rosettenroman
Hey guys. I'm using the Sinusbot on my TS3 Server on Ubuntu. I installed to bot via the given installation skript. I use the free dynamic DNS service "dynv6".
My Problem:
-If i set the dynv6 IP, the bot connects for 1 secound, then disconnects.
+If i set the acctually IP (Example: 37.48.94.41) the bot connects with no problem and stays online.
Im restarting my Router every week, so the IP changes. Thats why i need to use my dynv6 IP.
Do you can tell my whats the problem here?
Here is the instance log:
My Problem:
2022-12-19T12:44:51+01:00 TSClient quit.
2022-12-19T12:44:50+01:00 Could not remove client from group: insufficient client permissions
2022-12-19T12:44:50+01:00 New connection status 4; Error 0
2022-12-19T12:44:50+01:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2022-12-19T12:44:50+01:00 New connection status 3; Error 0
2022-12-19T12:44:50+01:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2022-12-19T12:44:50+01:00 New connection status 2; Error 0
2022-12-19T12:44:50+01:00 TS |INFO |ClientUI |1 |Connect status: Connected
2022-12-19T12:44:50+01:00 TS |DEVELOP |PktHandler |1 |Puzzle solve time: 5
2022-12-19T12:44:50+01:00 New connection status 1; Error 0
2022-12-19T12:44:50+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2022-12-19T12:44:50+01:00 TS |INFO |ClientUI |1 |Initiating connection: 93.239.XX.XXX:9987
2022-12-19T12:44:50+01:00 New connection status 0; Error 1797
2022-12-19T12:44:50+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2022-12-19T12:44:50+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2022-12-19T12:44:44+01:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI | |Last update check was: Mo. Jan. 1 00:00:01 2035
2022-12-19T12:44:44+01:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2022-12-19T12:44:44+01:00 New connection status 1; Error 0
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI |1 |Initiating connection: [2003:e0:6fff:752:9a9b:cbff:fea8:fd23]:9987
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI |1 |Resolve successful: [2003:e0:6fff:752:9a9b:cbff:fea8:fd23]:998793.239.XX.XXX:9987
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI |1 |Lookup finished: ip=2003:e0:6fff:752:9a9b:cbff:fea8:fd23 port=9987 query=XXXXXXX.v6.rocks error=0
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_ts3._udp.XXXXXX.v6.rocks" DNS server returned answer with no data
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve unsuccessful, "v6.rocks" Domain name not found
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.v6.rocks" Domain name not found
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |No TSDNS found
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 93.239.XX.XX:41144
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 2003:e0:6fff:752:9a9b:cbff:fea8:fd23:41144
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "XXXXXXXXX" =(h: 2003:e0:6fff:752:9a9b:cbff:fea8:fd23 p:0), (h: 93.239.97.173 p:0)
2022-12-19T12:44:44+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "XXXXXXX" =(h: 2003:e0:6fff:752:9a9b:cbff:fea8:fd23 p:0), (h: 93.239.97.173 p:0)
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI |1 |Trying to resolve XXXXXXXXXXX
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI |1 |Connect to server: XXXXXXX
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI | |ts3server: XXXXXXXport=9987&nickname=XXXXXXX&password=XXXXXXXX&cid=53&channelpassword=
2022-12-19T12:44:44+01:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/fdebddc7-867e-455e-8bd5-045954b7cdbb/ecf88bbb-8a36-459e-9380-b3408fcca29d/settings.db
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI | |Qt version: 5.12.1
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2022-12-19T12:44:44+01:00 TS |INFO | | |*** Time [INIT]: 330
2022-12-19T12:44:44+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 330
2022-12-19T12:44:44+01:00 TS |INFO | | |successfully downloaded revocation list for accounting
2022-12-19T12:44:44+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2022-12-19T12:44:44+01:00 TS |INFO |Addons | |Checking for addon updates...
2022-12-19T12:44:44+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2022-12-19T12:44:44+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2022-12-19T12:44:44+01:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2022-12-19T12:44:43+01:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2022-12-19T12:44:43+01:00 TS |INFO | | |Using hardware aes
2022-12-19T12:44:43+01:00 TS |INFO | | |SystemInformation: Linux 5.15.0-56-generic #62~20.04.1-Ubuntu SMP Tue Nov 22 21:24:20 UTC 2022 x86_64 Binary: 64bit
2022-12-19T12:44:43+01:00 TS |INFO | | |TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
2022-12-19T12:44:42+01:00 Starting instance ts3server://XXXXXport=9987&nickname=DJ%XXXX&password=XXXXXX&cid=53&channelpassword=
2022-12-19T12:44:42+01:00 Could not create Notifications-Tabletable Notifications already exists
2022-12-19T12:44:42+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2022-12-19T12:44:42+01:00 Could not create Chat-Tabletable Chat already exists
2022-12-19T12:44:40+01:00 BOT-CONFIG [admin] HOST CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2022-12-19T12:43:15+01:00 Playing next from playlist: ytdl://ytdl/?url=1qtwoQ6BQxI&album=Noyse&title=Frenchcore+Xmas+%28Christmas+Remix%29
