Solved Sinus Bot Crontab Problem
prxy
I just set up the bot. Worked like charm.
But after setting up a crontab for the user sinusbot and creating a script startsinus.sh in the home directory of the user i rebooted and get following
Edit: Forgot to tell you, that i can get into the webinterface and such, but as soon as i start it by the interface, the button turns off after some seconds
System
vServer
Debian 8
1,5Gb RAM
Hardware Unknown (CPU Intel)
Instance-Log
2016-07-12T15:24:04+02:00 Loaded
2016-07-12T15:24:47+02:00 Could not delete from Notificationsno such table: Notifications
2016-07-12T15:24:47+02:00 Could not insert into Notifications-Tableno such table: Notifications
2016-07-12T15:24:47+02:00 Starting instance ts3server://79.ts-rent.de?port=7972&nickname=Ave%20prxy&password=&channel=&channelpassword=
2016-07-12T15:24:47+02:00 TSClient quit.
Config
SecretKey = [222, 204, 107, 244, 60, 115, 183, 83, 109, 217, 30, 167, 2, 222, 47, 33, 69, 237, 246, 240, 119, 140, 227, 226, 90, 89, 158, 176, 55, 230, 41, 39]
MTU = 1500
SampleInterval = 100
Startsinus.sh
cd /opt/ts3soundboard/ (Just added it, because I thought it cause the error)
screen -dmS xinit /opt/ts3soundboard/ts3bot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
I google'd about 1 hour
Please help me :S
Regards
Don't use crontab systemd/initd instead. AND update to the latest Beta...
prxy
Dude, thank you. This was the problem i think... I've just downloaded it today, so it must be the latest version. I reinstalled it and used someones link of teamspeak in this forum now, used init.d - works like charm again ;)
