Been a while since I've made a thread, haven't been active here, but still actively had the bot running (on a license) for my community until recently where it wouldn't start.
None of the latest versions, both internal and public for linux work for me, even as a fresh setup.
Server time seems to be in sync, so I don't think that's the issue, but who knows.
My VPS IP did change "recently" (sometime in the previous months) from
diagSinusbot.sh output
192.223.26.175
-> 74.91.119.170
, so I'm assuming maybe it's being blacklisted?curl -v --no-keepalive --http1.1 https://update01.sinusbot.com
returns a 403 with CF's captcha page- Host is NFOservers
- Operating System: Debian GNU/Linux 9.13 (stretch)
- Kernel: Linux 4.9.0-12-amd64 x86_64
- Load Average: 0.03 0.10 0.16
- Uptime: 0 days, 15 hours, 52 minutes, 35 seconds
- OS APT Last Update: 02.08.2020 15:31:22 CDT -05:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 4
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
CPU MHz: 3000.166
Hypervisor vendor: Xen
Virtualization type: full
- RAM: 2.17 GB/3.85 GB in use (56%)
- DISK: 122.71 GB/590.58 GB in use (20%)
- libglib: 2.50.3-2+deb9u2
- Webinterface: port locally not reachable (Port: 8088)
- Binary: /home/sinusbot/ts3bots/sinusbot-test/sinusbot
- TS3Path = /home/sinusbot/ts3bots/sinusbot-test/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.5.3)
- YoutubeDLPath = not set (does exist anyway, version: 2020.07.28)
- TS3Client/libqxcb-glx-integration.so: yes
linux-vdso.so.1 (0x00007fff3db83000)
libswresample.so.2 => /home/sinusbot/ts3bots/sinusbot-test/libswresample.so.2 (0x00007fcaffa7e000)
libavfilter.so.6 => /home/sinusbot/ts3bots/sinusbot-test/libavfilter.so.6 (0x00007fcaff726000)
libavformat.so.57 => /home/sinusbot/ts3bots/sinusbot-test/libavformat.so.57 (0x00007fcaff325000)
libavcodec.so.57 => /home/sinusbot/ts3bots/sinusbot-test/libavcodec.so.57 (0x00007fcafe9c0000)
libavutil.so.55 => /home/sinusbot/ts3bots/sinusbot-test/libavutil.so.55 (0x00007fcafe74c000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fcafe548000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fcafe244000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fcafe027000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fcafdca5000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fcafda8e000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fcafd6ef000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fcafd4d5000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fcafd2cd000)
/lib64/ld-linux-x86-64.so.2 (0x00007fcaffc98000)
- HTTPS check with IPv4 mode: FAILED [Failed connection to www.sinusbot.com, CODE #403]
update01.sinusbot.com -> 104.28.15.74: FAILED [CODE #403]
update02.sinusbot.com -> 104.28.15.74: FAILED [CODE #403]
update03.sinusbot.com -> 172.67.132.160: FAILED [CODE #403]
- Time (local): 02.08.2020 15:53:36 CDT -05:00:00
- Time (remote): 02.08.2020 15:53:36 CDT -05:00:00
- Timezone: America/Chicago
- TeamSpeak3 Version: 3.5.3
- youtube-dl Version: 2020.07.28
