D
Deleted member 43579
Guest
Hi, so i need a help. I can't get the newest version to work (ts3 client is crashing when bot stats to play). I've updated server version to 3.10, so i needd client version min. 3.3. My bots were beta 1 with 3.2.5 and beta 1 doesn't support the 3.3. So i did a backup and downloaded beta 8 with 3.3 client (did usual things like cp plugin, set the right permissons and make it executable). When i start the bot, he was fine, could message him and he responded, but when i made him to play, he crashed. Bots are crashing when playing music. i've beta 3,6,7,8 with ts versions 3.2, 3.1, 3.0, always the same and i need a help what to do. i even tried docker ( sinusbot/docker:latest ), same result. When i use the backup, bots are working fine, but i can't use them on 3.10 ts server. Here's some logs (beta 8, ts 3.2) (deleting libqxcb-glx-integration.so doesn't make any diff)
crash ts3 dump:
From sinusbot console:
Server data etc script:
crash ts3 dump:
2019-11-11 11:58:15.147702|INFO | | |TeamSpeak 3 Client 3.3.0 (2019-06-18 09:29:01)
2019-11-11 11:58:15.147904|INFO | | |SystemInformation: Linux 4.15.0-66-generic #75-Ubuntu SMP Tue Oct 1 05:24:09 UTC 2019 x86_64 Binary: 64bit
2019-11-11 11:58:15.488559|ERROR |PulseAudio | |failed to connect to pulse audio server -
2019-11-11 11:58:15.489642|ERROR |PulseAudio | |pa_context_connect failed -
2019-11-11 11:58:15.490204|ERROR |SoundBckndIntf| |/opt/ts3soundboard1/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2019-11-11 11:58:15.490960|INFO |ClientUI | |Unable to create an Open GL context.
2019-11-11 11:58:15.491896|ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-11-11 11:58:15.606615|INFO |Addons | |Checking for addon updates...
2019-11-11 11:58:15.712909|INFO | | |successfully downloaded revocation list for accounting
2019-11-11 11:58:15.720806|INFO | | |successfully downloaded revocation list for myteamspeak id
2019-11-11 11:58:15.843121|INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-11-11 11:58:15.844907|INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-11-11 11:58:15.846560|INFO |Plugins | |Api version is not compatible for plugin: /opt/ts3soundboard1/data/ts3/5e0f9a2a-87a2-411a-8b77-39a992c72825/2dc701a2-4330-46f3-8484-44438139177c/plugins/libclientquery_plugin_linux_amd64.so
2019-11-11 11:58:16.169352|INFO | | |*** Time [CONTACTS]: 137
2019-11-11 11:58:16.447490|INFO | | |*** Time [MAINWINDOW]: 566
2019-11-11 11:58:16.448109|INFO | | |*** Time [INIT]: 567
2019-11-11 11:58:16.448920|DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/ts3soundboard1/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019-11-11 11:58:16.455737|INFO |ClientUI | |Failed to init text to speech engine
2019-11-11 11:58:16.455863|INFO |ClientUI | |Qt version: 5.12.1
2019-11-11 11:58:16.455898|INFO |ClientUI | |Using configuration location: /opt/ts3soundboard1/data/ts3/5e0f9a2a-87a2-411a-8b77-39a992c72825/2dc701a2-4330-46f3-8484-44438139177c/settings.db
2019-11-11 11:58:16.986081|INFO |ClientUI | |ts3server: 192.168.1.4?port=9987&nickname=%E2%99%AA%E2%94%8F%28%C2%B0.%C2%B0%29%E2%94%93Europa%202%20Bot%E2%94%8F%28%C2%B0.%C2%B0%29%E2%94%9B%E2%99%AA&password=&cid=73&channelpassword=
2019-11-11 11:58:16.987200|INFO |ClientUI |1 |Connect to server: 192.168.1.4
2019-11-11 11:58:16.988075|INFO |ClientUI |1 |Initiating connection: 192.168.1.4:9987
2019-11-11 11:58:17.372242|INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019-11-11 11:58:17.515313|INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-11-11 11:58:17.516614|INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019-11-11 11:58:17.517590|INFO | | |Statistics report: User has not yet confirmed participation
2019-11-11 11:58:17.525106|DEVELOP |PktHandler | |Puzzle solve time: 7
2019-11-11 11:58:17.595550|INFO |ClientUI |1 |Connect status: Connecting
2019-11-11 11:58:17.596583|INFO |Newsticker | |Newsticker next check: Sat Jan 1 00:00:01 2022
2019-11-11 11:58:17.698067|INFO |ClientUI |1 |Connect status: Connected
2019-11-11 11:58:17.740776|INFO |ClientUI |1 |Connect status: Establishing connection
2019-11-11 11:58:17.785761|INFO |ClientUI |1 |Connect status: Connection established
2019-11-11 11:58:17.786229|INFO |PermManager | |Requesting permissions from server
2019-11-11 11:58:17.913031|WARNING |SCHandler |1 |Received unknown packet
2019-11-11 11:58:18.202256|WARNING |SCHandler |1 |Received unknown packet
2019-11-11 11:58:27.557736|INFO |Newsticker | |Newsticker next check: Sat Jan 1 00:00:01 2022
