Loglevel increased Problem (Nur 3 Bots conntecten)
Qinaii
SinusBot version (in you web-interface under Settings -> Info -> About)
1.0.0-beta.8-9e95ca7
TS Client and Server version
Client Release 3.3.2 - 26 Aug 2019
Server version: 3.9.1
OS (operating system), e.g. Windows 10 64bit or Debian 9 64bit
Debian 9 64bit (Kernel 4.9.0)
hardware specs (e.g. VPS, Core i7, 8 GB RAM)
vCores 6
RAM 12GB
the instance log and bot log (set LogLevel = 10 in the config.ini before)
your config.ini
ExternalFileBase = ""
LicenseKey = "jdIyTWB00TynKoyMmTAiREFJzTplkkAX40cDFC+LTlw="
DevMode = false
[TTS]
Enabled = false
Diagnostic script
- Binary Info: MD5 Hash: 43a7695283e7688edd94790e09bbce39, Perms: 755, User: sinusbot
- Version: 1.0.0-beta.8-9e95ca7
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.09.28)
- Installed scripts: advertising.js; alonemode.js; AntiProxy.js; away_mover.js; badnickname.js; bookmark.js; Channel_Servergroup_Assigner.js; command.js; followme.js; instagram.js; norecording.js; OKlib.js; Online_Users_Record.js; PrivatChannelManager.js; rememberChannel.js; RLNT MUOJ v1.0.0.js; RLNT OOTO v1.0.0.js; sinusbot-commands.js; SteamUserQuery.js; support-pp.js; TwitchStatus_Advanced.js; welcome.js; welcomeSound.js; youtube.js
linux-vdso.so.1 (0x00007ffc4f2ee000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f8e175d3000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f8e1727b000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f8e16e7a000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f8e16515000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f8e162a1000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f8e1609d000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f8e15d99000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f8e15b7c000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f8e157fa000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f8e155e3000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f8e15244000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f8e1502a000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f8e14e22000)
/lib64/ld-linux-x86-64.so.2 (0x00007f8e177ed000)
- Time (local): 22.10.2019 11:48:44 CEST +02:00:00
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: 2019.09.28
[/CODE]
[2019-10-22 11:48:44] [DEBUG] Done.
Beim Diag, weiß ich nicht ob der output richtig ist. habe keine debugdatei erhalten, falls doch eine erstellt wird und ich es nicht weiß wo, lasst es mich bitte Wissen.
Eigentliche Problem im terminal vom Sinusbot:
2019/10/22 11:51:20 d6e0e5f7 abfe79a3 INFO Starting instance ts3server://127.0.01?port=9987&nickname=Server%20Wache&password=&cid=60&channelpassword=
2019/10/22 11:51:20 X [MAIN] New connection
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/d6e0e5f7-25c6-403d-b733-f1adc5282fbe/abfe79a3-d40d-446a-bea9-4a5efaa4ea0e/crashdumps
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/d6e0e5f7-25c6-403d-b733-f1adc5282fbe/abfe79a3-d40d-446a-bea9-4a5efaa4ea0e/crashdumps
2019/10/22 11:51:21 X [MAIN] New connection
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO | | |SystemInformation: Linux 4.9.0 #1 SMP Thu Jun 27 15:10:55 MSK 2019 x86_64 Binary: 64bit
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO | | |Using hardware aes
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO | | |successfully downloaded revocation list for accounting
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO | | |*** Time [ICONMANGER]: 213
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO |Addons | |Checking for addon updates...
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG TS>Crashdump written (unhandled) !
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TS |CRITICAL| | |Failure during pthread_create, error = EAGAIN
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 DEBUG Closed.
2019/10/22 11:51:21 d6e0e5f7 abfe79a3 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/10/22 11:51:22 d6e0e5f7 abfe79a3 DEBUG closing channels
2019/10/22 11:51:22 d6e0e5f7 abfe79a3 DEBUG eof from voice
Ich kann drei Bots connecten lassen, danach (beim 4. kommt dieses Problem)
Danke im vorraus
Vom diag-Output fehlen da noch die oberen Zeilen mit den System-Infos, die sind ggf noch wichtig.
