEBUG Reseeding PRNG
2016/04/01 21:02:44 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:44 faf1cb68 285d0b98 DEBUG Done playing
2016/04/01 21:02:44 faf1cb68 DEBUG GET didn't work either. Stream will be forwarded to FFmpeg directly.
2016/04/01 21:02:44 faf1cb68 285d0b98 INFO Playing idle trackplaylist://19cd2ebb-6308-474b-8bf0-a7942a812fa7
2016/04/01 21:02:44 faf1cb68 285d0b98 DEBUG Reseeding PRNG
2016/04/01 21:02:45 faf1cb68 DEBUG GET didn't work either. Stream will be forwarded to FFmpeg directly.
2016/04/01 21:02:45 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:45 faf1cb68 e21a0919 DEBUG Done playing
2016/04/01 21:02:45 faf1cb68 e21a0919 INFO Playing next from playlist: track://374eebb9-f693-4d61-9b16-2d461f74d9c2
2016/04/01 21:02:46 faf1cb68 DEBUG GET didn't work either. Stream will be forwarded to FFmpeg directly.
2016/04/01 21:02:46 faf1cb68 e21a0919 DEBUG Done playing
2016/04/01 21:02:46 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:47 faf1cb68 e21a0919 INFO Playing idle trackplaylist://65072544-9ae1-4762-a6c0-af7aaa0eaace
2016/04/01 21:02:47 faf1cb68 e21a0919 DEBUG Reseeding PRNG
2016/04/01 21:02:47 faf1cb68 DEBUG GET didn't work either. Stream will be forwarded to FFmpeg directly.
2016/04/01 21:02:47 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:48 faf1cb68 DEBUG GET didn't work either. Stream will be forwarded to FFmpeg directly.
2016/04/01 21:02:49 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:49 faf1cb68 e21a0919 DEBUG Done playing
2016/04/01 21:02:49 faf1cb68 e21a0919 INFO Playing next from playlist: track://374eebb9-f693-4d61-9b16-2d461f74d9c2
2016/04/01 21:02:49 faf1cb68 DEBUG GET didn't work either. Stream will be forwarded to FFmpeg directly.
2016/04/01 21:02:50 faf1cb68 e21a0919 DEBUG Done playing
2016/04/01 21:02:50 faf1cb68 e21a0919 INFO Playing idle trackplaylist://65072544-9ae1-4762-a6c0-af7aaa0eaace
2016/04/01 21:02:50 faf1cb68 e21a0919 DEBUG Reseeding PRNG
2016/04/01 21:02:51 faf1cb68 DEBUG GET didn't work either. Stream will be forwarded to FFmpeg directly.
2016/04/01 21:02:51 faf1cb68 e21a0919 DEBUG Done playing
2016/04/01 21:02:51 faf1cb68 e21a0919 INFO Playing next from playlist: track://374eebb9-f693-4d61-9b16-2d461f74d9c2
2016/04/01 21:02:51 faf1cb68 DEBUG Server seems broken or unreachable. Maybe ICY? Trying GET
2016/04/01 21:02:52 faf1cb68 e21a0919 DEBUG Done playing
Thanks in advance!
- Cr4ftii
