panic.go Problem
Rolfol
Betriebssystem: Debian Wheezy 7
SinusBot Version: 0.9.16
TS3 Version: 3.0.10.3
Problembeschreibung
Ich hab den ganzen morgen gesucht und eigentlich keinen Plan wo das Problem liegt.
Log level = 10
2017/01/27 11:34:10 e112cc6b df71e277 INFO Starting instance ts3server://beckerpm.de?port=9987&nickname=Test&password=&channel=&channelpassword=
2017/01/27 11:34:10 e112cc6b df71e277 INFO TS |INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
2017/01/27 11:34:10 e112cc6b df71e277 INFO TS |INFO |ServerLibPriv | | SystemInformation: Linux 2.6.32-26-pve #1 SMP Mon Oct 14 08:22:20 CEST 2013 x86_64 Binary: 64bit
2017/01/27 11:34:10 e112cc6b df71e277 INFO TS |INFO |ServerLibPriv | | Using hardware aes
2017/01/27 11:34:10 e112cc6b df71e277 INFO TS |INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
2017/01/27 11:34:10 e112cc6b df71e277 INFO TS |INFO |DatabaseQuery | | dbPlugin version: 3.7.3
2017/01/27 11:34:10 e112cc6b df71e277 INFO TS |INFO |DatabaseQuery | | checking database integrity (may take a while)
2017/01/27 11:34:10 e112cc6b df71e277 INFO Loading script welcometext
2017/01/27 11:34:10 e112cc6b df71e277 INFO Initialization complete
2017/01/27 11:34:10 e112cc6b df71e277 INFO Auto-Starting e112cc6b-eb68-4e7e-8ac1-4b4d0f4d1205/df71e277-68d8-47ee-81cd-ce3fce47401c in 500 ms...
2017/01/27 11:34:10 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/01/27 11:34:10 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2017/01/27 11:34:10 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2017/01/27 11:34:10 e112cc6b df71e277 INFO TS |CRITICAL|DatabaseQuery | | setSQLfromFile( file:sql/create_sqlite//create_tables.sql) failed
2017/01/27 11:34:10 e112cc6b df71e277 DEBUG Closed.
2017/01/27 11:34:10 e112cc6b df71e277 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017/01/27 11:34:10 [GENERAL/RADIO ] INFO RadioStation data loaded
2017/01/27 11:34:11 [GENERAL/RADIO ] INFO Imported radio stations
2017/01/27 11:34:11 e112cc6b df71e277 WARN Fail from data reader: EOF
2017/01/27 11:34:11 EOF &▒▒▒[▒
▒%▒ /usr/local/go/src/runtime/panic.go 387
lנ ▒]t▒▒U▒▒▒_▒▒[▒8uj▒J▒(>U▒▒u▒ ▒ح
>▒▒BO▒▒m0HP▒▒s ۶▒p▒x▒v▒'6▒▒▒
▒ ▒1▒ 393
▒▒$▒▒<▒M▒6 /usr/local/go/src/runtime/asm_amd64.s 2232
2017/01/27 11:34:11 EOF &▒▒▒erLibPriv | | SystemInformation: Linux 2.6.32-26-pve #1 SMP Mon Oct 14 08:22:20 CEST 2013 x86_64 Binary: 64bit
2017/01/27 11:34:11 e112cc6b df71e277 INFO TS |INFO |ServerLibPriv | | Using hardware aes
2017/01/27 11:34:11 e112cc6b df71e277 INFO TS |INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
2017/01/27 11:34:11 e112cc6b df71e277 INFO TS |INFO |DatabaseQuery | | dbPlugin version: 3.7.3
2017/01/27 11:34:11 e112cc6b df71e277 INFO TS |INFO |DatabaseQuery | | checking database integrity (may take a while)
2017/01/27 11:34:11 e112cc6b df71e277 INFO TS |CRITICAL|DatabaseQuery | | setSQLfromFile( file:sql/create_sqlite//create_tables.sql) failed
2017/01/27 11:34:11 e112cc6b df71e277 DEBUG Closed.
2017/01/27 11:34:11 e112cc6b df71e277 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
Debian 7 wird nicht mehr unterstützt,
wenn du den Bot weiterhin verwenden willst solltest du auf Debian 8 updaten
Das kommt noch dazu^^ Du hast nicht den TS Client, sondern den Server installiert. Dennoch, was @Multivitamin gesagt hat, stimmt.
