croppa
Operating System: / Linux
SinusBot Version: 0.10.8-71ba94b
TS3 Version: 3.0.19.4
bot cant connect with server idk why allowed version ts3 clinet (https://i.imgur.com/8l6uxeO.png) and on other ts3 working
2017-11-11T20:50:58+01:00 TSClient quit.
2017-11-11T20:50:57+01:00 New connection status 0; Error 1797
2017-11-11T20:50:57+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-11-11T20:50:57+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2017-11-11T20:50:57+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-11-11T20:50:52+01:00 New connection status 1; Error 0
2017-11-11T20:50:52+01:00 TS |INFO | | |Statistics report: Not yet, next report on Fri Dec 1 17:44:27 2017
2017-11-11T20:50:52+01:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-11-11T20:50:52+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-11-11T20:50:51+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-11-11T20:50:51+01:00 TS |INFO |ClientUI |1 |Initiating connection: 178.217.187.190:10134 178.217.187.190
2017-11-11T20:50:51+01:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-11-11T20:50:51+01:00 TS |INFO |ClientUI |1 |Connect to server: 178.217.187.190
2017-11-11T20:50:51+01:00 TS |INFO |ClientUI | |ts3server: 178.217.187.190?port=10134&nickname=Ks.Muzyk&password=&channel=&channelpassword=
2017-11-11T20:50:51+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/024e514b-e5ec-4444-9fa2-805e5e3192fa/ca49c47f-1476-4d12-88f1-7de1d419ed7f/settings.db
2017-11-11T20:50:51+01:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-11-11T20:50:51+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-11-11T20:50:50+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-11-11T20:50:50+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-11-11T20:50:50+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-11-11T20:50:50+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-11-11T20:50:50+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-11-11T20:50:50+01:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-11-11T20:50:50+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-11-11T20:50:50+01:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-11-11T20:50:50+01:00 TS |INFO | | |Using hardware aes
2017-11-11T20:50:50+01:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab123.9 #1 SMP Thu Jun 29 13:01:59 MSK 2017 x86_64 Binary: 64bit
2017-11-11T20:50:50+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-11-11T20:50:50+01:00 Starting instance ts3server://178.217.187.190?port=10134&nickname=Ks.Muzyk&password=&channel=&channelpassword=
2017-11-11T20:50:49+01:00 Could not create Notifications-Tabletable Notifications already exists
2017-11-11T20:50:49+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-11-11T20:50:49+01:00 Could not create Chat-Tabletable Chat already exists
2017-11-11T20:40:12+01:00 TSClient quit.
2017-11-11T20:40:11+01:00 New connection status 0; Error 1797
2017-11-11T20:40:11+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-11-11T20:40:11+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2017-11-11T20:40:11+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-11-11T20:40:06+01:00 New connection status 1; Error 0
2017-11-11T20:40:06+01:00 TS |INFO | | |Statistics report: Not yet, next report on Fri Dec 1 17:44:27 2017
2017-11-11T20:40:06+01:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-11-11T20:40:06+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-11-11T20:40:05+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-11-11T20:40:05+01:00 TS |INFO |ClientUI |1 |Initiating connection: 178.217.187.190:10134 178.217.187.190
2017-11-11T20:40:05+01:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-11-11T20:40:05+01:00 TS |INFO |ClientUI |1 |Connect to server: 178.217.187.190
2017-11-11T20:40:05+01:00 TS |INFO |ClientUI | |ts3server: 178.217.187.190?port=10134&nickname=Ks.Muzyk&password=&channel=&channelpassword=
2017-11-11T20:40:04+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/024e514b-e5ec-4444-9fa2-805e5e3192fa/ca49c47f-1476-4d12-88f1-7de1d419ed7f/settings.db
2017-11-11T20:40:04+01:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-11-11T20:40:04+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-11-11T20:40:03+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-11-11T20:40:03+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-11-11T20:40:03+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-11-11T20:40:03+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-11-11T20:40:03+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-11-11T20:40:03+01:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-11-11T20:40:03+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-11-11T20:40:03+01:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-11-11T20:40:03+01:00 TS |INFO | | |Using hardware aes
2017-11-11T20:40:03+01:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab123.9 #1 SMP Thu Jun 29 13:01:59 MSK 2017 x86_64 Binary: 64bit
2017-11-11T20:40:03+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-11-11T20:40:03+01:00 Starting instance ts3server://178.217.187.190?port=10134&nickname=Ks.Muzyk&password=&channel=&channelpassword=
2017-11-11T20:40:03+01:00 Could not create Notifications-Tabletable Notifications already exists
2017-11-11T20:40:03+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-11-11T20:40:03+01:00 Could not create Chat-Tabletable Chat already exists
2017-11-11T20:25:43+01:00 TSClient quit.
2017-11-11T20:25:42+01:00 New connection status 0; Error 1797
2017-11-11T20:25:42+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-11-11T20:25:42+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2017-11-11T20:25:42+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-11-11T20:25:37+01:00 New connection status 1; Error 0
2017-11-11T20:25:37+01:00 TS |INFO | | |Statistics report: Not yet, next report on Fri Dec 1 17:44:27 2017
2017-11-11T20:25:37+01:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-11-11T20:25:37+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-11-11T20:25:37+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-11-11T20:25:36+01:00 TS |INFO |ClientUI |1 |Initiating connection: 178.217.187.190:10134 178.217.187.190
2017-11-11T20:25:36+01:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-11-11T20:25:36+01:00 TS |INFO |ClientUI |1 |Connect to server: 178.217.187.190
2017-11-11T20:25:36+01:00 TS |INFO |ClientUI | |ts3server: 178.217.187.190?port=10134&nickname=Ks.Muzyk&password=&channel=&channelpassword=
2017-11-11T20:25:35+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/024e514b-e5ec-4444-9fa2-805e5e3192fa/ca49c47f-1476-4d12-88f1-7de1d419ed7f/settings.db
2017-11-11T20:25:35+01:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-11-11T20:25:35+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-11-11T20:25:35+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-11-11T20:25:35+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-11-11T20:25:35+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-11-11T20:25:35+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-11-11T20:25:35+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-11-11T20:25:35+01:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-11-11T20:25:35+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-11-11T20:25:35+01:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-11-11T20:25:35+01:00 TS |INFO | | |Using hardware aes
2017-11-11T20:25:35+01:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab123.9 #1 SMP Thu Jun 29 13:01:59 MSK 2017 x86_64 Binary: 64bit
2017-11-11T20:25:35+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-11-11T20:25:34+01:00 Starting instance ts3server://178.217.187.190?port=10134&nickname=Ks.Muzyk&password=&channel=&channelpassword=
2017-11-11T20:25:34+01:00 Could not create Notifications-Tabletable Notifications already exists
2017-11-11T20:25:34+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-11-11T20:25:34+01:00 Could not create Chat-Tabletable Chat already exists
2017-11-11T20:25:32+01:00 BOT-CONFIG [admin] HOST PORT CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-11-11T20:25:02+01:00 TSClient quit.
2017-11-11T20:25:02+01:00 KILL [admin] OK
2017-11-11T20:25:01+01:00 New connection status 0; Error 0
