Sinusbot Connection problem.
BakusCpunek
System: Linux Ubuntu 16
4GB Ram, 4x Core 2,5 GHz.
Okay, i updated bots to 3.1.6, but i have another problem.
2017-12-20T17:22:24+01:00 TSClient quit.
2017-12-20T17:22:23+01:00 New connection status 0; Error 1793
2017-12-20T17:22:23+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-12-20T17:22:23+01:00 TS |INFO |ClientUI |1 |Connection lost, want autoreconnect = 1
2017-12-20T17:22:23+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-12-20T17:22:23+01:00 TS |INFO |PktHandler | |Dropping client 276 because of resend timeout
2017-12-20T17:22:23+01:00 TS |INFO |PktHandler | |Cleaning up connection because of 12 resends of COMMAND packet
Bots are connect but 5 sec later i see this:
<17:22:22> "✡ CZATIN." dropped (connection lost)
<17:22:25> "✡ BocikNeVo." dropped (connection lost)
Any ideas?
have you done the steps for using the 3.1?
  • for Ubuntu/Debian, run the following to install additional dependencies: apt-get install libnss3 libegl1-mesa x11-xkb-utils libasound2
  • remove the file libqxcb-glx-integration.so from the clients' xcbglintegrations directory
  • remove the data/ts3 directory: rm -rf ./data/ts3
BakusCpunek
I think this is server problem.
Once he enters, once not.
Yes, I done the steps using 3.1.
Dropping client 276 because of resend timeout.
Cleaning up connection because of 12 resends of COMMAND packet.
If i click connection info on bot, i dont see ping, idle Time, connection Time etc.
How can I fix it? (Im not owner of server)