2019-11-11 11:58:33.678236|INFO |ClientUI |1 |Ignored text message by Clara || EUNE: Zyra Hentai1111: !help
2019-11-11 11:58:33.678585|INFO |ClientUI |1 |Ignored text message by Clara || EUNE: Zyra Hentai1111: !help
2019-11-11 11:58:34.250408|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]37[/B] Commands found:
2019-11-11 11:58:34.250916|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!help[/B] - Displays this text
2019-11-11 11:58:34.251173|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!man[/B] - Displays detailed help about a command if available
2019-11-11 11:58:34.251356|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!register[/B] - Register a new user
2019-11-11 11:58:34.251543|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!playing[/B] - Show what's currantly playing
2019-11-11 11:58:34.251713|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!next[/B] - Play the next track
2019-11-11 11:58:34.251885|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!prev[/B] - Play the previous track
2019-11-11 11:58:34.252055|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!search[/B] - Search for tracks
2019-11-11 11:58:34.252267|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!play[/B] - Play a track by its id or name
2019-11-11 11:58:34.252466|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!playlist[/B] - Start playing back the playlist <playlistname>
2019-11-11 11:58:34.252761|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!queue[/B] - Enqueue a track or resume queue
2019-11-11 11:58:34.252974|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!queuenext[/B] - Prepends a track to the queue
2019-11-11 11:58:34.253169|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!stop[/B] - Stop playback
2019-11-11 11:58:34.253364|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!!stop[/B] - Stop playback and remove idle-track
2019-11-11 11:58:34.253532|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!volume[/B] - Change the volume
2019-11-11 11:58:34.253697|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!stream[/B] - Stream a url
2019-11-11 11:58:34.253911|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!say[/B] - Say a text via TTS
2019-11-11 11:58:34.254074|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!sayex[/B] - Say a text via TTS with given locale
2019-11-11 11:58:34.254237|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ttsurl[/B] - Set the TTS url.
2019-11-11 11:58:34.254389|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ttslocale[/B] - Set the TTS locale.
2019-11-11 11:58:34.254551|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!yt[/B] - Play <url> via youtube-dl
2019-11-11 11:58:34.254777|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ytdl[/B] - Download and play <url> via youtube-dl
2019-11-11 11:58:34.269713|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!qyt[/B] - Enqueue <url> via youtube-dl
2019-11-11 11:58:34.270484|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!qytdl[/B] - Download and enqueue <url> via youtube-dl
2019-11-11 11:58:34.271691|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!shuffle[/B] - Toggle shuffle
2019-11-11 11:58:34.273676|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!repeat[/B] - Toggle repeat
2019-11-11 11:58:34.275845|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!sub[/B] - Subscribe to bot
2019-11-11 11:58:34.281927|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!unsub[/B] - Unsubscribe from bot
2019-11-11 11:58:34.282302|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!subchan[/B] - Add subscription for channel
2019-11-11 11:58:34.283667|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!unsubchan[/B] - Remove subscription for channel
2019-11-11 11:58:34.283862|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!mode[/B] - Change Transmit-Mode
2019-11-11 11:58:34.290053|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!registration[/B] - Enable / disable user registration via chat
2019-11-11 11:58:34.290244|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!prefix[/B] - Change command prefix
2019-11-11 11:58:34.290364|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ping[/B] - pong
2019-11-11 11:58:34.290490|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!version[/B] - Show version
2019-11-11 11:58:34.291503|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!reload[/B] - Reload scripts
