Help plz..
This DIAGSINUSBOT on https://forum.sinusbot.com/threads/diagsinusbot-sh-sinusbot-diagnostic-script.831/
019-08-26T18:27:12+02:00 eof from data
2019-08-26T18:27:12+02:00 closing channels
2019-08-26T18:27:12+02:00 eof from voice
2019-08-26T18:27:11+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-08-26T18:27:11+02:00 Closed.
2019-08-26T18:27:11+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-08-26T18:27:11+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-08-26T18:27:11+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-08-26T18:27:11+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-08-26T18:27:11+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-08-26T18:27:11+02:00 Starting instance ts3server://royal-ts3?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-08-26T18:27:11+02:00 Could not insert into News-Tableno such table: News
2019-08-26T18:27:11+02:00 Could not delete from Newsno such table: News
2019-08-26T18:27:11+02:00 Could not insert into Profiles-Tableno such table: Profiles
2019-08-26T18:27:11+02:00 Could not delete from Profilesno such table: Profiles
2019-08-26T18:27:11+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-08-26T18:27:11+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-08-26T18:27:11+02:00 Could not insert into Application-Tableno such table: Application
2019-08-26T18:27:11+02:00 Could not delete from Applicationno such table: Application
2019-08-26T18:27:11+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-08-26T18:27:11+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-08-26T18:27:11+02:00 Could not create Chat-Tabletable Chat already exists
- Operating System: Debian GNU/Linux 9.9 (stretch) (OpenVZ)
- Kernel: Linux 2.6.32-042stab139.1 x86_64
- Load Average: 0.01 0.00 0.00
- Uptime: 0 days, 0 hours, 2 minutes, 21 seconds
- OS APT Last Update: 26.08.2019 14:56:43 UTC +00:00:00
- Shell Locale: (not set)
- RAM: B/4.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 1.92 GB/50.00 GB in use (3%)
- libglib: 2.50.3-2
- Status: running (PIDs: 278 265, User: sinusbot)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.08.13)
linux-vdso.so.1 (0x00007fffda5db000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f7e84640000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f7e842e8000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f7e83ee7000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f7e83582000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f7e8330e000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7e83103000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7e82dfd000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7e82be0000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f7e8285e000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7e82647000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7e822a8000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7e8208e000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f7e81e84000)
/lib64/ld-linux-x86-64.so.2 (0x0000565226949000)
- Time (local): 26.08.2019 16:26:57 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: 2019.08.13
- libglib: 2.50.3-2
- Timezone: Etc/UTC
LogLevel = 3
ExternalFileBase = ""
LicenseKey = "yN8+zS0nFrzRS6RD16GF1NMflX7hbxsCgO2b2iImJCg="
DevMode = false
[TTS]
Enabled = false
LogLevel = 3
DevMode = false
[TTS]
Enabled = false
