Sinusbot can not connect to Teamspeak
Badetuch
  • used version: sb: newest, Ts3: 3.1.3
  • used operating system: linux debian 8
  • hardware specs 1GB Ram 1 CPU Core
  • used plugins: no Plugins yet
  • config:
  • Instanze log: http://prntscr.com/jd61kw
Badetuch
Falls du nicht weist was man degegen tuen kann trotzdem Vielen dank!
LG Elia :^)
Edit: sry i forgot that you only speak english, so: Thanks man thant you tired to help me
Elia
PaTiiBoY
  • config:
  • config:
Same Problem here :/
EDIT:
[2018-05-03 13:56:25] [INFO] Starting diagSinusbot v0.7.0 [2018-01-14 18:00 UTC]...
[2018-05-03 13:56:25] [INFO] Checking for new diagnostic script version...
[2018-05-03 13:56:25] [OKAY] You are using the latest version.
[2018-05-03 13:56:25] [INFO] Detected operating system: Debian GNU/Linux 8.10 (jessie)
[2018-05-03 13:56:25] [INFO] Searching bot binary...
[2018-05-03 13:56:25] [DEBUG] Searching in directory '/opt'...
[2018-05-03 13:56:25] [DEBUG] Searching in directory '/opt/sinusbot/'...
[2018-05-03 13:56:25] [DEBUG] Binary 'sinusbot' found.
[2018-05-03 13:56:25] [INFO] Binary found.
[2018-05-03 13:56:25] [DEBUG] Collecting information...
[2018-05-03 13:56:25] [INFO] (Scan may take some moments...)
[2018-05-03 13:56:25] [INFO] Collecting system information...
[2018-05-03 13:56:25] [DEBUG] Getting operating system version...
[2018-05-03 13:56:25] [DEBUG] Checking DNS resolution...
[2018-05-03 13:56:25] [DEBUG] Checking web IPv4 access...
[2018-05-03 13:56:25] [DEBUG] Checking for locales...
[2018-05-03 13:56:25] [DEBUG] Getting processor information...
[2018-05-03 13:56:25] [DEBUG] Checking for available operating system updates...
[2018-05-03 13:56:26] [DEBUG] Getting RAM information...
[2018-05-03 13:56:26] [DEBUG] Getting SWAP information...
[2018-05-03 13:56:26] [DEBUG] Getting DISK information...
[2018-05-03 13:56:26] [DEBUG] Getting disk info by using command:
[2018-05-03 13:56:26] [DEBUG]  $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reiserfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk
[2018-05-03 13:56:26] [INFO] Collecting bot information...
[2018-05-03 13:56:26] [DEBUG] Trying to get SinusBot version using version parameter...
[2018-05-03 13:56:26] [DEBUG] Loading bot config file...
[2018-05-03 13:56:26] [DEBUG] Determining bot status...
[2018-05-03 13:56:26] [DEBUG] Reading ListenPort from bot configuration...
[2018-05-03 13:56:26] [DEBUG] Getting installed bot scripts...
[2018-05-03 13:56:26] [DEBUG] Reading LogLevel from bot configuration...
[2018-05-03 13:56:26] [DEBUG] Reading TS3Path from bot configuration...
[2018-05-03 13:56:26] [DEBUG] Trying to get ts3client version...
[2018-05-03 13:56:26] [DEBUG] Checking installation of bot plugin in ts3client...
[2018-05-03 13:56:26] [DEBUG] Checking for 'youtube-dl'...
[2018-05-03 13:56:30] [DEBUG] Generating output...
[CODE]
 - Operating System: Debian GNU/Linux 8.10 (jessie)
 - Kernel: Linux 3.16.0-6-amd64 x86_64
 - Load Average: 0.04 0.12 0.07
 - Uptime: 0 days, 22 hours, 39 minutes, 9 seconds
 - OS APT Last Update: 03.05.2018 13:50:58 EDT -04:00:00
    CPU(s):                2
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             2
    Model name:            QEMU Virtual CPU version 1.5.3
    CPU MHz:               2493.990
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 379.84 MB/7.81 GB in use (4%)
 - SWAP: 0 B/3.99 GB in use (0%)
 - DISK: 2.07 GB/87.59 GB in use (2%)
   + libglib: 2.42.1-1+b1
 - Status: running (PIDs: 16944 16942, User: sinusbot)
 - Binary Info: MD5 Hash: f42a573b7435a8ff04da446d5ccbe754, Perms: 755, User: sinusbot
 - Version: 0.13.37-9791176
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.1.8)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2018.05.01)
 - Time (local): 03.05.2018 13:56:28 EDT -04:00:00
 - Time (remote): 03.05.2018 13:56:28 EDT -04:00:00
 - Timezone: America/New_York
 - TeamSpeak 3 Version: 3.1.8
 - youtube-dl Version: 2018.05.01
 - DiagScript Version: 0.7.0
[2018-05-03 13:56:30] [DEBUG] Done.
