[GUIDE] Youtube-dl problems?
Idler
If anyone gets the issue "Signature extraction failed", here is a fix for Linux:
1. Connect to your VPS via SSH or open up a terminal
2. Type sudo youtube-dl --update
3. Restart the bot
Should work.
Halis
[root@desktop ~]# youtube-dl --update
Usage: youtube-dl [OPTIONS] URL [URL...]
youtube-dl: error: You must provide at least one URL.
Type youtube-dl --help to see a list of all options.
[root@desktop ~]# sudo youtube-dl --update
Didn't work. I use Centos 6.7(final) 64-Bit system.
Niggolo
$ youtube-dl -U
Updating to version 2015.12.23 ...
ERROR: no write permissions on /usr/local/bin/youtube-dl
Ignore the permission lol im not using the root now XD
What OS are oyu using?
Halis
[root@desktop etc]# youtube-dl -U
It looks like you installed youtube-dl with a package manager, pip, setup.py or a tarball. Please use that to update.
I am using centos 6.7 (final) 64-Bit
Halis
I solved this problem. youtube-dl is old version. So I removed this version and again install.
#remove youtube-dl
yum remove youtube-dl
#install pip command for youtube-dl #(http://sharadchhetri.com/2014/05/30/install-pip-centos-rhel-ubuntu-debian/)
yum install -y python-pip
#install youtube-dl #(https://rg3.github.io/youtube-dl/download.html)
wget https://yt-dl.org/downloads/2015.12.23/youtube-dl -O /usr/local/bin/youtube-dl
chmod a+rx /usr/local/bin/youtube-dl
pip install --upgrade youtube_dl
And this problem is solved.
Halis
Yes, thank you Niogglo :) But still I have a problem. I can't add language pack. I add tr.json file in "data/locales" but didn't work, I didn't see in personal settings / Languege. I can see only german and english. How can I solve it ?
Halis
I reboot, but sill didn't work.
I didn't edit tr.json file. Only download from sinusbot.com and upload in my vds.
Niggolo
Hm I'm not sure.... Also I'm about to go sleep, if you don't solve it, I will help tomorrow
Last version of sinusbot? also the bot is not fully compatible with centos if I'm not wrong
Bye
Halis
Ok thank you Niggolo.
my config.ini
ListenHost = "127.0.0.1"
SecretKey = [166, 66, 84, 77, 121, 91, 126, 35, 69, 238, 242, 80, 78, 254, 166, 43, 176, 25, 254, 65, 38, 207, 79, 78, 60, 101, 216, 120, 3, 101, 36, 83]
MTU = 1500
SampleInterval = 100
