curl -O https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2
tar -xjvf sinusbot-beta.tar.bz2
What do you even have trouble with? All you do is, make a folder where you want the bot to be and go into that folder, then enter these commands in terminal.
Code:curl -O https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2 tar -xjvf sinusbot-beta.tar.bz2
If your VPS is windows, then it's much easier. Just make sure you have <= teamspeak 3.0.19.4 installed and run the exe.
Yes it starts without any error.Does the bot startup without any errors?
That was the problem, i didn't open the port. Now it works fine. Thanks for the help dude.I'm assuming you wanted to hide your ip. Make sure port 8087 is open on your vps through your firewall. If there is no firewall and all ports are open, then you should be able to connect fine.
