Problems with youtube-dl
itsphill
Hello, i have problems playing playlist added with the youtube playlist link, and i cant play music/download youtube music so i think the problem is with the youtube-dl!
this is not the first time I'm having this problem, pls help!
Sinusbot diagnostic RESULTS:
 - Operating System: Ubuntu 18.04.3 LTS (OpenVZ)
 - Kernel: Linux 4.15.0 x86_64
 - Load Average: 0.88 0.47 0.38
 - Uptime: 2 days, 0 hours, 2 minutes, 13 seconds
 - OS APT Last Update: 06.12.2019 18:45:56 UTC +00:00:00
 - Shell Locale: (not set)
    Architecture:        x86_64
    CPU(s):              0
    Model name:          Intel(R) Xeon(R) CPU E5-2683 v3 @ 2.00GHz
    CPU MHz:             2499.877
    Virtualization:      VT-x
    Hypervisor vendor:   Parallels
    Virtualization type: container
 - RAM:  B/8.00 GB in use (%)
 - SWAP:  B/ B in use (%)
 - DISK: 7.08 GB/58.93 GB in use (12%)
 - Status: running (PIDs: 921 920, User: sinusbot)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.11.28)
 - Installed scripts: AFK_Mover.js; AFK_Mover_(AwayMuteDeafIdle).js; AntiProxy.js; Auto_Channel_Creator.js; Avatar DW.js; ChatToTTS.js; CountOnlineUsers.js; CountryGroup.js; CountryManager.js; CryptoCurrency_Info.js; Digital_Clock.js; Lauftext__Ticker__APINewsticker_Support.js; Now_Playing_[Cleans_Bad_Tags]_[Custom_Display_Formats]_[TTS_Announce].js; RLNT MOC v1.0.0.js; ServerGroupOnConnect.js; Server_Rules.js; Simple_Custom_Commands.js; SinusForMinecraft.js; Support.js; WelcomeSoundz.js; WoWS_Server_Online_Status.js; YT-search.js; Youtube_Search.js; advertising.js; alonemode.js; bookmark.js; broadcast.js; come.js; command.js; ecovote.js; followme.js; norecording.js; onlineMembersCount.js; registerNotificator.js; rememberChannel.js; simple_channel_creator.js; sinusbot-commands.js; tts-greetings.js; tunakills_ranking.js; welcome.js; youtube.js
    linux-vdso.so.1 (0x00007ffeb37c9000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f5a45d9a000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f5a45a42000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f5a45641000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f5a44cdc000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f5a44a68000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f5a44864000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f5a444c6000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f5a442a7000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f5a43f1e000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f5a43d06000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5a43915000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f5a436f8000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f5a434f0000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f5a45fb4000)
 - Time (local): 06.12.2019 18:58:59 UTC +00:00:00
 - Timezone: Etc/UTC
 - TeamSpeak3 Version: 3.3.2
 - youtube-dl Version: 2019.11.28
