Language and Youtube-DL Problem ?
Halis
I use Centos 6.7(Final) 64 Bit operating system. I have vmware and I created vds.
config.ini >>>
ListenHost = "31.210.96.206"
SecretKey = [166, 66, 84, 77, 121, 91, 126, 35, 69, 238, 242, 80, 78, 254, 166, 43, 176, 25, 254, 65, 38, 207, 79, 78, 60, 101, 216, 120, 3, 101, 36, 83]
MTU = 1500
SampleInterval = 100
I installed sinusbot, but I have two problems.
1. I didn't use youtube-dl. When I started the sinusbot, screen logs are in below. (fork/exec /usr/local/bin/youtube-dl: permission denied youtube-dl not found) I didn't upload youtube-link on webinterface, I saw "error, youtube-dl not available". How can I solve this problem ?
2015/12/21 00:20:31 9fce4f41 INFO Initializing bot://9fce4f41-8314-41d1-b68a-1915f3de291d
2015/12/21 00:20:31 9fce4f41 fe05c913 INFO Loaded
2015/12/21 00:20:31 Auto-Starting 9fce4f41-8314-41d1-b68a-1915f3de291d/fe05c913-b1b8-4d17-8452-8cb77c99707e in 2500 ms...
2015/12/21 00:20:31 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/12/21 00:20:31 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/12/21 00:50:02 youtube-dl checking...
2015/12/21 00:50:02 fork/exec /usr/local/bin/youtube-dl: permission denied youtube-dl not found
2015/12/21 00:50:02 RadioStation data loaded
2015/12/21 00:50:02 Imported radio stations
2015/12/21 00:50:04 9fce4f41 fe05c913 DEBUG Could not delete from Notificationsno such table: Notifications
2015/12/21 00:50:04 9fce4f41 fe05c913 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/12/21 00:50:04 9fce4f41 fe05c913 INFO Starting instance ts3server://31.210.96.196?port=9099&nickname=GT%C3%9C%20M%C3%BCzik%20Bot&password=&cid=80037&channelpassword=
Crashdump ENABLED, directory is: /opt/ts3soundboard/data/ts3/9fce4f41-8314-41d1-b68a-1915f3de291d/fe05c913-b1b8-4d17-8452-8cb77c99707e/crashdumps
DUMP defined! Dumpdir is: /opt/ts3soundboard/data/ts3/9fce4f41-8314-41d1-b68a-1915f3de291d/fe05c913-b1b8-4d17-8452-8cb77c99707e/crashdumps
2015-12-20 22:50:04.635683|INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2015-12-20 22:50:04.635914|INFO | | |SystemInformation: Linux 2.6.32-573.12.1.el6.x86_64 #1 SMP Tue Dec 15 21:19:08 UTC 2015 x86_64 Binary: 64bit
2015-12-20 22:50:04.644779|DEBUG |PulseAudio | |connected to pulse audio server
2015-12-20 22:50:04.675293|INFO | | |Loading plugin: libclientquery_plugin
2015-12-20 22:50:04.675444|INFO | | |Loading plugin: liblua_plugin
2015-12-20 22:50:04.675541|INFO | | |Loading plugin: libsoundbot_plugin
2015-12-20 22:50:04.675611|INFO | | |Loading plugin: libtest_plugin
2015-12-20 22:50:04.677508|INFO |Query | |listening on 127.0.0.1:25639
libpng warning: iCCP: known incorrect sRGB profile
2015-12-20 22:50:04.772199|INFO | | |*** Time [MAINWINDOW]: 120
2015-12-20 22:50:04.772440|INFO | | |*** Time [INIT]: 120
2015-12-20 22:50:04.776343|INFO |ClientUI | |Failed to init text to speech engine
2015-12-20 22:50:04.776521|INFO |ClientUI | |Qt version: 5.5.0
2015-12-20 22:50:04.776600|INFO |ClientUI | |Using configuration location: /opt/ts3soundboard/data/ts3/9fce4f41-8314-41d1-b68a-1915f3de291d/fe05c913-b1b8-4d17-8452-8cb77c99707e/settings.db
2015-12-20 22:50:05.073696|INFO |ClientUI | |ts3server: 31.210.96.196?port=9099&nickname=GT%C3%9C%20M%C3%BCzik%20Bot&password=&cid=80037&channelpassword=
2015-12-20 22:50:05.074289|INFO |ClientUI |1 |Connect to server: 31.210.96.196
2015-12-20 22:50:05.075488|INFO |ClientUI |1 |Blacklist check ok
2015-12-20 22:50:05.075676|INFO |ClientUI |1 |Initiating connection: 31.210.96.196:9099 31.210.96.196
2015-12-20 22:50:05.090232|INFO |PreProSpeex |1 |Speex version: 1.2rc1
2015-12-20 22:50:05.095398|INFO |ClientUI |1 |Connect status: Connecting
2015-12-20 22:50:05.100099|DEVELOP |PktHandler | |Puzzle solve time: 5
2015-12-20 22:50:05.106273|INFO |EncodeCelt |1 |CELT bitstream version: 0x80000010
2015-12-20 22:50:05.106557|INFO |ClientUI |1 |Connect status: Connected
2015-12-20 22:50:05.119725|INFO |ClientUI |1 |Connect status: Establishing connection
2015-12-20 22:50:05.122283|INFO |ClientUI |1 |Connect status: Connection established
2015-12-20 22:50:05.122986|INFO |PermManager | |Loading permissions from cache
2015-12-20 22:50:05.301381|INFO |ClientUI | |Last update check was: Paz Oca 1 00:00:01 2017
2015-12-20 22:50:05.301604|INFO |ClientUI | |Checking for update
2015-12-20 22:50:05.306656|INFO |Update | |Checking for updates...
2015-12-20 22:50:05.655616|INFO |Update | |Check license version: 1
2015-12-20 22:50:05.657549|INFO |LicenseViewer | |License language: en
2015-12-20 22:50:05.657883|INFO |LicenseViewer | |Found cached license for version 1 and language en
2015-12-20 22:50:05.778698|INFO |Newsticker | |Newsticker next check: Pzt Ara 21 01:00:09 2015
2015/12/21 00:50:32 9fce4f41 fe05c913 DEBUG Storing configuration.
2015/12/21 00:51:13 9fce4f41 INFO JOBS-ADD [admin] %!s(*string=0xc208131840) OK
2015/12/21 00:51:13 youtube-dl not available, so not able to download. whoops.
2. I didn't change language(tr.json). I uploaded tr.json in "/opt/ts3soundboard/data/locales" but didn't work. I didn't see on webinterface menu. I saw only german and english. How can I solve this problem ?