[/CODE]
PaTiiBoY
[QUOTE = "flyth, post: 30240, member: 2"] Du hast den Bot nicht richtig installiert, denn ich denke an Abhängigkeiten. Verwenden Sie das Installationsskript, wenn Sie nicht sicher sind, wie Sie es sich leisten können. [/ QUOTE]
[SPOILER = "Config.ini"]
LicenseKey = "5ITacrDPolMbmuMdtSmjwSfMvIRfKx2qz9rYZuDfMkk="
CacheStreamed = Falsch
ChunkSize = 5242880
[StreamReques]
[Skripte]
[Themen]
Standard = ""
[Spracherkennung]
Aktivieren = false
BenutzerAgent = "SinusBot (0.13.37-9791176)"
Aktivieren = false
Verzögerung = 0
Debug = falsch
Aktivieren = false
Größe = 0
Verzögerung = 0
Intervall = 0
[Radio Stationen]
[/ SPOILER]
[SPOILER = "log"]
2018-05-03T20: 04: 34 + 02: 00 TSClient beendet. LogLevel wurde erhöht, bitte versuchen Sie es erneut, um weitere Details zu sehen.
2018-05-03T20: 04: 34 + 02: 00 Geschlossen.
2018-05-03T20: 04: 34 + 02: 00 TS> / opt / sinbot / teamspeak3-client / ts3client_linux_amd64: Fehler beim Laden von gemeinsam genutzten Bibliotheken: libXtst.so.6: Gemeinsame Objektdatei kann nicht geöffnet werden: Keine solche Datei oder Verzeichnis
2018-05-03T20: 04: 34 + 02: 00 Startinstanz ts3server: //5.1.81.128? Port = 8087 & nickname = SinusBotdfgh & password = & channel = & channelpassword =
2018-05-03T20: 04: 34 + 02: 00 Ungefähr zu rennen.
2018-05-03T20: 04: 34 + 02: 00 Vorbrechen.
2018-05-03T20: 04: 28 + 02: 00 Speichern der Konfiguration.
2018-05-03T20: 03: 59 + 02: 00 TSClient beendet. LogLevel wurde erhöht, bitte versuchen Sie es erneut, um weitere Details zu sehen.
2018-05-03T20: 03: 59 + 02: 00 Geschlossen.
2018-05-03T20: 03: 59 + 02: 00 TS> / opt / sinbot / teamspeak3-client / ts3client_linux_amd64: Fehler beim Laden gemeinsamer Bibliotheken: libXtst.so.6: Gemeinsame Objektdatei kann nicht geöffnet werden: Keine solche Datei oder kein Verzeichnis
2018-05-03T20: 03: 59 + 02: 00 Fehler beim Sprachauslesen: Unix lesen @ -> @: Verwendung einer geschlossenen Netzwerkverbindung
2018-05-03T20: 03: 59 + 02: 00 Startinstanz ts3server: //5.1.81.128? Port = 8087 & nickname = SinusBotdfgh & password = & channel = & channelpassword =
2018-05-03T20: 03: 59 + 02: 00 Ungefähr zu rennen.
2018-05-03T20: 03: 58 + 02: 00 Vorbrechen.
2018-05-03T20: 03: 58 + 02: 00 Geschlossen.
2018-05-03T20: 03: 58 + 02: 00 TSClient beendet. LogLevel wurde erhöht, bitte versuchen Sie es erneut, um weitere Details zu sehen.
2018-05-03T20: 03: 58 + 02: 00 Autostart 6b11b159-dd2d-48a3-835c-cd58b828825c / 42a3ad72-8895-4a38-a585-89f413eabb12 in 500 ms ...
