when i try to install sinusbot it gave me this error:
[root@Archedia ~]# bash <(wget -O - 'https://raw.githubusercontent.com/SinusBot/installer-linux/master/sinusbot_installer.sh')
Redirecting output to 'wget-log.5'.
Checking for the latest installer version
/dev/fd/63: line 92: 3: No such file or directory
You're using installer 1.5
What should the installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Installing redhat-lsb! Please wait.
Done!
You're running CentOS. Which firewallsystem are you using?
1) IPtables
2) Firewalld
#? 2
Warning, your server is running OpenVZ! This very old container system isn't well supported by newer packages.
Automatically chosen system.d for your startscript!
1) Automatic
2) Own path
3) Quit
#? 1
Should I install TeamSpeak or only Discord Mode?
1) Both
2) Only Discord
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
Update the system packages to the latest version? (Recommended)
1) Yes
2) No
#? 1
Starting the installer now!
Detected latest TS3-Client version as 3.3.2
Error: Unable to find a match: xvfb libxcursor1 libglib2.0-0 cron-apt ntp python libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 libpci3 libxslt1.1 libxkbcommon0 libxss1
Command which failed was: " yum -y install screen xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 less cron-apt ntp python iproute which dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 libpci3 libxslt1.1 libxkbcommon0 libxss1". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 622.
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Done!
1) IPtables
2) Firewalld
#? 2
1) Automatic
2) Own path
3) Quit
#? 1
1) Both
2) Only Discord
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
1) Yes
2) No
#? 1
