Sometimes the music is cracking and bleeping, i have the audio set to Opus Music -> 10. Still doesnt work PLEASE HELP!
Your issue is most likely the self hosting connection. There are some tricks you can do to reduce the effect of this.
Firstly, Attempt to change your SampleInterval to around 20.
Secondly, As you said, adjust teamspeak settings
Thirdly, If both of these fail, try running a
VB Linux Sinusbot - Seams to work well on self hosting systems
If none of these work. Purchase a dedicated server, and run sinusbot from that.
Hope one of these help.
TGT