2018-05-03T20: 03: 58 + 02: 00 Initialisierung abgeschlossen
2018-05-03T20: 03: 58 + 02: 00 Startinstanz ts3server: //5.1.81.128? Port = 8087 & nickname = SinusBotdfgh & password = & channel = & channelpassword =
2018-05-03T20: 03: 58 + 02: 00 Ungefähr zu rennen.
2018-05-03T20: 03: 58 + 02: 00 Die Instanz wird aufgrund der fehlenden Konfigurationsdatei kurz erstellt.
[/ SPOILER]
Bitte schau mal meine Diag an, habe den Installer benützt. hoffe es hilft weiter
Badetuch
so
ChunkSize = 5242880
[StreamReques]
[Skripte]
[Themen]
Standard = ""
[Spracherkennung]
Aktivieren = false
Aktivieren = false
Verzögerung = 0
Debug = falsch
Aktivieren = false
Größe = 0
Verzögerung = 0
Intervall = 0
[Radio Stationen]
[/ SPOILER]
[SPOILER = "log"]
[/ SPOILER]
Lg.
so that can not help me ?
PaTiiBoY
so
its a log file that helps other peoples to help us with the problem
sinusbot@vps:/opt/sinusbot$ ./sinusbot
2018/05/03 20:55:25 X [MAIN] Starting up fake x-server...
2018/05/03 20:55:25 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2018/05/03 20:55:25 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
2018/05/03 20:55:25 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2018/05/03 20:55:25 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2018/05/03 20:55:25 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2018/05/03 20:55:25 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChanne        l.js
2018/05/03 20:55:25 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
2018/05/03 20:55:25 4de92695          INFO   Loading instances
2018/05/03 20:55:25 4de92695          INFO   Loading instance://baed8c49-6a4a-4f        da-8cd0-f3ff2f033419
2018/05/03 20:55:25 4de92695 baed8c49 INFO   Starting instance ts3server://127.0        .0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018/05/03 20:55:25 4de92695 baed8c49 INFO   Initialization complete
2018/05/03 20:55:25 4de92695 baed8c49 INFO   Auto-Starting 4de92695-c38a-4dbd-9b        34-83d2141774d9/baed8c49-6a4a-4fda-8cd0-f3ff2f033419 in 500 ms...
2018/05/03 20:55:25 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: L        GPL version 2.1 or later; 81 codecs
2018/05/03 20:55:25 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license:        LGPL version 2.1 or later; 143 formats
2018/05/03 20:55:25 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2018/05/03 20:55:25 4de92695 baed8c49 INFO   TSClient quit. LogLevel has been in        creased, please try to connect again to see more details.
2018/05/03 20:55:25 4de92695 baed8c49 DEBUG  Closed.
2018/05/03 20:55:26 4de92695 baed8c49 DEBUG  Prespawn.
2018/05/03 20:55:26 4de92695 baed8c49 WARN   Fail from voice reader: read unix @        ->@: use of closed network connection
2018/05/03 20:55:26 read unix @->@: use of closed network connection .  138
.  500
.  514
.  489
.  523
.  2197
2018/05/03 20:55:26 4de92695 baed8c49 DEBUG  About to run.
2018/05/03 20:55:26 4de92695 baed8c49 INFO   Starting instance ts3server://127.0        .0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018/05/03 20:55:26 4de92695 baed8c49 DEBUG  TS>/opt/sinusbot/teamspeak3-client/        ts3client_linux_amd64: error while loading shared libraries: libXtst.so.6: canno        t open shared object file: No such file or directory
2018/05/03 20:55:26 4de92695 baed8c49 DEBUG  Closed.
2018/05/03 20:55:26 4de92695 baed8c49 INFO   TSClient quit. LogLevel has been in        creased, please try to connect again to see more details.
2018/05/03 20:55:26 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, supp        ort enabled
2018/05/03 20:55:26 [GENERAL/!!!!!!!] NOTICE You may now configure and launch th        e bots from the webinterface. http://0.0.0.0:8087
error starting up: listen tcp 0.0.0.0:8087: bind: address already in usesinusbot
PaTiiBoY
FIXED ! Läuft nun.
  1. apt-get install x11vnc xvfb libxcursor1 ca-certificates bzip2 -y
  2. update-ca-certificates
  3. apt-get install libglib2.0-0
bei Debian 8.
Lg.
