TheNarboxCZE
Please help, i installed sinusbot from https://sinusbot.github.io/docs/installation/linux/ and when bot connect have disabled sounds. https://ctrlv.cz/HeXV Please help
Your screenshot shows 3.2.3 though.Im installed TS3 client 3.2.5
2019-07-28T15:40:18+02:00 new track info: OpenFM (4f70656e464d)
2019-07-28T15:40:18+02:00 PLAY [admin] 47457f25-50a2-46ba-8aa7-0f157a97c6ea OK
2019-07-28T15:40:18+02:00 New channel 47457f25-50a2-46ba-8aa7-0f157a97c6ea () ID d32b39d6-30d6-4b5f-9ed0-b7b181c9340c (cc 0)
2019-07-28T15:40:11+02:00 TS |INFO | | |Statistics report: Not yet, next report on Tue Aug 20 19:17:56 2019
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019-07-28T15:40:11+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-07-28T15:40:11+02:00 TS |INFO |PermManager | |Loading permissions from cache
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2019-07-28T15:40:11+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2019-07-28T15:40:11+02:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2019-07-28T15:40:11+02:00 TS |ERROR |ALSA | |snd_pcm_open: No such file or directory -
2019-07-28T15:40:11+02:00 TS>AA ts3.alsa.dummy.capturedefault 5
2019-07-28T15:40:11+02:00 TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.alsa.dummy.capturedefault
2019-07-28T15:40:11+02:00 TS>AA ts3.alsa.dummy.playbackdefault 5
2019-07-28T15:40:11+02:00 TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.alsa.dummy.playbackdefault
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI |1 |Initiating connection: 95.156.227.80:9987
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI |1 |Connect to server: 95.156.227.80
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI | |ts3server: 95.156.227.80?port=9987&nickname=MusicBOT&password=&channel=&channelpassword=
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/239a382d-14ab-49bb-9381-686f3c1e6ff0/ce10df38-718f-44e4-9c3d-f5469f83491d/settings.db
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2019-07-28T15:40:11+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-07-28T15:40:11+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019-07-28T15:40:11+02:00 TS |INFO | | |*** Time [INIT]: 368
2019-07-28T15:40:11+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 367
2019-07-28T15:40:11+02:00 TS |INFO | | |*** Time [SERVERVIEWMANAGER]: 102
2019-07-28T15:40:11+02:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2019-07-28T15:40:11+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-07-28T15:40:11+02:00 TS |INFO |Plugins | |Api version is not compatible for plugin: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2019-07-28T15:40:11+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-07-28T15:40:11+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2019-07-28T15:40:11+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-07-28T15:40:11+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-07-28T15:40:11+02:00 TS |INFO |Addons | |Checking for addon updates...
2019-07-28T15:40:10+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-07-28T15:40:10+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-07-28T15:40:10+02:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2019-07-28T15:40:10+02:00 TS |ERROR |PulseAudio | |pa_context_connect failed -
2019-07-28T15:40:10+02:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
2019-07-28T15:40:10+02:00 TS |INFO | | |Using hardware aes
2019-07-28T15:40:10+02:00 TS |INFO | | |SystemInformation: Linux 4.15.18-14-pve #1 SMP PVE 4.15.18-38 (Tue, 30 Apr 2019 10:51:33 +0200) x86_64 Binary: 64bit
2019-07-28T15:40:10+02:00 TS |INFO | | |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019-07-28T15:40:10+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/239a382d-14ab-49bb-9381-686f3c1e6ff0/ce10df38-718f-44e4-9c3d-f5469f83491d/crashdumps
2019-07-28T15:40:10+02:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/239a382d-14ab-49bb-9381-686f3c1e6ff0/ce10df38-718f-44e4-9c3d-f5469f83491d/crashdumps
2019-07-28T15:40:10+02:00 Starting instance ts3server://95.156.227.80?port=9987&nickname=MusicBOT&password=&channel=&channelpassword=
2019-07-28T15:40:10+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-07-28T15:40:10+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-07-28T15:40:10+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-07-28T15:40:10+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-07-28T15:40:10+02:00 Could not create Chat-Tabletable Chat already exists
2019-07-28T15:40:10+02:00 About to run.
2019-07-28T15:40:10+02:00 Prespawn.
2019-07-28T15:40:10+02:00 script command loaded
2019-07-28T15:40:10+02:00 module registered as command
2019-07-28T15:40:10+02:00 registered callback for event chat
2019-07-28T15:40:10+02:00 serialized function: true
2019-07-28T15:40:10+02:00 Auto-Starting 239a382d-14ab-49bb-9381-686f3c1e6ff0/ce10df38-718f-44e4-9c3d-f5469f83491d in 500 ms...
2019-07-28T15:40:10+02:00 Initialization complete
2019-07-28T15:40:10+02:00 executing script command
https://files.teamspeak-services.com/releases/client/3.3.0/TeamSpeak3-Client-linux_amd64-3.3.0.run
The TS-client is too old for the sinusbot version you installedApi version is not compatible for plugin: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