Wie startest du den Bot?
Qinaii
Ich sehe nur so weit vom Diag, wie kann ich mehr sehen ??
starte Sinusbot über ein screen -S und als sinusbot
Qinaii
sinusbot@h2720579:/opt/sinusbot$ ulimit -a
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 1030716
max locked memory (kbytes, -l) 64
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 62987
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited
- Operating System: Debian GNU/Linux 9.11 (stretch) (OpenVZ)
- Kernel: Linux 4.9.0 x86_64
- Load Average: 0.05 0.14 0.22
- Uptime: 1 days, 11 hours, 43 minutes, 58 seconds
- OS APT Last Update: 22.10.2019 10:22:09 CEST +02:00:00
- Shell Locale: de_DE.utf8
CPU(s): 0
Model name: Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
CPU MHz: 1999.739
Virtualization: VT-x
Hypervisor vendor: Parallels
Virtualization type: container
- RAM: 761.41 MB/12.00 GB in use (6%)
- DISK: 2.17 GB/599.78 GB in use (0%)
- libglib: 2.50.3-2+deb9u1
- Status: running (PIDs: 28811 28810, User: sinusbot)
linux-vdso.so.1 (0x00007ffdd99c5000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007eff48483000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007eff4812b000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007eff47d2a000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007eff473c5000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007eff47151000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007eff46f4d000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007eff46c49000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007eff46a2c000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007eff466aa000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007eff46493000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007eff460f4000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007eff45eda000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007eff45cd2000)
/lib64/ld-linux-x86-64.so.2 (0x00007eff4869d000)
- Time (local): 22.10.2019 12:17:31 CEST +02:00:00
Starte mal:
ulimit -n 8192
Und schau danach den Wert mit ulimit -a, Zeile "open files" nochmal an. Der sollte dann auf 8192 stehen.
DIREKT danach (also nicht im neuen Screen o.Ä.) den Bot nochmal starten und versuchen, ob's hilft.
Qinaii
1x ist es gecrashed und ging aus, das andere mal kam dieser Fehler
2019/10/22 12:31:16 d6e0e5f7 86dc813c INFO Starting instance ts3server://127.0.01?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/10/22 12:31:16 X [MAIN] New connection
2019/10/22 12:31:16 d6e0e5f7 86dc813c DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/d6e0e5f7-25c6-403d-b733-f1adc5282fbe/86dc813c-2a39-1b2a-a643-b95ceeecdad7/crashdumps
2019/10/22 12:31:16 d6e0e5f7 86dc813c DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/d6e0e5f7-25c6-403d-b733-f1adc5282fbe/86dc813c-2a39-1b2a-a643-b95ceeecdad7/crashdumps
funktioniert dennoch nicht
Qinaii
2019/10/22 12:32:38 d6e0e5f7 86dc813c INFO Starting instance ts3server://127.0.01?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/10/22 12:32:38 d6e0e5f7 86dc813c ERROR Error spawning instancefork/exec /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: resource temporarily unavailable
2019/10/22 12:32:38 d6e0e5f7 86dc813c INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/10/22 12:32:38 d6e0e5f7 86dc813c DEBUG Closed.
2019/10/22 12:32:39 d6e0e5f7 86dc813c DEBUG eof from voice
2019/10/22 12:32:39 d6e0e5f7 86dc813c DEBUG closing channels
2019/10/22 12:32:39 d6e0e5f7 86dc813c DEBUG eof from data
2019/10/22 12:32:39 d6e0e5f7 7e6e6b1e WARN Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
Qinaii
beim crash ist der bot abgeschmiert und hat den screen geschlossen. und die Bots haben einen timeout bekommen aufm TS
Hat das geklappt? Stand das auf 8192? Und direkt danach hast du mit ./sinusbot gestartet?