2019-11-11 11:58:34.293318|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!join[/B] - Move the SinusBot to your channel
2019-11-11 11:58:34.296068|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!leave[/B] - Disconnect the SinusBot
2019-11-11 11:58:34.338285|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]37[/B] Commands found:
2019-11-11 11:58:34.340671|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!help[/B] - Displays this text
2019-11-11 11:58:34.342994|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!man[/B] - Displays detailed help about a command if available
2019-11-11 11:58:34.344719|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!register[/B] - Register a new user
2019-11-11 11:58:34.347263|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!playing[/B] - Show what's currantly playing
2019-11-11 11:58:34.348966|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!next[/B] - Play the next track
2019-11-11 11:58:34.351065|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!prev[/B] - Play the previous track
2019-11-11 11:58:34.352585|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!search[/B] - Search for tracks
2019-11-11 11:58:34.354612|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!play[/B] - Play a track by its id or name
2019-11-11 11:58:34.356622|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!playlist[/B] - Start playing back the playlist <playlistname>
2019-11-11 11:58:34.358491|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!queue[/B] - Enqueue a track or resume queue
2019-11-11 11:58:34.360235|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!queuenext[/B] - Prepends a track to the queue
2019-11-11 11:58:34.361934|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!stop[/B] - Stop playback
2019-11-11 11:58:34.363828|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!!stop[/B] - Stop playback and remove idle-track
2019-11-11 11:58:34.366020|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!volume[/B] - Change the volume
2019-11-11 11:58:34.367596|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!stream[/B] - Stream a url
2019-11-11 11:58:34.369691|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!say[/B] - Say a text via TTS
2019-11-11 11:58:34.371469|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!sayex[/B] - Say a text via TTS with given locale
2019-11-11 11:58:34.373021|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ttsurl[/B] - Set the TTS url.
2019-11-11 11:58:34.374740|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ttslocale[/B] - Set the TTS locale.
2019-11-11 11:58:34.376482|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!yt[/B] - Play <url> via youtube-dl
2019-11-11 11:58:34.378440|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ytdl[/B] - Download and play <url> via youtube-dl
2019-11-11 11:58:34.380139|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!qyt[/B] - Enqueue <url> via youtube-dl
2019-11-11 11:58:34.382013|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!qytdl[/B] - Download and enqueue <url> via youtube-dl
2019-11-11 11:58:34.390236|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!shuffle[/B] - Toggle shuffle
2019-11-11 11:58:34.390482|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!repeat[/B] - Toggle repeat
2019-11-11 11:58:34.390630|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!sub[/B] - Subscribe to bot
2019-11-11 11:58:34.390771|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!unsub[/B] - Unsubscribe from bot
2019-11-11 11:58:34.390938|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!subchan[/B] - Add subscription for channel
2019-11-11 11:58:34.391975|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!unsubchan[/B] - Remove subscription for channel
2019-11-11 11:58:34.393525|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!mode[/B] - Change Transmit-Mode
2019-11-11 11:58:34.395233|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!registration[/B] - Enable / disable user registration via chat
2019-11-11 11:58:34.397348|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!prefix[/B] - Change command prefix
2019-11-11 11:58:34.399163|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!ping[/B] - pong
2019-11-11 11:58:34.400892|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!version[/B] - Show version