Dass der screen geschlossen wird sollte NIE passieren. Da beschneidet das System arg deine Ressourcen (das ist auch die Meldung beim instance/fork).
Qinaii
8192 stand da ja und habe es mit ./sinusbot gestartet weiteres aber mit passwortchange befehl hinten dran
Qinaii
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/10/22 12:38:14 X [MAIN] New connection
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/d6e0e5f7-25c6-403d-b733-f1adc5282fbe/5f634e8b-60a1-dcc2-9d6f-eeea89179074/crashdumps
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/d6e0e5f7-25c6-403d-b733-f1adc5282fbe/5f634e8b-60a1-dcc2-9d6f-eeea89179074/crashdumps
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO | | |SystemInformation: Linux 4.9.0 #1 SMP Thu Jun 27 15:10:55 MSK 2019 x86_64 Binary: 64bit
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO | | |Using hardware aes
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO | | |successfully downloaded revocation list for accounting
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO | | |*** Time [ICONMANGER]: 177
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO |Addons | |Checking for addon updates...
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG TS>Crashdump written (unhandled) !
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TS |CRITICAL| | |Failure during pthread_create, error = EAGAIN
2019/10/22 12:38:14 d6e0e5f7 5f634e8b DEBUG Closed.
2019/10/22 12:38:14 d6e0e5f7 5f634e8b INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/10/22 12:38:15 d6e0e5f7 5f634e8b DEBUG eof from voice
2019/10/22 12:38:15 d6e0e5f7 5f634e8b DEBUG closing channels
2019/10/22 12:38:27 d6e0e5f7 abfe79a3 DEBUG Storing configuration.
2019/10/22 12:38:27 d6e0e5f7 5f634e8b DEBUG Storing configuration.
2019/10/22 12:38:27 d6e0e5f7 7e6e6b1e DEBUG Storing configuration.
Mitlerweile funktionieren nurnoch 2 Bots
Das ist der Knackpunkt: da versucht der Bot den TS client zu starten und das System sagt: "nope". Das müsstest du ggf. mit deinem Hoster klären.
OpenVZ ist eine Art Virtualisierung, die sich extrem in die Ressourcenverwaltung einmischen kann. Je nachdem wie dein Hoster dich da konfiguriert hat, eckt das da aneinander.
Qinaii
what should i do now ? Es hat ja vorher auch funktioniert, also Monate vorher mit älteren Sinusbot Versionen und da hat ich 6 Bots aufm Server. Mit dem selben Anbieter.
Es kann durchaus sein, dass ältere Versionen den "open files" counter (dahinter verbirgt sich mehr als nur "offene Dateien") nicht so arg hochgezogen haben, neuere aber schon. Jeder zusätzliche Bot erhöht das wieder um fast denselben Faktor. Grundsätzlich sind das keine enormen Werte, aber Hoster, die zum Teil ihre Maschinen extrem überbuchen, versuchen verständlicherweise halt zu verhindern, dass Prozesse unnötig laufen und Ressourcen verschwenden.
Die Sache ist halt die: solange der Prozess selbst nicht aus irgendwelchen Gründen in einen Berserkermodus verfällt (und das ist in der Geschichte des Bots noch nicht vorgekommen), kann man an Fehlern vom System bezgl. Ressourcen von uns aus nicht viel machen. Da muss der Hoster ran und sich das im Einzelnen ansehen.
(Der Hoster hat bei OpenVZ eine Statistik-Tabelle, genannt beancounters, in der steht, was am Limit war, als es abgelehnt wurde.)
Qinaii
Was sollte ich im Support Ticket reinschreiben, sodass ich mehr Leistung in der Virtualisierung erhalte ? Weil 12GB RAm und 6 Cores dennoch schlechte Leistung durch Verringerung der Virtualisierung ist doch beschiss oder nicht ?