2019-11-11 11:58:34.402572|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!reload[/B] - Reload scripts
2019-11-11 11:58:34.404260|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!join[/B] - Move the SinusBot to your channel
2019-11-11 11:58:34.406149|INFO |ClientUI |1 |Ignored text message by ♪┏(°.°)┓Europa 2 Bot┏(°.°)┛♪: [B]!leave[/B] - Disconnect the SinusBot
2019-11-11 11:58:37.547538|INFO |Newsticker | |Newsticker next check: Sat Jan 1 00:00:01 2022
2019-11-11 11:58:47.548112|INFO |Newsticker | |Newsticker next check: Sat Jan 1 00:00:01 2022
2019-11-11 11:58:57.552665|INFO |Newsticker | |Newsticker next check: Sat Jan 1 00:00:01 2022
2019-11-11 11:59:07.548027|INFO |Newsticker | |Newsticker next check: Sat Jan 1 00:00:01 2022
2019/11/11 12:59:09 5e0f9a2a 529e79bc INFO TS |INFO |ClientUI | |ts3server: 192.168.1.4?port=9987&nickname=NightcoreBot&password=&cid=114&channelpassword=
2019/11/11 12:59:09 5e0f9a2a 529e79bc INFO TS |INFO |ClientUI |1 |Connect to server: 192.168.1.4
2019/11/11 12:59:09 5e0f9a2a 529e79bc INFO TS |INFO |ClientUI |1 |Initiating connection: 192.168.1.4:9987
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |INFO | | |Statistics report: User has not yet confirmed participation
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 6
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO New connection status 1; Error 0
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |INFO |ClientUI |1 |Connect status: Connected
2019/11/11 12:59:10 5e0f9a2a 2dc701a2 DEBUG closing channels
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO New connection status 2; Error 0
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO New connection status 3; Error 0
2019/11/11 12:59:10 5e0f9a2a 529e79bc DEBUG TS>Breakpad crash /opt/ts3soundboard1/data/ts3/5e0f9a2a-87a2-411a-8b77-39a992c72825/529e79bc-0a3c-411d-be89-52687fa7f5f2/crashdumps/b6d19cc5-2125-4335-9c34e288-2e164615.dmp
2019/11/11 12:59:10 5e0f9a2a 529e79bc DEBUG TS>Starting Error Reporter: /opt/ts3soundboard1/TeamSpeak3-Client-linux_amd64/error_report
2019/11/11 12:59:10 X [MAIN] New connection
2019/11/11 12:59:10 5e0f9a2a 529e79bc INFO TSClient quit.
- Operating System: Ubuntu 18.04.3 LTS
- Kernel: Linux 4.15.0-66-generic x86_64
- Load Average: 0.76 0.80 0.88
- Uptime: 0 days, 1 hours, 34 minutes, 11 seconds
- OS Updates: 64 (updates available!)
- OS APT Last Update: 11.11.2019 11:18:11 CET +01:00:00
- Shell Locale: en_US.UTF-8
- Bot Start Script: found at /etc/init.d/sinusbot [perms: 777]
CPU(s): 2
Thread(s) per core: 1
Core(s) per socket: 2
Socket(s): 1
Model name: AMD Turion(tm) II Neo N54L Dual-Core Processor
CPU MHz: 800.000
Virtualization: AMD-V
- RAM: 2.25 GB/3.72 GB in use (60%)
- SWAP: 452.50 MB/9.28 GB in use (4%)
- DISK: 169.25 GB/513.24 GB in use (32%)
- Binary: /opt/ts3soundboard1/sinusbot
- Binary Info: MD5 Hash: 43a7695283e7688edd94790e09bbce39, Perms: 755, User: sinusbot
- Version: 1.0.0-beta.8-9e95ca7
- TS3Path = /opt/ts3soundboard1/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.3.0)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.08.13)
- Installed scripts: advertising.js; alonemode.js; bookmark.js; come.js; command.js; defaultChannel+.js; Group__Distributor.js; OKlib.js; reconnect.js; rememberChannel.js; saveCPU (1).js; sinusbot-commands.js; tunakills_ranking.js; welcome.js
- TS3Client/libqxcb-glx-integration.so: yes
linux-vdso.so.1 (0x00007ffde375a000)
libswresample.so.2 => /opt/ts3soundboard1/libswresample.so.2 (0x00007fe6590ab000)
libavfilter.so.6 => /opt/ts3soundboard1/libavfilter.so.6 (0x00007fe658d53000)
libavformat.so.57 => /opt/ts3soundboard1/libavformat.so.57 (0x00007fe658952000)
libavcodec.so.57 => /opt/ts3soundboard1/libavcodec.so.57 (0x00007fe657fed000)
libavutil.so.55 => /opt/ts3soundboard1/libavutil.so.55 (0x00007fe657d79000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fe657b75000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fe6577d7000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fe6575b8000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fe65722f000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fe657017000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fe656c26000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fe656a09000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fe656801000)
/lib64/ld-linux-x86-64.so.2 (0x00007fe6592c5000)
- Time (local): 11.11.2019 13:06:04 CET +01:00:00
- Timezone: Europe/Bratislava
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.08.13
